mcamann
no sound on a Model B with XBMC
Mon Jan 13, 2014 5:38 am
Hi all--
Please forgive me if this isn't the correct forum for this question (kindly redirect, and thanks), or if it's a common question.
I have a Model B that I'm currently trying to use for playing media files. I've installed both RaspBMC and OpenELEC from the most recent NOOBS 1.3.4-- both seem to run just fine, but I cannot get any sound out of the headphone jack in either case (I'm using a converter cable on the HDMI for video only). I've searched through the XBMC UI for some obvious way to "turn up the volume," but haven't found it yet. I'm not even certain yet that XBMC is the solution I'm looking for, but I need to get the sound on first. Can anyone point me toward resources for solving this problem, or ask for clarifying information if I can provide it?
Best regards,
--Mike C.
Dukmans
Re: no sound on a Model B with XBMC
Mon Jan 13, 2014 4:24 pm
Same prob here. I am reading through the posts but no clear solution yet.
I will let you know when I find one or cheer when I find the solution here.
Grz, Martijn
Phill Rymer
Mon Jan 13, 2014 11:27 pm
mcamann wrote:Hi all--
Best regards,
--Mike C.
start film click on speaker bottem right opens amplifier and volume controls set as prefared then click video default to set it as default volume settinh
Dukmans
Tue Jan 14, 2014 9:59 am
Music!
I first got the raspbmc through the link: http://www.raspbmc.com/wiki/user/windows-installation/
Wth this setup plus update my jack did not work. I tried NOOBS plus update and the jack works!
Tadaa!
But: it now works on jack to headphone, not on my amplifier with a jack to tulip plug. This jack to tulip plug works fine with my smartphone to the amplifier.
So: is there something in the configuration I can change to get music out of the amplifier?
Thanks!
Dukmans
Mon Jan 20, 2014 7:29 am
Hello Mike,
Do you use a jack to tulip cable like I do? If so; make sure the tulip output is only sound (red and white), not also video (yellow). I bought a cable with only audio output and the pi works fine now.
