Hello.
So I have a Raspberry Pi running "2013-09-25-wheezy-raspbian". I have installed all the NFS bits and followed the guide. My HDD is formatted to NTFS and all the ntfs drivers are installed on my Raspberry Pi.
Now I know that the system works. I had a 8gb memory stick formatted in NTFS attached to a USB hub and I could stream the two movies and a few tv shows on the pc with XBMCBuntu and a Raspberry Pi with OPENelec on it. No problems. But when I swapped the USB Stick with a external 2.5 external HDD thats in a enclosure with USB 3 attached to the usb Hub. I mounted it and thats all fine.
Both XBMC machines can see the NFS. They can even set it up and download all the show information. But when I click on a movie or show both machines freeze then come up saying no remote connection. Some times I can watch a little bit of a show before it does the same thing. When I go back onto the Raspberry Pi NFS server the USB HDD under 'sudo fdisk -l" shows the the HDD has gone from /dev/sda1 to /dev/sdb1 etc. I then re-mount the device and it does the same thing over and over. But no errors come up on the screen.
Has anyone heard of this before? The reason I use NTFS is so that I can swap all my Movies from a PC in a different house.
The strangest part is when I used the usb Stick with NTFS format it worked like a dream. Only when swapping to a hard drive did it go wrong.
My HDD enclosure is this … http://www.novatech.co.uk/products/comp ... 3-gy..html "Novatech 2.5" Tool Free SATA HDD/SSD Enclosure USB 3.0"
I also Have a Novatech USB hub.
Any help is much appreciated.
