Sutty
Administrator Password
Tue May 29, 2012 10:23 am
I received my Pi on Friday and I'm having fun trying things out. I noticed that the SD card space is limited due to the image. When I tried to run Gparted to reallocate the partition I'm asked for the Administrator/Root password. Does anyone know what this is ???
markb
Re: Administrator Password
Tue May 29, 2012 12:39 pm
There is no administrator/root account in Debian, you need to use the sudo command. you can run gparted as root by opening a terminal window and typing:
sudo gparted.
Sutty
Tue May 29, 2012 4:12 pm
Thanks Mark, that worked fine, I've now plenty of space to work with!!
markb wrote:There is no administrator/root account in Debian, you need to use the sudo command. you can run gparted as root by opening a terminal window and typing:
sudo gparted.
Iteken
Tue May 29, 2012 5:08 pm
if you have loads to do and get bored of sudoing all the time, you can always do:
sudo su
Return to “Beginners”
