mogupyogu
Internet of Thing Printer
Mon Feb 03, 2014 8:59 pm
Hi Everyone,
I've recently purchased an "Internet of Things" - Raspberry Pi edition - from AdaFruit to experiment with and learn on. This isn't my first RPi but it is my first real foray into Python. I've been working on a piece of sample sample code that they include in order to help get you started using the device and I've hit a snag that I think should be very easy to fix. Unfortunately, my lack of experience with Python is keeping me from progressing past this spot and I was wondering if anyone here could help me out?
The sample code is for pulling updates from certain Twitter accounts and printing them on a miniature receipt printer. Everything with the printer is working fine. What I need help with is being able to pull more than one account's updates. Here's the sample code I'm working with:
# queryString can be any valid Twitter API search string, including
# boolean operators. See http://dev.twitter.com/docs/using-search
# for options and syntax. Funny characters do NOT need to be URL
# encoded here -- urllib takes care of that.
queryString = 'from:TheTweetOfGod'
I've gone thru the website listed in the comments but I'm still not able to figure out how to add more than one account. Basically, "TheTweetOfGod" is the only one I can view unless I change it to something else. I want to be able to add several. I've tried using things like:
queryString = 'from:TheOnion'
queryString = 'from:TFLN'
But the only one that prints is the last one. I've tried adding boolean operators like queryString = 'from:TheTweetOfGod'ORqueryString = 'from:TheOnion'OR....etc
But then I get errors regarding the syntax.
I know this is pretty first-rate stuff and I'm missing something very simple. If anyone can point me in the right direction I would really appreciate it.
Thank you.
paddyg
Re: Internet of Thing Printer
Mon Feb 03, 2014 11:37 pm
I don't really have a clue about the working details of what you are trying to do but the example you give will jettison whatever was in queryString and replace it with the new tweet. To get a list of strings you would need to do something like
queryStrings = []
sources = ['TheTweetOfGod', 'TheOnion', 'TFLN',... etc ]
for source in sources:
  queryStrings.append('from:' + source)
queryStrings will then be a list that you can iterate through as I do with sources above. Hope that helps
also https://groups.google.com/forum/?hl=en-GB&fromgroups=#!forum/pi3d
mogupyogu
Mon Feb 03, 2014 11:43 pm
AH! That makes SO much sense! Thank you so much for your response, paddyg. I've been fighting with this for days and you're the first person to give me something I can actually use. Again, thank you for your help. This has been driving me crazy! :lol:
Mon Feb 03, 2014 11:45 pm
Before you go anywhere update your code
https://github.com/adafruit/Python-Thermal-Printer
Twitter changed their API so that you MUST use https (http with ssl) for any interaction with twitter. (That broke my perl code when they implemented that without warning, it also broke @Big_Ben_Clock.)
mogupyogu
Mon Feb 03, 2014 11:56 pm
Thanks for the heads up, Dougie. I actually pulled my code from GitHub when I first set this up. It should be the most current but I'll definitely check it and make sure. I was actually following your post regarding "main.py" on the adafruit forums. Without knowing, you actually pointed me in the right direction for a lot of the issues I was experiencing early on.
mogupyogu
Tue Feb 04, 2014 12:24 am
I think I'm still missing something. When using
queryStrings = []
sources = ['TheTweetOfGod', 'TheOnion', 'TFLN' ]
I get an error:
File "twitter.py", line 50, in <module>
queryStrings.append('from:' + sources)
TypeError: cannot concatenate 'str' and 'list' objects
I'm really sorry for my ignorance here. It seems like the code is right. Is it because the indentation is wrong? I know Python is really picky about that.
elParaguayo
Tue Feb 04, 2014 8:18 am
The error message suggests your actual code is not the same as you've posted here. It says you're trying to append "sources" (which is the original list) rather than "source" which is the individual items in the list that you're looping through.
Just check your actual code again and you should be fine. Ie make sure the code says
and not
RPi Information Screen: plugin based system for displaying weather, travel information, football scores etc.
paddyg
Tue Feb 04, 2014 9:33 am
My poor choice of variables! It's a good example of how to confuse yourself and why thinking of appropriate names is worthwhile. Also it's probably worth getting used to the format method (python's equivalent to sprintf) for assembling strings,.
for s in sources:
  queryString.append("from:{}".format(s))
Return to “Python”
