triplus
Contact: Website Facebook Twitter YouTube
Compiling and installing gcc 4.8.x
Sun Jan 05, 2014 8:36 pm
Hello
I've been trying to install gcc 4.8.2 on my raspberry, because i need it to compile something else (http://rathena.org/board/topic/78187-ra ... =raspberry)
I have tried many different ways, but i haven't succeeded so far... What i did so far:
-Make a clone from github and run the "make" command. This worked for a while, but then it began to give missing file errors. I tried fixing some of them, but then i noticed i began to change(duplicate) certain files that i don't think should be moved from position.
-I tried crosscompiling with eclipse, but this also gave me missing file errors.
Is there any guide that will work, or can anyone give me good instructions on how to get a working gcc 4.8 on my raspberry?
I don't care if i have to compile on my raspberry since it is on 24/7.
I found many guides on how to get gcc working on ubuntu, but that did not work. Also corsscompiling worked for a simple hello world program (but i did not run it on my raspberry, but at least it didn't give me errors), but for gcc 4.8 it didn't work.
Thanks in advance
Joren C.
- Raspberry Pi Model B since 2013.
- Raspberry Pi Zero since October 2016
- Raspberry Pi 3 since: December 2016
Re: Compiling and installing gcc 4.8.x
Sun Jan 05, 2014 11:04 pm
Update /etc/apt/sources.list to have jessie wherever you've currently got wheezy
sudo apt-get update
sudo apt-get dist-upgrade
sudo rpi-update
reboot
And the stock gcc that gets installed is:
ii gcc 4:4.8.2-1 armhf GNU C compiler
triplus
Mon Jan 06, 2014 12:39 pm
I never tought of actually upgrading my pi... that seems like the easiest way of doing this. I'm testing this right now, getting the packages ;)
Thanks!
triplus
Mon Jan 06, 2014 2:45 pm
It worked! now onto the next step, thank you!
zappfinger
Wed Dec 28, 2016 11:15 pm
This does not work for me. I followed the steps but my gcc version stayed the same:
gcc version 4.6.3 (Debian 4.6.3-14+rpi1)
kevscott
Sun Feb 11, 2018 1:52 pm
I found that I still had the old compiler after following these steps as well. However, then doing "sudo apt-get install build-essential" got me the latest version of the compiler, which is now 4.9.2 at the time of writing.
jahboater
Sun Feb 11, 2018 6:32 pm
You have resurrected an old thread ...
The current version of the compiler is 7.3 which I use on all my Pi's.
The pre-installed version is 6.3
So your 4.9.2 is very old
n67
Sun Feb 11, 2018 7:46 pm
It wasn't (old) when this thread was started (and thus relevant):
"L'enfer, c'est les autres"
Epmu Sn!
Return to “Advanced users”
