Greatalastor3
sudo nano /etc/dhcp/dhcpd.conf brings up empty file
Wed Jan 15, 2014 5:29 am
sudo nano /etc/dhcp/dhcpd.conf brings up empty file with no script
im attempting to set up a tor router by following these 2 tutorials but with little success
http://makezine.com/projects/make-36-bo ... -onion-pi/
http://learn.adafruit.com/downloads/pdf ... -point.pdf
i dont know if its also related to this but another problem im having is that each time i power up the pi it boots to setup config and i end having to enter my settings each start up.
KStatefan
Re: sudo nano /etc/dhcp/dhcpd.conf brings up empty file
Fri Feb 05, 2016 12:37 am
I am having the same problem.
Fri Feb 05, 2016 10:45 am
If it's Raspbian Jessie that you're running the file is /etc/dhcpcd.conf it's not in the /etc/dhcp sub-directory.
KStatefan
Fri Feb 05, 2016 2:34 pm
I am using Raspbian Wheezy May 2015 version
Fri Feb 05, 2016 3:49 pm
KStatefan wrote:I am using Raspbian Wheezy May 2015 version
Then either upgrade to Jessie or do it the old way. Wheezy has static addresses in /etc/network/interfaces and still uses isc-dhcp-client rather than dhcpcd.
ripat
Fri Feb 05, 2016 8:30 pm
If it is a router that you want to setup, may be you are after a dhcp *server* and not the dhcpcd *client* daemon. If that is the case, install either isc-dhcp-server or dnsmasq. For the first one, after installing it, you should have a default configuration in the /etc/dhcp/dhcpd.conf file.
Using Linux command line usually boils down to these three things:
#1) Respect the privacy of others.
#2) Think before you type.
#3) With great power comes great responsibility.
ripat
Sat Feb 06, 2016 11:16 am
Is isc-dhcp-server correctly installed?
$ dpkg -l isc-dhcp-server
If properly installed, you should have a default /etc/dhcp/dhcpd.conf file which is the configuration file for the -isc-dhcp-server package.
What settings do you need to enter after boot?
