YOSTIE
Change name of USB automount
Tue Jan 28, 2014 10:36 pm
Hi guys,
Just looking for a little help if possible. When I plug my external HD into the Pi running the latest version of Raspbian, the OS automounts the hard drive to /media/Seagate Expansion Drive. I am trying to change the name of the automount from "Seagate Expansion Drive" to something shorter like "ExternalHD", but have been unable to work out how to do it. Any help would be greatly appreciated.
Re: Change name of USB automount
Wed Jan 29, 2014 12:23 am
What's the volume label?
YOSTIE
Wed Jan 29, 2014 12:32 am
DougieLawson wrote:What's the volume label?
I'm not at home at the moment, but I believe it was /dev/sda1
Wed Jan 29, 2014 12:34 am
No. That's the device name.
Look at the device with
sudo fdisk -l /dev/sda1
Gogitow
Sat Sep 17, 2016 5:33 pm
I have the same issue. Nobody seems to have the information. They want to tell you how to mount usb drives but will not tell you how to change the drive label on an drive that already mounts. I'm starting to think that nobody knows because otherwise why not just post the information?
FTrevorGowen
Sat Sep 17, 2016 7:54 pm
Gogitow wrote:I have the same issue. Nobody seems to have the information. They want to tell you how to mount usb drives but will not tell you how to change the drive label on an drive that already mounts. I'm starting to think that nobody knows because otherwise why not just post the information?
In part it depends upon what you mean by "automount" ie. automount at boot time or, if you're booting into the graphical desktop automount with/when you have opened the GUI file manager. The first is, perhaps, best dealt with by an entry in fstab**, the second, as indicated by @DougieLawson, by giving the drive a label either when it's initially formatted or, IIRC, changing/adding one using something like gparted.
Trev.
** Something like the, perhaps, "old fashioned approach" here:
https://www.cpmspectrepi.uk/raspberry_p ... ticks.html
Still running Raspbian Jessie or Stretch on some older Pi's (an A, B1, 2xB2, B+, P2B, 3xP0, P0W, 2xP3A+, P3B, B+, and a A+) but Buster on the P3B+, P4B's & P400. See: https://www.cpmspectrepi.uk/raspberry_pi/raspiidx.htm
Paeryn
Sat Sep 17, 2016 8:00 pm
People do know, I've given the info out on here before (only a month or two ago). The desktop automounter uses the partition label if it has one.
If the filesystem is ext2/3/4
sudo e2label /dev/sda1 MyNewLabel
If it's fat
sudo dosfslabel /dev/sda1 MyNewLabel
Replace /dev/sda1 with the actual device name of the partition.
If dosfslabel isn't installed it can be installed with
sudo apt-get install dosfstools
Please note that my name doesn't start with the @ character so can people please stop writing it as if it does!
Return to “Raspberry Pi OS”
