USKeith
Composite Video
Sat Jan 04, 2014 1:28 am
New to the R-Pi world and using composite video. Composite video was working while loading Raspian Wheezy OS. Received message that installation was complete and hit ENTER to proceed. Composite Video went blank. I suspect R-Pi switched to HDMI Video when Raspian Wheezy started. Since I cannot see what is being displayed, how do I change the video output back to composite? I rebooted and believe that Raspian Wheezy is running, but the composite output does not show anything. Any suggestions?
Thanks in advance, USKeith.
totoharibo
Re: Composite Video
Sat Jan 04, 2014 7:53 am
have a look there :
http://elinux.org/RPi_config.txt
I've heard of an option about that but not verified (too lazy this morning : sorry)
FTrevorGowen
Re: Composite Video
Sat Jan 04, 2014 10:19 am
USKeith wrote:New to the R-Pi world and using composite video. Composite video was working while loading Raspian Wheezy OS. Received message that installation was complete and hit ENTER to proceed. Composite Video went blank. I suspect R-Pi switched to HDMI Video when Raspian Wheezy started. Since I cannot see what is being displayed, how do I change the video output back to composite? I rebooted and believe that Raspian Wheezy is running, but the composite output does not show anything. Any suggestions?
Were you using the NOOBS installer? That defaults to HDMI for any installed O.S. unless you make composite permanent, as shown here: http://www.cpmspectrepi.webspace.virgin ... ellow.html
Trev.
Phill Rymer
Re: Composite Video
Sun Jan 05, 2014 8:56 pm
if your using a tv as monitor make sure you hace set composit video as imput source in menu of tv
USKeith
Re: Composite Video
Mon Jan 06, 2014 2:17 am
Thanks very much for your help! I did get the Pi to show video through the Composite output. After a few successful shutdown tests, it still seemed to work great!
Thanks again for your help.
