szymon1051
HUB USB 3.0 don't work, how fix?
Mon Jan 20, 2014 4:31 pm
I have praspberr pi b and use raspbian.
Hub ORICO A3H10.
sdjf
Re: HUB USB 3.0 don't work, how fix?
Mon Jan 20, 2014 11:12 pm
Do you also have a USB 2.0 hub in the house? I have read posts in the forum where people plugged the 2.0 Hubs into their pi and then plugged their 3.0 hubs or devices into the 2.0 hubs and they they worked. At least I think that is what I read. ;o) Would not hurt to try it.
Another thing that might be your problem is if the Hub is drawing too much power from the Pi, is it a powered hub? You really need one if you want to connect much to the Pi over Usb.
FORUM TIP: To view someone's posting history, sign in, click on their user name, then on "Search User's Posts." || Running ArchLinuxArm on Model 2B and 512MB Model B
szymon1051
Tue Jan 21, 2014 11:24 am
sdjf wrote: Another thing that might be your problem is if the Hub is drawing too much power from the Pi, is it a powered hub? You really need one if you want to connect much to the Pi over Usb.
Hub have own power.
sdjf wrote:Do you also have a USB 2.0 hub in the house? I have read posts in the forum where people plugged the 2.0 Hubs into their pi and then plugged their 3.0 hubs or devices into the 2.0 hubs and they they worked. At least I think that is what I read. ;o) Would not hurt to try it.
I try add hub 3.0 (with own power) to hub 2.0 (with own power) and to pi, but still don't work.
Jessie
Tue Jan 21, 2014 5:18 pm
Have you tried the hub on a PC to make sure it works?
szymon1051
Tue Jan 21, 2014 9:17 pm
Jessie wrote:Have you tried the hub on a PC to make sure it works?
Yes.
vallieres
Mon May 05, 2014 1:53 pm
Have you guys managed to make it work? I also have a USB 3.0 hub, the Orico H10-U3 and I can't get it to work with my Raspberry Pi... :(
jdb
Mon May 05, 2014 5:32 pm
Rockets are loud.
https://astro-pi.org
vallieres
Tue May 06, 2014 5:04 pm
Actually, with the dwc_otg.speed=1 change in cmdline.txt it works :)
