*average *nix knowledge but this is new ground for me.
I'm trying to monitor an ethernet switch which has an interface set to monitor and I'm having a few issues.
I have the r-pi stock ethernet adapter plugged into the switch so i can ssh into the pi, then a USB ethernet adapter plugged into my monitoring adaptor on the switch.
so: eth0 is ssh (assigned ip by router)
eth1 monitor.
i can start tcpdump which outputs a steady steam on eth0 but on eth1, outputs a few lines then quickly locks me out of ssh. When i try to dump the output to a file, eth0 will write fine but no data is written from eth1.
my ifconfig shows:
eth0 Link encap:Ethernet HWaddr b8:27:eb:a8:0f:ca
inet addr:192.168.1.72 Bcast:192.168.1.255 Mask:255.255.255.0
UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1
RX packets:1814 errors:0 dropped:0 overruns:0 frame:0
TX packets:172 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:1000
RX bytes:134168 (131.0 KiB) TX bytes:31730 (30.9 KiB)
eth1 Link encap:Ethernet HWaddr 00:e0:4c:53:44:58
RX packets:1516 errors:0 dropped:0 overruns:0 frame:0
TX packets:2 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:111072 (108.4 KiB) TX bytes:88 (88.0 B)
lo Link encap:Local Loopback
inet addr:127.0.0.1 Mask:255.0.0.0
UP LOOPBACK RUNNING MTU:65536 Metric:1
RX packets:0 errors:0 dropped:0 overruns:0 frame:0
TX packets:0 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:0
RX bytes:0 (0.0 B) TX bytes:0 (0.0 B)
This is from a fairly plain raspian with libpcap. raspian detected the usb ethernet adapter and i have not configured anything else.
Do i need to configure eth1 in anyway to listen to this port?
Many thanks sticking with me on this.!
