Loonhaunt
Unzipping tar.gz files
Sat Feb 01, 2014 9:41 pm
Hello I am trying to unzip a downloaded file ftdi_sio.tar.gz
I have used these option that I got from a comment somewhere:
tar xvf ftdi_sio.tar.gz
tar ftdi_sio.tar.gz
tar xvzf ftdi_sio.tar.gz
return"tar: Child returned status 1
tar: error isn not recoverable: exiting now"
Thanks much, pretty new to linux and command line file operation
Dave
DeeJay
Re: Unzipping tar.gz files
Sat Feb 01, 2014 10:05 pm
Looking at http://www.ftdichip.com/Drivers/VCP.htm, there does not seem to be a driver for the ARM architecture in the RPi. Are you sure the driver you are trying to install is appropriate for your operating system?
If you are determined to proceed, try using gunzip to unpack the .gz archive, and then tar to extract the files from the resulting tar file.
Loonhaunt
Sun Feb 02, 2014 2:46 am
Hmm.
If that is the case what does one use to control an ftdi(the lack of ARM) chip with the raspberry pi and consequently talk to an xBee?
sdjf
Sun Feb 02, 2014 6:18 am
Cannot answer your question about controlling that device but, just for the record, if you want to unzip a gzip file, you would use gunzip.
gunzip filename.gz
and if it is a tar.gz file, I do it the long way instead of getting fancy with options:
gunzip filename.tar.gz
tar xvf filename.tar
FORUM TIP: To view someone's posting history, sign in, click on their user name, then on "Search User's Posts." || Running ArchLinuxArm on Model 2B and 512MB Model B
Sun Feb 02, 2014 7:23 am
If you are using Raspbian, the ftdi_sio driver is already installed. It is a module called (not surprisingly) ftdi_sio.ko
It should get automatically loaded when you plug the device in to the USB port.
In Linux most (but not all) of the drivers you will need are either built in to the kernel or available as modules which will either be automatically loaded when the device is detected or have to be told to be loaded.
It has been a long time since I've needed to install any other drivers and in that case it was a case of downloading source, making a few tweaks for the unusual device I was using (PCMCIA floppy drive), compiling and installing.
Sun Feb 02, 2014 9:14 pm
Why not use the simple options
If it's tar.bz2 then use tar -xjvf filename.tar.bz2
If it's tar.gz then use tar -xzvf filename.tar.gz
if it's tgz then use tar -xzvf filename.tgz
In each case tar runs the appropriate unzip program and pipes the output into tar.
-x means extract
-v mean list things as they're untarred (can be a bit noisy on a large tarball).
-f gives the filename for input
This is a doctor free zone.
Loonhaunt
Sun Feb 02, 2014 9:30 pm
So I did everyone of those letter for letter and each one returned a different error message. With that I am guessing the something did not work with the download. However if I just unzip the file using the file manager in startx I can see the four files and they have mass so I don't know what could be missing.
DB
DougieLawson wrote:Why not use the simple options
-x means extract
gkreidl
Sun Feb 02, 2014 10:07 pm
Loonhaunt wrote:So I did everyone of those letter for letter and each one returned a different error message. With that I am guessing the something did not work with the download. However if I just unzip the file using the file manager in startx I can see the four files and they have mass so I don't know what could be missing.
If your own quote was right, you didn't have the "-" in front of the options string.
Minimal Kiosk Browser (kweb)
Loonhaunt
Sun Feb 02, 2014 10:36 pm
Yes but did the whole run of experiments over again with the - . Still got the same results.
Dave
jojopi
Sun Feb 02, 2014 11:37 pm
The "-" is optional for tar options. (More correctly, either the standard option syntax or the historic bundled form are accepted. In bundled form, all the characters of the first argument are options, and all the values for the options come in later arguments. In option form, options can come anywhere, but values must immediately follow their options. So "tar fx file.tar" works, whereas "tar -fx file.tar" mistakes "x" as the filename for "-f".)
The error message in the original post is incomplete, but most likely the file was not downloaded correctly. The only other reason for the third command to fail is if gzip is broken on the system.
DougieLawson wrote:If it's tar.bz2 then use tar -xjvf filename.tar.bz2
In recent versions you can use "tar -xavf" to autodetect the compression based on the extension. This avoids the need to remember that there is also -J for .xz and -Z for .Z, and several others.
Sun Feb 02, 2014 11:40 pm
jojopi wrote:In recent versions you can use "tar -xavf" to autodetect the compression based on the extension. This avoids the need to remember that there is also -J for .xz and -Z for .Z, and several others.
Thanks for sharing that. I now have to retrain my fingers to type an 'a' where a 'j', 'J', 'z' or 'Z' belongs.
Loonhaunt
Mon Feb 03, 2014 1:53 am
jojopi wrote:The "-" is optional for tar options. (More correctly, either the standard option syntax or the historic bundled form are accepted. In bundled form, all the characters of the first argument are options, and all the values for the options come in later arguments. In option form, options can come anywhere, but values must immediately follow their options. So "tar fx file.tar" works, whereas "tar -fx file.tar" mistakes "x" as the filename for "-f".)
My suspicion is that the download did not go well.
ShiftPlusOne
Mon Feb 03, 2014 5:24 am
Strange, I've been using
tar xvf file
for a very long time for any archived tar file without specifying any additional flags without any problems.
Loonhaunt
Mon Feb 03, 2014 1:47 pm
I have to try that one. I will report back later.
jojopi
Mon Feb 03, 2014 3:22 pm
ShiftPlusOne wrote:tar xvf file
Oh wow! That behaviour is fully documented and actually predates --auto-compress.
So you only need -a when creating archives, and you only need -z -j -J when dealing with pipes.
