I'm having problems installing Mathematica. I used:
'sudo apt-get update && sudo apt-get install wolfram-engine'
It seemed to work well. But the license screen come up with the little <ok> at the bottom. I could not click on it or find a way past it. I eventually had to close out of it.
Reading other messages here I think I was suppose to Tab to it. Is that correct?
Anyway I tried again with the same command line and it errored out with:
"E: dpkg was interupted, you must manually run 'sudo dpkg --configure -a' to correct the problem"
I ran the command as typed and it seemed to run install more. But still no mathematica. I feel like I'm just digging myself in deeper.
Is there any way to start over?
