sudo pip install pilCode: Select all
copying PIL/ImageGL.py -> build/lib.linux-armv6l-2.7
copying PIL/BufrStubImagePlugin.py -> build/lib.linux-armv6l-2.7
running build_ext
building '_imaging' extension
creating build/temp.linux-armv6l-2.7
creating build/temp.linux-armv6l-2.7/libImaging
gcc -pthread -fno-strict-aliasing -DNDEBUG -g -fwrapv -O2 -Wall -Wstrict-prototypes -fPIC -IlibImaging -I/usr/include -I/usr/local/include -I/usr/include/python2.7 -c _imaging.c -o build/temp.linux-armv6l-2.7/_imaging.o
_imaging.c:75:20: fatal error: Python.h: No such file or directory
compilation terminated.
error: command 'gcc' failed with exit status 1
Cleaning up...
Command /usr/bin/python -c "import setuptools;__file__='/tmp/pip_build_root/pil/setup.py';exec(compile(open(__file__).read().replace('\r\n', '\n'), __file__, 'exec'))" install --record /tmp/pip-5mFH3b-record/install-record.txt --single-version-externally-managed failed with error code 1 in /tmp/pip_build_root/pil
Storing complete log in /root/.pip/pip.log
