spwx
hdmi_drive=2 changes colors
Sat Jan 18, 2014 5:37 pm
Hello, I am trying to get sound to work on my TV. I have two HDMI inputs labled:
HDMI 1 (DVI)
HDMI 2 (ARC)
I've tried both and can only get sound to work when adding "hdmi_drive=2" to the /boot/config.txt file.
On reboot boot i can get sound to work however it really fades the colors on the screen. Is there anyway to get both audio and vibrant color at the same time?
Thank you!
spwx
Re: hdmi_drive=2 changes colors
Sat Jan 18, 2014 5:50 pm
Also is there a way to force the raspberry pi to tell me what hdmi_mode and hdmi_group it is auto detecting?
Thank you!
Sat Jan 18, 2014 5:53 pm
rpdom
Sat Jan 18, 2014 7:12 pm
The "tvservice -s" command will show the current video type, group and mode.
Example on my main Pi
rpdom@raspi:~$ tvservice -s
state 0x120016 [DVI DMT (35) RGB full 5:4], 1280x1024 @ 60Hz, progressive
So you can see I'm running group DMT (into a DVI-D monitor) and mode 35.
spwx
Sun Jan 19, 2014 6:28 am
Thanks a lot guys! I learned a lot.
Basically i just tried a bunch of different hdmi_modes. They all had the same problem.
Whenever i set hdmi_drive=2 the colors at the terminal are faded.
Burngate
Sun Jan 19, 2014 10:41 am
HDMI is confusing, isn't it? Not least because TV manufacturers have their own ideas about what you should be wanting.
It sounds like the Pi is sending one of the "limited" encodings, while the TV is expecting "full"
spwx
Sun Jan 19, 2014 5:25 pm
Thanks for the help, but no luck with those either. I tried all five.
I can't quite tell but it looks like only my terminal colors are being effected and X windows is fine. For now ill just set hdmi_drive=1 and use a head set for sound.
