Viper1953
rc.local only loading 1 script on boot
Fri Jan 31, 2014 2:47 pm
Hi Guys,
I have two scripts in my rc.local file that are virtually identical (but pin numbers different etc). Only one is loading on startup though.
Here is the one that DOES load:
# Import the modules to send commands to the system and access GPIO pins
from subprocess import call
import RPi.GPIO as gpio
# Define a function to keep script running
def loop():
    raw_input()
# Define a function to run when an interrupt is called
def shutdown(pin):
    call('halt', shell=False)
gpio.setmode(gpio.BOARD) # Set pin numbering to board numbering
gpio.setup(7, gpio.IN) # Set up pin 7 as an input
gpio.add_event_detect(7, gpio.RISING, callback=shutdown, bouncetime=200) # Set up an interrupt to look for button presses
loop() # Run the loop function to keep script running
and here is the one that DOES NOT load:
import RPi.GPIO as GPIO
def loop():
    raw_input()
def LEDON(pin):
	GPIO.output(25, True)
GPIO.setmode(GPIO.BCM) #Set pin numbering to GPIO numbering
GPIO.setup(24, GPIO.IN) # Set up GPIO 24 as an input (button)
GPIO.setup(25, GPIO.OUT) # Set GPIO 25 as an output (LED)
GPIO.output(25, False)
GPIO.add_event_detect(24, GPIO.RISING, callback=LEDON, bouncetime=200)
And just to confirm, this is my rc.local entry:
fi
python /home/pi/scripts/PiSupply/softshut.py
python /home/pi/scripts/button/button.py
exit 0
Softshut.py is the one that DOES load.
Any help greatly appreciated!!
elParaguayo
Re: rc.local only loading 1 script on boot
Fri Jan 31, 2014 3:22 pm
Just a guess: If softshut is running a loop then it will never exit, so I don't think the next line of your rc.local file will execute.
Have you tried adding a " &" at the end of the line to send the process to the background e.g.
fi
python /home/pi/scripts/PiSupply/softshut.py &
python /home/pi/scripts/button/button.py &
exit 0
RPi Information Screen: plugin based system for displaying weather, travel information, football scores etc.
Viper1953
Fri Jan 31, 2014 5:40 pm
Yep, just tried that and unfortunately it didn't make a jot of difference!
Fri Jan 31, 2014 5:43 pm
Stop using /etc/rc.local
Create two scripts in /etc/init.d to get those two long running server processes running (there's a skeleton script /etc/init.d/skeleton).
Use update-rc.d to make them active and run at boot time
It's normal practice to move the scripts being started that way to /usr/local/bin
jojopi
Fri Jan 31, 2014 6:47 pm
You definitely need the background "&"s. Otherwise if the scripts do not exit, the rest of the boot sequence will be delayed indefinitely. (This is one reason that rc.local may be better than init.d/*, for beginners. It is always the very last script to run before starting console logins, so a mistake will not break SSH access.)
Both of the programs appear to use raw_input() as a blocking mechanism. That will not work when started at boot, because standard input is /dev/null, which returns an immediate end of file. Boot scripts are not supposed to expect keyboard interaction. Alternative methods of keeping the programs running, without wasting CPU time, include:
def loop():
    import signal
    while True:
        signal.pause()
def loop():
    import time
    while True:
        time.sleep(60)
Fri Jan 31, 2014 6:58 pm
If you set-up the headers in your /etc/init.d/ script you can ensure that it starts after networking and sshd are alive.
Viper1953
Fri Jan 31, 2014 8:22 pm
DougieLawson wrote:If you set-up the headers in your /etc/init.d/ script you can ensure that it starts after networking and sshd are alive.
Thanks for the info Dougie, while it is much appreciated its a little too advanced for me at the moment. I did take a look at the skeleton script and it just confused me even more!
jojopi wrote:You definitely need the background "&"s. Otherwise if the scripts do not exit, the rest of the boot sequence will be delayed indefinitely. (This is one reason that rc.local may be better than init.d/*, for beginners. It is always the very last script to run before starting console logins, so a mistake will not break SSH access.)
def loop():
    import signal
    while True:
        signal.pause()
def loop():
    import time
    while True:
        time.sleep(60)
This has worked brilliantly. I used the first option, combined with the "&"s and its now fully functioning.
Many thanks for your help and input.
Return to “Python”
