deavmi
TightVNC startup on boot not working
Thu Jan 09, 2014 4:21 pm
Hello, I have recetly been having problems gettoing a tightvnc server to start on boot using this page over here (http://elinux.org/RPi_VNC_Server) . I have created the file in /etc/init.d , then chmodded it. Then I tried the first command "update-rc.d /etc/init.d/vncboot defaults" which didn't work so I tried the other alternative one, "update-rc.d vncboot defaults" then it printed this out,
"update-rc.d: using dependency based boot sequencing
insserv: warning: script 'mathkernel' missing LSB tags and overrides" and I rebooted my Pi and tried connecting to it via VNCViewer and it gave me an error, I think it said connection refused so obviously the server didn't start.
AndyD
Re: TightVNC startup on boot not working
Thu Jan 09, 2014 8:29 pm
deavmi wrote:insserv: warning: script 'mathkernel' missing LSB tags and overrides"
This is a warning to do with the Mathematica init.d entry. It is just a warning that the file is missing the LSB header. It won't have anything to do with TightVNC not running.
deavmi
Fri Jan 10, 2014 9:06 am
But for some reason I think the VNC server never starts on boot. On their page it has the word "root" should I replace that with my user name, that being"pi"
AndyD
Fri Jan 10, 2014 9:11 am
Further down that page it talks about Getting VNC Server to Work on a Specific User
deavmi
Fri Jan 10, 2014 10:40 am
I think I might have found the error. The vncboot file was saved as vncboot.save and not just vncboot - UPDATE: Sorry about this post, i by mistake was on a different machine lookign at a different script file.
deavmi
Fri Jan 10, 2014 10:43 am
Okay I think it's still not working. I will check out the link you have posted. :D :D :D
alanwbaker
Sat Jan 11, 2014 7:00 am
I'm experiencing the same issue as deavmi. I ran the same two update-rc.d commands he mentioned with the same results.
vncserver did not start at boot time, so I put a couple of echo statements in the vncboot script and found that it is just not being executed then. But once the Pi is up and running, I can run sudo /etc/init.d/vncboot and the server works perfectly. I'm fine with running it as root.
Can you give me clue?
Sat Jan 11, 2014 12:02 pm
What's in the LSB header. You need to be sure the network is active before trying to start VNC.
# Required-Start: networking
Try sudo update-rc.d vncserver 99 to get it to run later in the boot process.
What options are you setting:
OPTIONS=" -depth ${DEPTH} -geometry ${GEOMETRY} :${DISPLAY}"
The $DISPLAY variable after the colon defines which virtual display you're using and by implication which port
:1 == 5901, :2 == 5902 etc.
Have you got it writing a log file?
Has everything been chmod'ed with chmod +x?
/etc/init.d/scripts always run with root.root as owner & group (unless you do something special) so anything like password files will be assumed to be in the /root directory.
NOTE: it's a massive security hole to run VNC as root.
alanwbaker
Sun Jan 12, 2014 3:01 am
Thanks for your reply, Dougie. I'm using the init.d script from http://elinux.org/RPi_VNC_Server#Run_at_boot. As you suggested I ran
sudo update-rc.d vncboot start 99 2 3 4 5 . stop 19 0 1 6 .
which returned
insserv: warning: current start runlevel(s) (3 4 5) of script `vncboot' overrides LSB defaults (2 3 4 5).
Once the pi is up I can run
sudo /etc/init.d/vncboot start
from the command line and it works fine with a solid connection and proper logging. I changed the geometry to
/usr/bin/vncserver :0 -geometry 800x600 -depth 24
which works fine on the client monitor.
Adding networking to its Required-Start was a good idea but it didn't help my case. To confirm that the script is not executed at boot time I added the following line to the script:
echo In /etc/init.d/vncboot >>/tmp/vncboot.log
And indeed it is not being executed at boot time, so something in the LSB environment is still hosed.
Thanks in advance for any further ideas.
alanwbaker
Mon Jan 13, 2014 4:18 am
I did not find out why /etc/init.d/vncboot would not run at boot time, but here's a workaround. To start it at boot time add the following line to /etc/rc.local:
sudo service vncboot start
