Wayne Keenan
Adafruit PiTFT Mini Kit in the UK
Thu Jan 09, 2014 4:40 pm
I've imported a few Adafruit PiTFT Mini kits for sale within the UK. If you're interested please see http://www.ebay.co.uk/itm/281242307155
All the best
Wayne
corenominal
Re: Adafruit PiTFT Mini Kit in the UK
Thu Jan 09, 2014 7:13 pm
Hey Wayne :)
I was just looking at these on YouTube and they look pretty sweet. I did a quick search to see if I could find a UK distributor and came across both your listing here and on Ebay. I'm not sure what the RRP is, but yours look pretty reasonable, so I've ordered one.
I'm looking forward to playing with it. Thanks.
Wayne Keenan
Fri Jan 10, 2014 12:14 pm
Thanks for ordering one. They seem to be out of stock most of the time in the US and the UK so have fun with yours, posting it today :)
All the best
Wayne
corenominal
Sat Jan 11, 2014 3:54 pm
It arrived today, blimey that was fast, thank you! I'm off now to have a play with it :D
corenominal
Fri Jan 17, 2014 9:51 pm
Just a quick follow-up post. So, it took me until earlier tonight to actually solder the header pins on and install the software. I followed the guide on the Adafruit site, it was pretty simple and worked first time.
If anyone is considering purchasing one of these, I would highly recommend it.
@Wayne, thank you again :)
docdailey
Mon Jan 20, 2014 12:13 am
did you use the newest version of wheezy? My only deviation was that I used the new download. Nothin from the tft. About to check my soldering. any tips? see below for various troubleshooting.
Doc
pi@raspberrypi ~ $ startx
X.Org X Server 1.12.4
Release Date: 2012-08-27
X Protocol Version 11, Revision 0
Build Operating System: Linux 3.2.0-2-mx5 armv7l Debian
Current Operating System: Linux raspberrypi 3.6.11+ #26 PREEMPT Tue Nov 26 18:19:51 SGT 2013 armv6l
Kernel command line: dma.dmachans=0x7f35 bcm2708_fb.fbwidth=1136 bcm2708_fb.fbheight=592 bcm2708.boardrev=0xe bcm2708.serial=0x31fae4e7 smsc95xx.macaddr=B8:27:EB:FA:E4:E7 sdhci-bcm2708.emmc_clock_freq=100000000 vc_mem.mem_base=0x1ec00000 vc_mem.mem_size=0x20000000 dwc_otg.lpm_enable=0 console=ttyAMA0,115200 kgdboc=ttyAMA0,115200 console=tty1 root=/dev/mmcblk0p6 rootfstype=ext4 elevator=deadline rootwait
Build Date: 18 December 2013 05:20:52PM
xorg-server 2:1.12.4-6+deb7u2 (Julien Cristau <jcristau@debian.org>)
Current version of pixman: 0.29.3
Before reporting problems, check http://wiki.x.org
to make sure that you have the latest version.
Markers: (--) probed, (**) from config file, (==) default setting,
(++) from command line, (!!) notice, (II) informational,
(WW) warning, (EE) error, (NI) not implemented, (??) unknown.
(==) Log file: "/var/log/Xorg.0.log", Time: Sun Jan 19 17:48:59 2014
(==) Using system config directory "/usr/share/X11/xorg.conf.d"
FATAL: Module g2d_23 not found.
^Cxinit: connection to X server lost
waiting for X server to shut down Server terminated successfully (0). Closing log file.
xinit: unexpected signal 2
pi@raspberrypi ~ $ lsmod
Module Size Used by
fuse 69819 1
fb_ili9340 3972 0
fbtft_device 22588 0
fbtft 31031 2 fb_ili9340,fbtft_device
syscopyarea 3097 1 fbtft
sysfillrect 3264 1 fbtft
sysimgblt 2160 1 fbtft
fb_sys_fops 1389 1 fbtft
spidev 5224 0
spi_bcm2708 6886 0
snd_bcm2835 16469 0
snd_pcm 78862 1 snd_bcm2835
snd_page_alloc 5146 1 snd_pcm
snd_seq 53885 0
snd_seq_device 6460 1 snd_seq
snd_timer 21043 2 snd_pcm,snd_seq
snd 58994 5 snd_bcm2835,snd_timer,snd_pcm,snd_seq,snd_seq_device
8192cu 491084 0
leds_gpio 2178 0
led_class 3573 1 leds_gpio
evdev 9509 2
rpi_pwm 6547 0
pi@raspberrypi ~ $ ls -l /dev/fb1
crw-rw---T 1 root video 29, 1 Jan 19 17:48 /dev/fb1
pi@raspberrypi ~ $ cat /boot/cmdline.txt
pi@raspberrypi ~ $ dmesg
[ 0.000000] Booting Linux on physical CPU 0
[ 0.000000] Initializing cgroup subsys cpu
[ 0.000000] Linux version 3.6.11+ (smc@build-ssd) (gcc version 4.5.4 20120305 (prerelease) (GCC) ) #26 PREEMPT Tue Nov 26 18:19:51 SGT 2013
[ 0.000000] CPU: ARMv6-compatible processor [410fb767] revision 7 (ARMv7), cr=00c5387d
[ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT nonaliasing instruction cache
[ 0.000000] Machine: BCM2708
[ 0.000000] cma: CMA: reserved 16 MiB at 17000000
[ 0.000000] Memory policy: ECC disabled, Data cache writeback
[ 0.000000] On node 0 totalpages: 98304
[ 0.000000] free_area_init_node: node 0, pgdat c055c1b0, node_mem_map c0606000
[ 0.000000] Normal zone: 768 pages used for memmap
[ 0.000000] Normal zone: 0 pages reserved
[ 0.000000] Normal zone: 97536 pages, LIFO batch:31
[ 0.000000] pcpu-alloc: s0 r0 d32768 u32768 alloc=1*32768
[ 0.000000] pcpu-alloc: [0] 0
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 97536
[ 0.000000] Kernel command line: dma.dmachans=0x7f35 bcm2708_fb.fbwidth=1136 bcm2708_fb.fbheight=592 bcm2708.boardrev=0xe bcm2708.serial=0x31fae4e7 smsc95xx.macaddr=B8:27:EB:FA:E4:E7 sdhci-bcm2708.emmc_clock_freq=100000000 vc_mem.mem_base=0x1ec00000 vc_mem.mem_size=0x20000000 dwc_otg.lpm_enable=0 console=ttyAMA0,115200 kgdboc=ttyAMA0,115200 console=tty1 root=/dev/mmcblk0p6 rootfstype=ext4 elevator=deadline rootwait
[ 0.000000] PID hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.000000] Dentry cache hash table entries: 65536 (order: 6, 262144 bytes)
[ 0.000000] Inode-cache hash table entries: 32768 (order: 5, 131072 bytes)
[ 0.000000] Memory: 384MB = 384MB total
[ 0.000000] Memory: 367108k/367108k available, 26108k reserved, 0K highmem
[ 0.000000] Virtual kernel memory layout:
[ 0.000000] vector : 0xffff0000 - 0xffff1000 ( 4 kB)
[ 0.000000] fixmap : 0xfff00000 - 0xfffe0000 ( 896 kB)
[ 0.000000] vmalloc : 0xd8800000 - 0xff000000 ( 616 MB)
[ 0.000000] lowmem : 0xc0000000 - 0xd8000000 ( 384 MB)
[ 0.000000] modules : 0xbf000000 - 0xc0000000 ( 16 MB)
[ 0.000000] .text : 0xc0008000 - 0xc0502ef4 (5100 kB)
[ 0.000000] .init : 0xc0503000 - 0xc052454c ( 134 kB)
[ 0.000000] .data : 0xc0526000 - 0xc055c9e0 ( 219 kB)
[ 0.000000] .bss : 0xc055ca04 - 0xc0605e78 ( 678 kB)
[ 0.000000] SLUB: Genslabs=13, HWalign=32, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
[ 0.000000] NR_IRQS:394
[ 0.000000] sched_clock: 32 bits at 1000kHz, resolution 1000ns, wraps every 4294967ms
[ 0.000000] Console: colour dummy device 80x30
[ 0.000000] console [tty1] enabled
[ 0.000959] Calibrating delay loop... 697.95 BogoMIPS (lpj=3489792)
[ 0.060125] pid_max: default: 32768 minimum: 301
[ 0.060588] Mount-cache hash table entries: 512
[ 0.061385] Initializing cgroup subsys cpuacct
[ 0.061445] Initializing cgroup subsys devices
[ 0.061477] Initializing cgroup subsys freezer
[ 0.061507] Initializing cgroup subsys blkio
[ 0.061648] CPU: Testing write buffer coherency: ok
[ 0.061977] hw perfevents: enabled with v6 PMU driver, 3 counters available
[ 0.062118] Setting up static identity map for 0x3b46d8 - 0x3b4734
[ 0.063608] devtmpfs: initialized
[ 0.078699] NET: Registered protocol family 16
[ 0.085151] DMA: preallocated 4096 KiB pool for atomic coherent allocations
[ 0.086238] bcm2708.uart_clock = 0
[ 0.087634] hw-breakpoint: found 6 breakpoint and 1 watchpoint registers.
[ 0.087687] hw-breakpoint: maximum watchpoint size is 4 bytes.
[ 0.087721] mailbox: Broadcom VideoCore Mailbox driver
[ 0.087816] bcm2708_vcio: mailbox at f200b880
[ 0.087914] bcm_power: Broadcom power driver
[ 0.087951] bcm_power_open() -> 0
[ 0.087974] bcm_power_request(0, 8)
[ 0.588670] bcm_mailbox_read -> 00000080, 0
[ 0.588710] bcm_power_request -> 0
[ 0.588735] Serial: AMBA PL011 UART driver
[ 0.588865] dev:f1: ttyAMA0 at MMIO 0x20201000 (irq = 83) is a PL011 rev3
[ 0.915629] console [ttyAMA0] enabled
[ 0.939600] bio: create slab <bio-0> at 0
[ 0.944687] SCSI subsystem initialized
[ 0.948764] usbcore: registered new interface driver usbfs
[ 0.954368] usbcore: registered new interface driver hub
[ 0.959976] usbcore: registered new device driver usb
[ 0.966287] Switching to clocksource stc
[ 0.970583] FS-Cache: Loaded
[ 0.973771] CacheFiles: Loaded
[ 0.988973] NET: Registered protocol family 2
[ 0.994231] TCP established hash table entries: 16384 (order: 5, 131072 bytes)
[ 1.001972] TCP bind hash table entries: 16384 (order: 4, 65536 bytes)
[ 1.008762] TCP: Hash tables configured (established 16384 bind 16384)
[ 1.015362] TCP: reno registered
[ 1.018613] UDP hash table entries: 256 (order: 0, 4096 bytes)
[ 1.024506] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
[ 1.031128] NET: Registered protocol family 1
[ 1.036015] RPC: Registered named UNIX socket transport module.
[ 1.042070] RPC: Registered udp transport module.
[ 1.046792] RPC: Registered tcp transport module.
[ 1.051535] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 1.058643] bcm2708_dma: DMA manager at f2007000
[ 1.063427] bcm2708_gpio: bcm2708_gpio_probe c0533d98
[ 1.068871] vc-mem: phys_addr:0x00000000 mem_base=0x1ec00000 mem_size:0x20000000(512 MiB)
[ 1.078121] audit: initializing netlink socket (disabled)
[ 1.083730] type=2000 audit(0.940:1): initialized
[ 1.221024] VFS: Disk quotas dquot_6.5.2
[ 1.225250] Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 1.234417] FS-Cache: Netfs 'nfs' registered for caching
[ 1.241140] NFS: Registering the id_resolver key type
[ 1.246316] Key type id_resolver registered
[ 1.250613] Key type id_legacy registered
[ 1.254975] msgmni has been set to 749
[ 1.261050] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 252)
[ 1.268777] io scheduler noop registered
[ 1.272817] io scheduler deadline registered (default)
[ 1.278052] io scheduler cfq registered
[ 1.293569] Console: switching to colour frame buffer device 142x37
[ 1.304902] kgdb: Registered I/O driver kgdboc.
[ 1.310169] vc-cma: Videocore CMA driver
[ 1.316298] vc-cma: vc_cma_base = 0x00000000
[ 1.323117] vc-cma: vc_cma_size = 0x00000000 (0 MiB)
[ 1.330533] vc-cma: vc_cma_initial = 0x00000000 (0 MiB)
[ 1.346840] brd: module loaded
[ 1.357120] loop: module loaded
[ 1.362693] vchiq: vchiq_init_state: slot_zero = 0xd7000000, is_master = 0
[ 1.372460] Loading iSCSI transport class v2.0-870.
[ 1.380574] usbcore: registered new interface driver smsc95xx
[ 1.388734] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
[ 1.601697] Core Release: 2.80a
[ 1.606888] Setting default values for core params
[ 1.613756] Finished setting default values for core params
[ 1.826442] Using Buffer DMA mode
[ 1.831824] Periodic Transfer Interrupt Enhancement - disabled
[ 1.839637] Multiprocessor Interrupt Enhancement - disabled
[ 1.847171] OTG VER PARAM: 0, OTG VER FLAG: 0
[ 1.853522] Dedicated Tx FIFOs mode
[ 1.859900] dwc_otg: Microframe scheduler enabled
[ 1.860301] dwc_otg bcm2708_usb: DWC OTG Controller
[ 1.867331] dwc_otg bcm2708_usb: new USB bus registered, assigned bus number 1
[ 1.876625] dwc_otg bcm2708_usb: irq 32, io mem 0x00000000
[ 1.884244] Init: Port Power? op_state=1
[ 1.890103] Init: Power Port (0)
[ 1.895361] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.904207] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.913397] usb usb1: Product: DWC OTG Controller
[ 1.920021] usb usb1: Manufacturer: Linux 3.6.11+ dwc_otg_hcd
[ 1.927679] usb usb1: SerialNumber: bcm2708_usb
[ 1.934977] hub 1-0:1.0: USB hub found
[ 1.940803] hub 1-0:1.0: 1 port detected
[ 1.946941] dwc_otg: FIQ enabled
[ 1.946957] dwc_otg: NAK holdoff enabled
[ 1.946964] dwc_otg: FIQ split fix enabled
[ 1.946982] Module dwc_common_port init
[ 1.947214] Initializing USB Mass Storage driver...
[ 1.954326] usbcore: registered new interface driver usb-storage
[ 1.962273] USB Mass Storage support registered.
[ 1.968960] usbcore: registered new interface driver libusual
[ 1.977021] mousedev: PS/2 mouse device common for all mice
[ 1.985414] bcm2835-cpufreq: min=700000 max=700000 cur=700000
[ 1.993337] bcm2835-cpufreq: switching to governor powersave
[ 2.001085] bcm2835-cpufreq: switching to governor powersave
[ 2.008719] cpuidle: using governor ladder
[ 2.014768] cpuidle: using governor menu
[ 2.020674] sdhci: Secure Digital Host Controller Interface driver
[ 2.028726] sdhci: Copyright(c) Pierre Ossman
[ 2.035077] sdhci: Enable low-latency mode
[ 2.080654] mmc0: SDHCI controller on BCM2708_Arasan [platform] using platform's DMA
[ 2.090722] mmc0: BCM2708 SDHC host at 0x20300000 DMA 2 IRQ 77
[ 2.100754] sdhci-pltfm: SDHCI platform and OF driver helper
[ 2.114031] usbcore: registered new interface driver usbhid
[ 2.121743] usbhid: USB HID core driver
[ 2.132306] TCP: cubic registered
[ 2.139722] Initializing XFRM netlink socket
[ 2.148143] Indeed it is in host mode hprt0 = 00021501
[ 2.155398] NET: Registered protocol family 17
[ 2.170616] Key type dns_resolver registered
[ 2.180783] VFP support v0.3: implementor 41 architecture 1 part 20 variant b rev 5
[ 2.200004] mmc0: new high speed SDHC card at address aaaa
[ 2.211160] registered taskstats version 1
[ 2.230457] mmcblk0: mmc0:aaaa SU16G 14.8 GiB
[ 2.240735] mmcblk0: p1 p2 < p5 p6 > p3
[ 2.285671] EXT4-fs (mmcblk0p6): mounted filesystem with ordered data mode. Opts: (null)
[ 2.296102] VFS: Mounted root (ext4 filesystem) on device 179:6.
[ 2.305337] devtmpfs: mounted
[ 2.310918] Freeing init memory: 132K
[ 2.380477] usb 1-1: new high-speed USB device number 2 using dwc_otg
[ 2.389319] Indeed it is in host mode hprt0 = 00001101
[ 2.601147] usb 1-1: New USB device found, idVendor=0424, idProduct=9512
[ 2.610509] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 2.621117] hub 1-1:1.0: USB hub found
[ 2.628188] hub 1-1:1.0: 3 ports detected
[ 2.910660] usb 1-1.1: new high-speed USB device number 3 using dwc_otg
[ 3.041036] usb 1-1.1: New USB device found, idVendor=0424, idProduct=ec00
[ 3.051043] usb 1-1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 3.067851] smsc95xx v1.0.4
[ 3.138236] smsc95xx 1-1.1:1.0: eth0: register 'smsc95xx' at usb-bcm2708_usb-1.1, smsc95xx USB 2.0 Ethernet, b8:27:eb:fa:e4:e7
[ 3.230712] usb 1-1.2: new low-speed USB device number 4 using dwc_otg
[ 3.371949] usb 1-1.2: New USB device found, idVendor=04f2, idProduct=0918
[ 3.389198] usb 1-1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 3.410501] usb 1-1.2: Product: 2.4G Multimedia Wireless Kit
[ 3.418598] usb 1-1.2: Manufacturer: Chicony
[ 3.447995] input: Chicony 2.4G Multimedia Wireless Kit as /devices/platform/bcm2708_usb/usb1/1-1/1-1.2/1-1.2:1.0/input/input0
[ 3.481050] hid-generic 0003:04F2:0918.0001: input,hidraw0: USB HID v1.11 Keyboard [Chicony 2.4G Multimedia Wireless Kit] on usb-bcm2708_usb-1.2/input0
[ 3.549697] input: Chicony 2.4G Multimedia Wireless Kit as /devices/platform/bcm2708_usb/usb1/1-1/1-1.2/1-1.2:1.1/input/input1
[ 3.581564] hid-generic 0003:04F2:0918.0002: input,hiddev0,hidraw1: USB HID v1.11 Mouse [Chicony 2.4G Multimedia Wireless Kit] on usb-bcm2708_usb-1.2/input1
[ 3.700778] usb 1-1.3: new high-speed USB device number 5 using dwc_otg
[ 3.812921] usb 1-1.3: New USB device found, idVendor=0bda, idProduct=8176
[ 3.824297] usb 1-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 3.834654] usb 1-1.3: Product: 802.11n WLAN Adapter
[ 3.850519] usb 1-1.3: Manufacturer: Realtek
[ 3.857666] usb 1-1.3: SerialNumber: 00e04c000001
[ 3.971817] udevd[154]: starting version 175
[ 4.922431] Adafruit Industries' Raspberry Pi PWM driver v1.0
[ 5.369214] Registered led device: led0
[ 6.881110] usbcore: registered new interface driver rtl8192cu
[ 9.991262] EXT4-fs (mmcblk0p6): re-mounted. Opts: (null)
[ 10.471529] EXT4-fs (mmcblk0p6): re-mounted. Opts: (null)
[ 24.696940] Adding 102396k swap on /var/swap. Priority:-1 extents:1 across:102396k SS
[ 270.442784] bcm2708_spi bcm2708_spi.0: DMA channel 0 at address 0xf2007000 with irq 16
[ 270.442818] bcm2708_spi bcm2708_spi.0: DMA channel 4 at address 0xf2007400 with irq 20
[ 270.445867] spi_master spi0: will run message pump with realtime priority
[ 270.446284] bcm2708_spi bcm2708_spi.0: SPI Controller at 0x20204000 (irq 80)
[ 270.446306] bcm2708_spi bcm2708_spi.0: SPI Controller running in polling mode
[ 282.094221] fbtft_device: SPI devices registered:
[ 282.094268] fbtft_device: spidev spi0.0 500kHz 8 bits mode=0x00
[ 282.094283] fbtft_device: spidev spi0.1 500kHz 8 bits mode=0x00
[ 282.094291] fbtft_device: 'fb' Platform devices registered:
[ 282.094312] fbtft_device: bcm2708_fb id=-1 pdata? no
[ 282.094369] fbtft_device: Deleting spi0.1 (spi0.1)
[ 282.094747] fbtft_device: Looking at item 0
[ 282.094764] fbtft_device: Setting pin 24 to 2
[ 282.170847] stmpe-spi spi0.1: unknown chip id: 0x0
[ 282.170895] stmpe-spi: probe of spi0.1 failed with error -22
[ 282.170927] fbtft_device: Deleting spi0.0 (spi0.0)
[ 282.171437] fbtft_device: GPIOS used by 'adafruitts':
[ 282.171457] fbtft_device: 'dc' = GPIO25
[ 282.171466] fbtft_device: SPI devices registered:
[ 282.171480] fbtft_device: stmpe610 spi0.1 500kHz 8 bits mode=0x00
[ 282.171493] fbtft_device: fb_ili9340 spi0.0 16000kHz 8 bits mode=0x00
[ 282.444335] graphics fb1: fb_ili9340 frame buffer, 320x240, 150 KiB video memory, 16 KiB buffer memory, fps=20, spi0.0 at 16 MHz
[ 306.507596] EXT4-fs (mmcblk0p3): mounted filesystem with ordered data mode. Opts: (null)
[ 488.966883] fuse init (API version 7.20)
docdailey
Mon Jan 20, 2014 12:37 am
some progress... the metal surround was toughing my header....
better... now it does flash prior to startx.
still get the same error with startx
[ 0.060128] pid_max: default: 32768 minimum: 301
[ 0.060590] Mount-cache hash table entries: 512
[ 0.061386] Initializing cgroup subsys cpuacct
[ 0.061447] Initializing cgroup subsys devices
[ 0.061481] Initializing cgroup subsys freezer
[ 0.061510] Initializing cgroup subsys blkio
[ 0.061651] CPU: Testing write buffer coherency: ok
[ 0.061978] hw perfevents: enabled with v6 PMU driver, 3 counters available
[ 0.063604] devtmpfs: initialized
[ 0.078716] NET: Registered protocol family 16
[ 0.085175] DMA: preallocated 4096 KiB pool for atomic coherent allocations
[ 0.086266] bcm2708.uart_clock = 0
[ 0.087660] hw-breakpoint: found 6 breakpoint and 1 watchpoint registers.
[ 0.087713] hw-breakpoint: maximum watchpoint size is 4 bytes.
[ 0.087748] mailbox: Broadcom VideoCore Mailbox driver
[ 0.087842] bcm2708_vcio: mailbox at f200b880
[ 0.087938] bcm_power: Broadcom power driver
[ 0.087973] bcm_power_open() -> 0
[ 0.087997] bcm_power_request(0, 8)
[ 0.588681] bcm_mailbox_read -> 00000080, 0
[ 0.588721] bcm_power_request -> 0
[ 0.588747] Serial: AMBA PL011 UART driver
[ 0.588875] dev:f1: ttyAMA0 at MMIO 0x20201000 (irq = 83) is a PL011 rev3
[ 0.915639] console [ttyAMA0] enabled
[ 0.939607] bio: create slab <bio-0> at 0
[ 0.944697] SCSI subsystem initialized
[ 0.948776] usbcore: registered new interface driver usbfs
[ 0.954378] usbcore: registered new interface driver hub
[ 0.959984] usbcore: registered new device driver usb
[ 0.966289] Switching to clocksource stc
[ 0.970590] FS-Cache: Loaded
[ 0.973776] CacheFiles: Loaded
[ 0.988981] NET: Registered protocol family 2
[ 0.994241] TCP established hash table entries: 16384 (order: 5, 131072 bytes)
[ 1.001985] TCP bind hash table entries: 16384 (order: 4, 65536 bytes)
[ 1.008775] TCP: Hash tables configured (established 16384 bind 16384)
[ 1.015375] TCP: reno registered
[ 1.018625] UDP hash table entries: 256 (order: 0, 4096 bytes)
[ 1.024518] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
[ 1.031140] NET: Registered protocol family 1
[ 1.036029] RPC: Registered named UNIX socket transport module.
[ 1.042083] RPC: Registered udp transport module.
[ 1.046806] RPC: Registered tcp transport module.
[ 1.051549] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 1.058655] bcm2708_dma: DMA manager at f2007000
[ 1.063441] bcm2708_gpio: bcm2708_gpio_probe c0533d98
[ 1.068885] vc-mem: phys_addr:0x00000000 mem_base=0x1ec00000 mem_size:0x20000000(512 MiB)
[ 1.078125] audit: initializing netlink socket (disabled)
[ 1.221001] VFS: Disk quotas dquot_6.5.2
[ 1.225231] Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 1.234406] FS-Cache: Netfs 'nfs' registered for caching
[ 1.241126] NFS: Registering the id_resolver key type
[ 1.246289] Key type id_resolver registered
[ 1.250586] Key type id_legacy registered
[ 1.254951] msgmni has been set to 749
[ 1.261037] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 252)
[ 1.268763] io scheduler noop registered
[ 1.272800] io scheduler deadline registered (default)
[ 1.278035] io scheduler cfq registered
[ 1.296655] Console: switching to colour frame buffer device 142x37
[ 1.308006] kgdb: Registered I/O driver kgdboc.
[ 1.313337] vc-cma: Videocore CMA driver
[ 1.319404] vc-cma: vc_cma_base = 0x00000000
[ 1.326219] vc-cma: vc_cma_size = 0x00000000 (0 MiB)
[ 1.333636] vc-cma: vc_cma_initial = 0x00000000 (0 MiB)
[ 1.349903] brd: module loaded
[ 1.360209] loop: module loaded
[ 1.365776] vchiq: vchiq_init_state: slot_zero = 0xd7000000, is_master = 0
[ 1.375546] Loading iSCSI transport class v2.0-870.
[ 1.383616] usbcore: registered new interface driver smsc95xx
[ 1.391898] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
[ 1.604813] Core Release: 2.80a
[ 1.610010] Setting default values for core params
[ 1.616886] Finished setting default values for core params
[ 1.829575] Using Buffer DMA mode
[ 1.834949] Periodic Transfer Interrupt Enhancement - disabled
[ 1.842800] Multiprocessor Interrupt Enhancement - disabled
[ 1.850327] OTG VER PARAM: 0, OTG VER FLAG: 0
[ 1.856667] Dedicated Tx FIFOs mode
[ 1.863087] dwc_otg: Microframe scheduler enabled
[ 1.863501] dwc_otg bcm2708_usb: DWC OTG Controller
[ 1.870530] dwc_otg bcm2708_usb: new USB bus registered, assigned bus number 1
[ 1.879790] dwc_otg bcm2708_usb: irq 32, io mem 0x00000000
[ 1.887399] Init: Port Power? op_state=1
[ 1.893303] Init: Power Port (0)
[ 1.898543] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.907383] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.916575] usb usb1: Product: DWC OTG Controller
[ 1.923238] usb usb1: Manufacturer: Linux 3.6.11+ dwc_otg_hcd
[ 1.930905] usb usb1: SerialNumber: bcm2708_usb
[ 1.938170] hub 1-0:1.0: USB hub found
[ 1.943996] hub 1-0:1.0: 1 port detected
[ 1.950125] dwc_otg: FIQ enabled
[ 1.950141] dwc_otg: NAK holdoff enabled
[ 1.950150] dwc_otg: FIQ split fix enabled
[ 1.950168] Module dwc_common_port init
[ 1.950459] Initializing USB Mass Storage driver...
[ 1.957476] usbcore: registered new interface driver usb-storage
[ 1.965458] USB Mass Storage support registered.
[ 1.972212] usbcore: registered new interface driver libusual
[ 1.980242] mousedev: PS/2 mouse device common for all mice
[ 1.988622] bcm2835-cpufreq: min=700000 max=700000 cur=700000
[ 1.996549] bcm2835-cpufreq: switching to governor powersave
[ 2.004299] bcm2835-cpufreq: switching to governor powersave
[ 2.011963] cpuidle: using governor ladder
[ 2.017980] cpuidle: using governor menu
[ 2.023873] sdhci: Secure Digital Host Controller Interface driver
[ 2.031970] sdhci: Copyright(c) Pierre Ossman
[ 2.038298] sdhci: Enable low-latency mode
[ 2.090578] mmc0: SDHCI controller on BCM2708_Arasan [platform] using platform's DMA
[ 2.100613] mmc0: BCM2708 SDHC host at 0x20300000 DMA 2 IRQ 77
[ 2.110654] sdhci-pltfm: SDHCI platform and OF driver helper
[ 2.123972] usbcore: registered new interface driver usbhid
[ 2.131636] usbhid: USB HID core driver
[ 2.142162] Indeed it is in host mode hprt0 = 00021501
[ 2.151635] TCP: cubic registered
[ 2.170415] Initializing XFRM netlink socket
[ 2.176762] NET: Registered protocol family 17
[ 2.190546] Key type dns_resolver registered
[ 2.197087] VFP support v0.3: implementor 41 architecture 1 part 20 variant b rev 5
[ 2.216285] mmc0: new high speed SDHC card at address aaaa
[ 2.231035] mmcblk0: mmc0:aaaa SU16G 14.8 GiB
[ 2.240903] registered taskstats version 1
[ 2.253300] mmcblk0: p1 p2 < p5 p6 > p3
[ 2.346895] EXT4-fs (mmcblk0p6): mounted filesystem with ordered data mode. Opts: (null)
[ 2.357240] VFS: Mounted root (ext4 filesystem) on device 179:6.
[ 2.366484] devtmpfs: mounted
[ 2.372100] Freeing init memory: 132K
[ 2.400493] usb 1-1: new high-speed USB device number 2 using dwc_otg
[ 2.410267] Indeed it is in host mode hprt0 = 00001101
[ 2.621130] usb 1-1: New USB device found, idVendor=0424, idProduct=9512
[ 2.635297] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 2.646224] hub 1-1:1.0: USB hub found
[ 2.653731] hub 1-1:1.0: 3 ports detected
[ 2.940771] usb 1-1.1: new high-speed USB device number 3 using dwc_otg
[ 3.061296] usb 1-1.1: New USB device found, idVendor=0424, idProduct=ec00
[ 3.078627] usb 1-1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 3.103324] smsc95xx v1.0.4
[ 3.175982] smsc95xx 1-1.1:1.0: eth0: register 'smsc95xx' at usb-bcm2708_usb-1.1, smsc95xx USB 2.0 Ethernet, b8:27:eb:fa:e4:e7
[ 3.300832] usb 1-1.2: new low-speed USB device number 4 using dwc_otg
[ 3.442317] usb 1-1.2: New USB device found, idVendor=04f2, idProduct=0918
[ 3.460721] usb 1-1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 3.480573] usb 1-1.2: Product: 2.4G Multimedia Wireless Kit
[ 3.488702] usb 1-1.2: Manufacturer: Chicony
[ 3.519372] input: Chicony 2.4G Multimedia Wireless Kit as /devices/platform/bcm2708_usb/usb1/1-1/1-1.2/1-1.2:1.0/input/input0
[ 3.549889] hid-generic 0003:04F2:0918.0001: input,hidraw0: USB HID v1.11 Keyboard [Chicony 2.4G Multimedia Wireless Kit] on usb-bcm2708_usb-1.2/input0
[ 3.623608] input: Chicony 2.4G Multimedia Wireless Kit as /devices/platform/bcm2708_usb/usb1/1-1/1-1.2/1-1.2:1.1/input/input1
[ 3.659093] hid-generic 0003:04F2:0918.0002: input,hiddev0,hidraw1: USB HID v1.11 Mouse [Chicony 2.4G Multimedia Wireless Kit] on usb-bcm2708_usb-1.2/input1
[ 3.790763] usb 1-1.3: new high-speed USB device number 5 using dwc_otg
[ 3.912917] usb 1-1.3: New USB device found, idVendor=0bda, idProduct=8176
[ 3.930543] usb 1-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 3.954759] usb 1-1.3: Product: 802.11n WLAN Adapter
[ 3.970539] usb 1-1.3: Manufacturer: Realtek
[ 3.977709] usb 1-1.3: SerialNumber: 00e04c000001
[ 4.041051] udevd[154]: starting version 175
[ 4.982081] Adafruit Industries' Raspberry Pi PWM driver v1.0
[ 5.383102] Registered led device: led0
[ 6.934498] usbcore: registered new interface driver rtl8192cu
[ 15.066344] EXT4-fs (mmcblk0p6): re-mounted. Opts: (null)
[ 15.531554] EXT4-fs (mmcblk0p6): re-mounted. Opts: (null)
[ 29.714523] Adding 102396k swap on /var/swap. Priority:-1 extents:1 across:102396k SS
[ 66.768949] bcm2708_spi bcm2708_spi.0: DMA channel 0 at address 0xf2007000 with irq 16
[ 66.768983] bcm2708_spi bcm2708_spi.0: DMA channel 4 at address 0xf2007400 with irq 20
[ 66.773622] spi_master spi0: will run message pump with realtime priority
[ 66.774025] bcm2708_spi bcm2708_spi.0: SPI Controller at 0x20204000 (irq 80)
[ 66.774049] bcm2708_spi bcm2708_spi.0: SPI Controller running in polling mode
[ 73.193586] fbtft_device: SPI devices registered:
[ 73.193622] fbtft_device: spidev spi0.0 500kHz 8 bits mode=0x00
[ 73.193638] fbtft_device: spidev spi0.1 500kHz 8 bits mode=0x00
[ 73.193646] fbtft_device: 'fb' Platform devices registered:
[ 73.193667] fbtft_device: bcm2708_fb id=-1 pdata? no
[ 73.193720] fbtft_device: Deleting spi0.1 (spi0.1)
[ 73.196856] fbtft_device: Looking at item 0
[ 73.196880] fbtft_device: Setting pin 24 to 2
[ 73.270865] stmpe-spi spi0.1: stmpe610 detected, chip id: 0x811
[ 73.277214] fbtft_device: Deleting spi0.0 (spi0.0)
[ 73.278513] fbtft_device: GPIOS used by 'adafruitts':
[ 73.278539] fbtft_device: 'dc' = GPIO25
[ 73.278574] fbtft_device: SPI devices registered:
[ 73.278621] fbtft_device: stmpe610 spi0.1 500kHz 8 bits mode=0x00
[ 73.278666] fbtft_device: fb_ili9340 spi0.0 16000kHz 8 bits mode=0x00
[ 73.407674] input: stmpe-ts as /devices/virtual/input/input2
[ 73.746101] graphics fb1: fb_ili9340 frame buffer, 320x240, 150 KiB video memory, 16 KiB buffer memory, fps=20, spi0.0 at 16 MHz
docdailey
Mon Jan 20, 2014 2:41 am
reverted to wheezy 2013-09-25 and all is well.
Doc
notro
Mon Jan 20, 2014 11:59 am
docdailey wrote:reverted to wheezy 2013-09-25 and all is well.
This could be a solution: https://github.com/notro/fbtft/issues/63
docdailey
Mon Jan 20, 2014 12:06 pm
I will give that a try on the newer distribution of wheezy when I have a chance.
TonyD
Mon Jan 20, 2014 1:20 pm
I sure Adafruit recently said PiTFT was having issues with the latest wheezy distribution and recommend people drop back to wheezy 2013-09-25.
Tony
docdailey
Mon Jan 20, 2014 1:46 pm
tony,
yes, i saw that... they dont mention what the issue is.
doc
h4rri
Mon Jan 20, 2014 3:28 pm
I am thinking of grabbing one of these to use as a sort of remote for a Pi which is currently plugged into a monitor via HDMI.
Any thoughts on if I can use a dual display setup with the little touchscreen to control the content viewed on the monitor? I would be running Plex, Slideshows etc.
Thoughts?
docdailey
Mon Jan 20, 2014 3:34 pm
That would work but it is really small and lores. I have considered building a little gtk interface for something similar.
Doc
Return to “For sale”
