Some users have found the Raspbian image created by Hexxeh to be a little too minimal. To help these user I went ahead and created a larger, less minimal image that can be found at the following page on the Wiki:
http://www.raspbian.org/PiscesImages
Please note, this image must be installed on a 4GB or larger SD card.
This image was created using the Debian installer discussed in another thread in this forum. Therefore, this image of Raspbian is what the Debian installer builds as a minimal system with the LXDE and compiler packages added to it. Users should find this image contains more of the common applications that most users might expect to find on a Linux system.
This is my first attempt at an image so please bear with me if there are some issues with it. Check back on the wiki page for any new notes added about the image as more people test it out and use it. If needed, I can fix significant problems and update the image on the server.
Good luck, and let me know how it goes.
I didn't have luck setting up a torrent. If someone can seed a torrent and send me a link, I'll post the link to the .torrrent URL in the wiki page.
Mike
