livefornow
4K Digital Photoframe - possible?
Fri Jan 17, 2014 6:35 pm
I have just received my Raspberry Pi and have created a digital photo frame that authenticates with Flickr and downloads pictures tagged with photoframe from my private account. I have it running nicely on my regular 1080p television.
My intention would be to ultimately buy this 4K television so I can see the photographs more beautifully.
http://www.amazon.com/Seiki-Digital-SE3 ... B00DOPGO2G
Is there anyway I can get Raspberry Pi to support 4K or is 1080P the maximum?
LFN
AndyD
Re: 4K Digital Photoframe - possible?
Fri Jan 17, 2014 8:39 pm
Jessie
Sat Jan 18, 2014 6:07 am
The current crop of 4k displays require two HDMI cables or one display port cable. In both cases they are detected as two separate displays. Since the R Pi does not have two physical HDMI ports or a Display Port it would be incompatible with a 4K display. Until a device comes out with a HDMI 2.0 port 4k displays will continue to require two HDMI cables because there isn't enough bandwidth avalible.
Aydan
Sat Jan 18, 2014 12:52 pm
Jessie wrote:The current crop of 4k displays require two HDMI cables or one display port cable. In both cases they are detected as two separate displays. Since the R Pi does not have two physical HDMI ports or a Display Port it would be incompatible with a 4K display. Until a device comes out with a HDMI 2.0 port 4k displays will continue to require two HDMI cables because there isn't enough bandwidth avalible.
If the display is detected as two independend half-monitors then you culd probably use two raspis, each serves half the image.
Regards
Aydan
Jessie
Sat Jan 18, 2014 5:33 pm
Regards
Aydan
Good point. All you would need to do is get the two independant RPi to display their half of the image.
monergy342
Sat May 24, 2014 12:34 pm
Has anyone tried to play 4k using 2 Raspberies? I'm a bit confused how to even attempt to play half of the content from each raspberry... how do you sync them both?
Aydan
Sat May 24, 2014 9:04 pm
monergy342 wrote:Has anyone tried to play 4k using 2 Raspberies? I'm a bit confused how to even attempt to play half of the content from each raspberry... how do you sync them both?
Syncing video over multiple raspberries has been done. There was a blog post on the raspberry blog about this some time ago. They managed to create a single, synchronous video capable display from arbitrarily positioned displays.
But decoding 4k content will most likely be impossible because as far as I know, the hardware decoder on the GPU only supports up to 1920x1080.
Regards
Aydan
ghans
Sun May 25, 2014 7:03 am
GTR2Fan
Sun May 25, 2014 7:26 am
livefornow wrote:My intention would be to ultimately buy this 4K television so I can see the photographs more beautifully.
You might want to read through some of the buyer reviews before committing to purchasing that TV. There's a lot more to good image reproduction than resolution alone. From what some of the reviewers are saying when comparing it to any half-decent Full-HD TV, its overall picture quality leaves a lot to be desired.
Pi2B Mini-PC/Media Centre: ARM=1GHz (+3), Core=500MHz, v3d=500MHz, h264=333MHz, RAM=DDR2-1200 (+6/+4/+4+schmoo). Sandisk Ultra HC-I 32GB microSD card on '50=100' OCed slot (42MB/s read) running Raspbian/KODI16, Seagate 3.5" 1.5TB HDD mass storage.
ame
Sun May 25, 2014 9:09 am
I watch movies on a 640x480 35 lumen pico projector. It's awesome and I can chuck it in my pocket. I can not contemplate owning a 4k TV and figuring out how to move it from place to place.
elatllat
Mon Aug 11, 2014 4:54 pm
Jessie wrote: (18 Jan 2014 06:07) The current crop of 4k displays require two HDMI cables or one display port cable. In both cases they are detected as two separate displays. Since the R Pi does not have two physical HDMI ports or a Display Port it would be incompatible with a 4K display. Until a device comes out with a HDMI 2.0 port 4k displays will continue to require two HDMI cables because there isn't enough bandwidth avalible.
That information was outdated 5 years before it was posted.
http://en.wikipedia.org/wiki/HDMI#Version_1.4
The $350 Seiki SE39UY04 will do 4k over HDMI 1.4.
raspberrypi using 4k:
http://www.raspberrypi.org/forums/viewt ... 38&t=79330
SBC with 32GB RAM: https://hardkernel.com
FAQ : https://raspberrypi.stackexchange.com
Unanswered: https://www.raspberrypi.org/forums/search.php?search_id=unanswered
Jessie
Mon Aug 11, 2014 5:32 pm
You are also reserecting a couple month old thread. I am aware that people have gotten 4k @ decent refreshes through overclocking the pixel clock. I'm not going to go through old posts to correct myself.
Thanks for the link to HDMI 1.4 the Pi is a 1.3a device.
