simplesi
Re: A new Scratch; pre-alpha-this-will-hurt release
Sat Apr 19, 2014 9:15 pm
I'll start testing it out for #ScratchGPIO compatibility and working over VNC
Simon
Seeking help with Scratch and I/O stuff for Primary age children
http://cymplecy.wordpress.com/ @cymplecy on twitter
simplesi
Sun Apr 20, 2014 8:21 am
Just tried to download NuScratch5.tgz but link doesn't seem to work
Simon
timrowledge
Mon Apr 21, 2014 6:45 pm
simplesi wrote:Just tried to download NuScratch5.tgz but link doesn't seem to work
Simon
Sorry about that; I've been moving away from dropbox, try -
https://copy.com/F01OLiWrf4GCP6Kf
Making Smalltalk on ARM since 1986; making your Scratch better since 2012
ghp
Fri May 09, 2014 4:03 pm
I looked for a nice feature in scratch: animated gifs. It Works in win-1.4 and legacy-1.4: import costume, it will load each frame as a separate costume then.
Unfortunately, it does not work with nuscratch5-1.4: the import first runs on a breakpoint (ok, it is beta) and then after selecting the file it simply does nothing.
See a working sample in http://wiki.scratch.mit.edu/w/images/Popular_GIF.gif
Instructions in http://wiki.scratch.mit.edu/wiki/Animated_GIF
Regards,
Gerhard
timrowledge
Sat May 10, 2014 10:19 pm
ghp wrote:Hello,
Hah! Oddly enough I just dealt with that a couple of weeks ago; it's in the upcoming beta release. Which is being kept back while we try to get a handle on the sound lock-up problem. Which looks like a possible kernel fix is needed, since apparently there is some clash between the timer interrupt I'm using and some other important vector that ... whatever.
simplesi
Sun May 11, 2014 4:30 pm
Just tested NuScratch5 for compatibility wit ScratchGPIO and it seems fine - sends out broadcasts and variable changes and receives sensor updates from Python :)
Simon
PS Any reason for font change from standard 1.4? Obviously makes it easy to see what version is being used but on the other hand it makes it look strange/different and that might not be best idea for young scratchers moving between PC/Mac/Pi
Simon
timrowledge
Sun May 11, 2014 5:29 pm
simplesi wrote:Just tested NuScratch5 for compatibility wit ScratchGPIO and it seems fine - sends out broadcasts and variable changes and receives sensor updates from Python :)
Excellent. Thanks for testing it out.
simplesi wrote:PS Any reason for font change from standard 1.4?
Yup. The deeply technical and important one of "I didn't get around to doing anything about it." I've done something about it for the beta release. Which should be out soon... if the sound nonsense can be solved.
timrowledge
Mon May 26, 2014 4:19 pm
timrowledge wrote:I've done something about it for the beta release. Which should be out soon... if the sound nonsense can be solved.
... and the beta release is now official. I had to fiddle with the VM a bit to avoid using a timer interrupt that ALSA also uses and uses incorrectly. Fortunately the current Raspbian kernel allows thread priority munging and so the alternative timer handling regime was practical. The upshot is that sound no longer seems to cause any lockups, which is nice.
We should consider this forum thread locked though and move to a new one for the Beta release(s).
simplesi
Tue May 27, 2014 5:19 pm
You start it and we'll follow along :)
KeithSloan
Thu May 29, 2014 5:30 am
I am new to Scratch & Squeak, but listening to Tim at http://smalltalkinspect.podspot.de/post ... -rowledge/ I would assume that the software is faster under RISC OS than Raspbian as the RISC OS Wimp is much faster than X-Windows. Are these new versions available for RISC OS
simplesi
Thu May 29, 2014 3:27 pm
Until things are sorted and new thread created - here is link to blog post so that people can get started testing/trying
http://www.raspberrypi.org/blog/#test-t ... ratch-beta
Simon
JarJarGeek
Sat Mar 07, 2015 6:35 pm
is NuScratch now 'standard' on Raspian .img ?? Or do you have to use the prescribed installer on this page to get it ??
@jarjargeek
syntax-err0r.com
ghp
Sat Mar 07, 2015 7:18 pm
nuscratch is standard since raspbian 2014-12-24, the xmas-release. There have been some hickups with this distribution, but with current raspbian these are corrected, especially the startup script.
'old' scratch is still available, start it with sratch.old from a terminal window.
nuscratch is starting with title line 'scratch 1.4 of 14-Jan-15'.
Regards,
Gerhard
timrowledge
Tue Jun 23, 2015 7:17 pm
So how do you folks feel about running Asteroids fast enough that it gets throttled to 'only' 50 fps?
Coming soon...
timrowledge
Tue Jul 14, 2015 3:35 pm
timrowledge wrote:So how do you folks feel about running Asteroids fast enough that it gets throttled to 'only' 50 fps?
oh, and without throttling it now does around 200fps on a pi2.
ghp
Tue Jul 14, 2015 7:09 pm
do you already have plans when this release is delivered to the public ?
And what is progress on bug fixes ? Kids in school complained a lot about the "sudden crashes".
Regards,
Gerhard
timrowledge
Tue Jul 14, 2015 7:12 pm
ghp wrote:Hello,
Pretty soon; and I'll be back at the bug-fixing mines very soon. Some stuff to do with AstroPi etc first.
Return to “Scratch”
