doug
New text-to-speech (TTS) engine
Wed Feb 05, 2014 11:19 pm
For anyone who is interested I've ported a text-to-speech engine to the Raspberry Pi. Google's Android project includes an offline TTS engine called Pico TTS that they licensed from a company called SVOX but open sourced under the Apache 2 license. It is a good quality, well documented product and is designed to run efficiently on embedded platforms like the Raspberry Pi and your smart phone.
I had to do a little hacking to exact it fully from Android and also write a simple demo application to show how it is used so it might be a little rough around the edges but it works and supports several different languages. It is also far nicer to listen to than eSpeak :-)
I made a rather poor quality video/presentation to demo it in action which you can see here:
http://www.youtube.com/watch?v=CY8udTlrBXk
You can find the source code on GitHub here:
https://github.com/DougGore/picopi
It would be good for someone to try it out and let me know if it works for you. I'm sure many projects could benefit from it.
I've also left the code for the Java bindings in (untouched) just in case it could be incorporated into something like Scratch.
Doug
AutoStatic
Re: New text-to-speech (TTS) engine
Thu Feb 06, 2014 4:24 pm
Cool but isn't Pico TTS already in Raspbian?
RPi and real-time, low-latency audio: http://wiki.linuxaudio.org/wiki/raspberrypi
RPi audio repository: http://rpi.autostatic.com/
RPi and audio blog: https://autostatic.com/tag/raspberrypi/
Thu Feb 06, 2014 8:01 pm
There's no Makefile in ../pico/lib
If I try to make in ../pico/tts it fails with
[email protected] /tmp/picopi/pico/tts # make
g++ -L../lib/ strdup16to8.c strdup8to16.c svox_ssml_parser.cpp com_svox_picottsengine.cpp main.cpp -lexpat -lsvoxpico -I../compat/include/ -I../lib/ -fpermissive -o testtts
strdup16to8.c: In function ‘char* strndup16to8(const char16_t*, size_t)’:
strdup16to8.c:163:25: warning: invalid conversion from ‘void*’ to ‘char*’ [-fpermissive]
     ret = malloc(len + 1);
main.cpp: In function ‘int main(int, char**)’:
main.cpp:125:83: warning: invalid conversion from ‘uint8_t* {aka unsigned char*}’ to ‘int8_t* {aka signed char*}’ [-fpermissive]
  result = ttsEngine->synthesizeText(argv[1], synthBuffer, OUTPUT_BUFFER_SIZE, NULL);
In file included from main.cpp:7:0:
../compat/include/TtsEngine.h:235:24: warning:   initializing argument 2 of ‘virtual android::tts_result android::TtsEngine::synthesizeText(const char*, int8_t*, size_t, void*)’ [-fpermissive]
     virtual tts_result synthesizeText(const char *text, int8_t *buffer,
/usr/bin/ld: cannot find -lsvoxpico
collect2: error: ld returned 1 exit status
make: *** [all] Error 1
Yggdrasil
Thu Feb 06, 2014 10:01 pm
Wow, many thanks for this hint and port of the pico speech engine. :)
It's also compilable on other systems and I really like the quality (compared with espeak and festival ).
Edit: Ok, this engine isn't better in all cases. I like the voice in short sequences. Long sequences/sentences sounds quite monotone.
doug
Sat Feb 08, 2014 9:08 am
There should be a Makefile in the pico/lib directory, you need to do a make then a make install so it gets put in a system library directory.
doug
Sat Feb 08, 2014 9:43 am
AutoStatic wrote:Cool but isn't Pico TTS already in Raspbian?
I couldn't find any mention of it anywhere online or on this page:
http://elinux.org/RPi_Text_to_Speech_(Speech_Synthesis)
So I assume it hasn't already been ported but I could be wrong :-)
Yggdrasil wrote:Wow, many thanks for this hint and port of the pico speech engine. :)
It is very portable I noticed the core library in the pico/lib directory required exactly zero changes to build for the Raspberry Pi. The additional C++ bits that wrap around it and extend it took some work but it adds the SSML features. I also added a sample program so there is an example of how to use it.
I agree the speech isn't perfect to get the very best results you usually need a huge data file with lots of pre-recorded words and phrases which can be hundreds of megabytes if not gigabytes in size.
Doug
Sat Feb 08, 2014 12:55 pm
doug wrote:There should be a Makefile in the pico/lib directory, you need to do a make then a make install so it gets put in a system library directory.
Ah ha, it's there now.
NickE
Sat Feb 08, 2014 2:57 pm
I compiled and installed this with the instructions on github, but the testtts program is doing this:
pi$ testtts "Hello"
Pico TTS Test App
Input string: "Hello"
Failed to load language
Synthesising text...
Failed to synth text
and then hangs.
Any ideas of what could be wrong?
doug
Sat Feb 08, 2014 3:22 pm
NickE wrote:I compiled and installed this with the instructions on github, but the testtts program is doing this:
pi$ testtts "Hello"
Pico TTS Test App
and then hangs.
Sorry about that, I realised I hard coded to the language data path to "../lang/" on line 103 of main.cpp. If you are running it in the pico/tts subdirectory where it is built you should be ok otherwise you might need to modify the path and copy the language data. The test program is hard coded to use the UK English so you will need the en-GB_kh0_sg.bin and en-GB_ta.bin files.
I realise that isn't very convenient, I might look into having a system wide path to install the voice data to allow multiple applications to find and use the same voice data.
Doug
darrepac
Mon Feb 10, 2014 12:23 pm
Indeed, I could be interested to know how to build french langage...
doug
Mon Feb 10, 2014 1:36 pm
darrepac wrote:Indeed, I could be interested to know how to build french langage...
Line 113 of main.cpp:
result = ttsEngine->setLanguage("eng", "GBR", "");
Change that to:
result = ttsEngine->setLanguage("fra", "FRA", "");
Hopefully that should switch it to French. I should really make that a command line switch.
Here is a list of all the supported language settings:
  • UK English - eng / GBR
  • US English - eng / USA
  • French - fra / FRA
  • German - deu / DEU
  • Spanish - spa / SPA
  • Italian - ita / ITA
Doug
AutoStatic
Mon Feb 10, 2014 8:33 pm
Added it to the elinux.org Wiki: http://elinux.org/RPi_Text_to_Speech_(S ... _to_Speech
doug
Mon Feb 10, 2014 8:59 pm
Doh I completely failed to spot that it already existed as a package :oops:
pico2wave is easier to use to generate some speech in a file but I'm not sure you can pump the output straight into aplay like my little sample application does. In addition I've ported across the SSML parser and C++ wrapper which might be handy for some people.
I think the sample app is still useful but rather than build the core library yourself you could just install the libttspico-utils package :-)
Doug
Yggdrasil
Fri Feb 14, 2014 5:21 pm
I've added a parameter for testts to select the used language, but do not want fork the project on Github. Feel free do add this :)
http://pastebin.com/FEcZwSYr
positron
Fri Feb 21, 2014 10:05 am
Hello there everyone! I've tried to install pico from repository as descibed in http://elinux.org/RPi_Text_to_Speech_(Speech_Synthesis), but there is no such package in raspbian repo (No
libttspico-utils
, no
libttspico0
, but there is a
libttspico-data
). Anyone has the same problem?
doug
Fri Feb 21, 2014 11:02 am
Yggdrasil wrote:I've added a parameter for testts to select the used language, but do not want fork the project on Github. Feel free do add this :)
Thanks I'll add this in to the code in my git repo when I get a chance :-)
Doug
RamonV
Fri Feb 21, 2014 7:21 pm
positron wrote:Hello there everyone! I've tried to install pico from repository as descibed in http://elinux.org/RPi_Text_to_Speech_(Speech_Synthesis), but there is no such package in raspbian repo (No
libttspico-utils
, no
libttspico0
, but there is a
libttspico-data
It looks like the package got removed at some point, according to this link we have to build it ourselves (page 23 of the doc below)
http://www.mon-club-elec.fr/mes_downloa ... e_base.pdf
gkreidl
Fri Feb 21, 2014 10:12 pm
I checked it with Synaptic when this thread was opened and it was definitely there; now I can only find libttspico-data. Really strange ....
Minimal Kiosk Browser (kweb)
hippy
Fri Sep 12, 2014 10:50 pm
RamonV wrote:It looks like the package got removed at some point, according to this link we have to build it ourselves (page 23 of the doc below)
Just a note to say that I got it to compile and install following those instructions - Thanks for that link. The only tricky part was installing the *.deb packages at the end which needed to be in a different order, or I misunderstood the instructions.
Google TTS is of superb quality but does require an internet connection. I would rate pico as just bearably tolerable, espeak too robotic, festival even more robotic.
For anyone requiring TTS in an app, I would say it would be best to use Google or grab samples of words and phrases from Google and then string them together as needed.
DazzlingDukeOfLazers
Sat Feb 14, 2015 9:09 pm
It looks like there is a DMCA on:
More:
https://github.com/github/dmca/blob/mas ... -Mobile.md
Hopefully this can be rectified.
doug
Tue Feb 17, 2015 9:18 pm
DazzlingDukeOfLazers wrote:It looks like there is a DMCA on:
More:
The DMCA notice came as a bit of a surprise but I'm far from the only person to receive such as notice, I see CyanogenMod is in the same situation. I'm working on trying to rectify this but it will likely mean I cannot distribute the complete Android TTS engine to comply with this request.
Out of interest and to help with finding the best solution to the problem who here was using picopi? If so did you just use the library or did you use the command line tool as well?
snowblind
Sun Feb 22, 2015 11:31 pm
I had my github copy of your pico TTS code blocked also
I use the testtts command line in some scripts
mascal
Thu Feb 26, 2015 9:19 am
I succesfully compiled the repository sources for svox pico engine and it works quite well. I put all the steps (in english) in a post on my blog, just in case someone needs them:
http://rpihome.blogspot.com/2015/02/ins ... o-tts.html
Mascal
doug
Fri Feb 27, 2015 11:28 pm
Good news everyone, I might have my repository back online. I've removed the offending file (hopefully) and realised it wasn't essential to the project anyway. I think it was just part of the Java API interface which I hadn't integrated.
Hopefully the repository will now stay up but I'll have to wait and see if I've managed to comply correctly with the DMCA request.
obra
Thu Jun 25, 2015 6:53 pm
Hi Doug,
It seems that now that com_svox has been removed, the tts does not compile. I get the following error:
/pico/tts $ make
g++-4.6.real: error: com_svox_picottsengine.cpp: No such file or directory
Editing Makefile to remove reference to com_svox does not solve the problem, apparently this code is used elsewhere.
Any suggestions?
Thank you
