cemicle123
Does Pi work with 8GB SD card?
Sun Jan 05, 2014 2:44 pm
Re: Does Pi work with 8GB SD card?
Sun Jan 05, 2014 3:09 pm
The Pi will work with most 8GB SD cards.
mahjongg
Sun Jan 05, 2014 3:11 pm
generally yes, but for specifics, look at the wiki: http://elinux.org/RPi_SD_cards
redhawk
The Pi supports SDHC memory cards so yes 8GB will work although you should check the compatibility list just to be sure - http://elinux.org/RPi_SD_cards
Richard S.
FTrevorGowen
Sun Jan 05, 2014 4:12 pm
FWIW the five different brands of 8Gb cards I've used (along with other sizes etc.) are shown here: http://www.cpmspectrepi.webspace.virgin ... cards.html
(and they're logged in the eLinux wiki).
Trev.
Nightsurfer
Sun Jan 05, 2014 10:12 pm
One of my RasPi model B rev 2 512 is running Raspbian from NOOBS on SanDisk 8gb class 4 micro-SD with SD adapter. Running remote, 24/7 headless, wifi, used solely for Dump1090. All maintenance done via vnc and ssh. Runs like a dream. :D
gsh
Mon Jan 06, 2014 7:23 am
redhawk wrote:The Pi supports SDHC memory cards so yes 8GB will work although you should check the compatibility list just to be sure - http://elinux.org/RPi_SD_cards
Richard S.
I wouldn't take that page particularly usefully, in the cases where people have not found it to work they are mostly having trouble because of known bugs in the software (-110 timeout errors)
So far we've not found an SD card that doesn't work with the Raspberry Pi, or if there were problems someone sent me an SD card and I fixed the bug!
Gordon
Gordon Hollingworth PhD
