linuxfox69 wrote:Bonjour ,
Depuis hier j'essaye de configurer ma clef wifi ( TP-Link TL-WN725N Nano ) sur XBMC pourtant recommander comme étant compatible avec le raspberry pi.
J'ai d'abord brancher la clef avec le câble ethernet pour télécharger et configurer l'extension Network-Manager mais au moment de faire les réglages il n'y a aucune options présentent ( du moins pas celle permettant a detection automatique ).
J'ai aussi essayé de régler les options manuellement dans opelelec settings en mettant wlan , ssid et mot de passe mais rien n'y fait ...
try this
Download Your Free 60-Page eBook on 5 Steps to a Successful Home Theater PC Project. Click here
Close
Open
My Media Experience
Facebook1,417 Fans Like
Twitter2,315 Followers Follow
Feed9,442 Subscribers Subscribe
Home
Start Here
HTPC eBook
Reference Builds
Hardware Guides
Software Guides
3 Easy Steps to Install OpenELEC with WiFi on Raspberry Pi
How to Set Up unRAID NAS Software with Plex Media Server and Tvheadend This Is What I Learned from My 2012 HTPC Project
Posted By Tuukka
Aug 2nd, 2012
About the author
about me
Hi! I’m Tuukka. I’m a 33 year old technology enthusiast who has over 13 years experience on building HTPCs. Here's my quick story.
Join over 14,000 followers!
New?
Start Here
Free eBook
DIY HTPC
HTPC Builds
for 2014
Most Popular in Past 7 Days
The Only Raspberry Pi XBMC Tutorial You Will Ever Need2,348 views
How to Customize XBMC 12 Frodo with All the Bells and Whistles1,803 views
List of the Best XBMC Addons1,622 views
8 Things I Wish I Knew Before Building My First HTPC1,556 views
How to Set Up XBMC on Android Based Ouya the Right Way1,502 views
5 Awesome XBMC Skins Plus One Bonus Tip1,323 views
Home » Hardware » Raspberry Pi » 3 Easy Steps to Install OpenELEC with WiFi on Raspberry Pi
Further to my comprehensive Raspberry Pi XBMC guide, this tutorial will show you how to install Raspberry Pi OpenELEC distribution and configure wireless USB WiFi adapter in 3 easy steps.
Many people have been struggling to get a wireless adapter working with their Raspberry Pi. Thanks to OpenELEC Operating System, it is now quite easy to configure WLAN inside XBMC.
The installation procedure with Linux is a bit more advanced compared to the Raspbmc installation with Windows, so if you are not familiar with Linux or using a command line to install software, I would suggest trying the Raspbmc first.
There are also instructions available to install OpenELEC with Windows at the Squirrel Hosting Blog. However, you still need to complete the step 3 in this guide to get the wireless connection working.
Do you already have the Raspberry Pi and required accessories? If not, I have created a resource page where you can easily find the tested and proven components.
So, let’s get started…
Step 1: Install a Linux distribution to a USB drive
If you don’t have a computer with Linux Operating System, start with this step. If you already have Linux, you can jump directly to step 2.
•Get a universal USB installer here.
•Launch the universal USB installer and select Xubuntu Desktop Linux distribution from the drop down list and tick download ISO.
•After the download is finished, browse to the file and select the xubuntu ISO.
•Select your USB drive letter and start creating the image.
•Reboot the computer and make sure that the booting order is USB drive first (you can change this from the BIOS settings).
•Select run Xubuntu directly from USB.
Step 2: Download & Install OpenELEC on Raspberry Pi
The latest sources for the Raspberry Pi OpenELEC images are archived here, where you can check the version number.
•After the Xubuntu has started, go to Menu > Accessories > Terminal Emulator.
•In the terminal application, type “sudo bash”.
•Type “cd Downloads” and download the latest version by typing “wget
http://sources.openelec.tv/tmp/image/op ... 91.tar.bz2″.
•Then extract the file by typing “tar xvf OpenELEC-RPi.arm-devel-20120729151944-r11691.tar.bz2″
•Go to extracted folder at Downloads/OpenELEC-RPi.arm-devel-20120729151944-r11691.
•Next, check which mount is the SD card reader. You can check this e.g. with GParted application located at Menu > System > GParted. In my case, it was /dev/sdd.
•Now, type “sudo ./create_sdcard /dev/sdd”(where /dev/sdd is the device you looked up with GParted).
Installation is finished, so unplug your SD card and place it in your Raspberry Pi.
Connect the HDMI cable, plug in the ethernet cable, WiFi USB adapter and USB keyboard/remote and power it on.
Step 3: Configure WiFi Settings in OpenELEC
•Let’s configure the WiFi connection. I’m using Asus USB-N10 wireless adapter which seem to work fine.
Please note that your wireless SSID name should not be hidden or include empty spaces.
•Once the Raspberry Pi has booted up, go to Programs > OpenELEC OS Settings and select Network tab.
•In the Network tab, set the Network Technology as WLAN, Network Interface as wlan0 and WLAN SSID as your network’s name.
•Scroll down a bit and set WLAN security and WLAN Passphrase according to your home network’s settings.
•Click OK and reboot the system.
That’s it, now you have successfully installed OpenELEC with WiFi connection.
What’s Next
Fine-tune your Raspberry Pi OpenELEC experience with these XBMC customization tips that will help you to set things up properly with the right skin and settings.
Learn anything? Please share!
Get free updates! (plus a bonus eBook)
Join over 8,000 people who receive exclusive weekly media center building tips, and get a FREE COPY of my eBook! Learn more...
Email:
No Spam, Guaranteed
Home
About
Contact
Join Us
Privacy Policy
Author
Copyright © 2009-2014 My Media Experience
Close
Open
My Media Experience
Home
Start Here
HTPC eBook
Reference Builds
Hardware Guides
Software Guides
Posted By Tuukka
Aug 2nd, 2012
About the author
about me
New?
Start Here
Free eBook
DIY HTPC
HTPC Builds
for 2014
What’s Next
Email:
No Spam, Guaranteed
Home
About
Contact
Join Us
Privacy Policy
Author
