congia
wiringPi.h not found
Fri Jan 03, 2014 3:27 am
Hi, I just installed Wiring Pi and typing "gpio" confirmed it installed fine.
I'm trying to compile blink.c with
gcc -Wall -o blink blink.c -lwiringPi
(http://wiringpi.com/examples/blink/) and I'm getting
blink.c:1:22: fatal error: wiringpi.h: No such file or directory
I ran the find command and got:
sudo find / -name wiringPi.h
/home/pi/WiringPi2-Python/WiringPi/wiringPi/wiringPi.h
/home/pi/wiringPi/wiringPi/wiringPi.h
/usr/local/include/wiringPi.h
/usr/include/wiringPi.h
wiringPi.h is already included in the default include folder but it isn't getting picked up by GCC. How can I fix this problem?
DBryant
Re: wiringPi.h not found
Fri Jan 03, 2014 8:09 am
Use the -L option of gcc to add the path to the required file (see its man page or got to http://linux.die.net/man/1/gcc). Alternatively you could also define LIBRARY_PATH such that there was a common search list for all your software development.
congia
Fri Jan 03, 2014 2:31 pm
DBryant wrote:Use the -L option of gcc to add the path to the required file (see its man page or got to http://linux.die.net/man/1/gcc). Alternatively you could also define LIBRARY_PATH such that there was a common search list for all your software development.
Definitely gonna look at those. I found my problem though, it was pretty stupid actually. I was missing the capital 'P' in 'wiringPi'. Thank you for your reply.
Fri Jan 03, 2014 11:54 pm
Have you run
sudo -i
cd wiringPi # the directory where you downloaded it
./build
exit
congia
Sat Jan 04, 2014 12:02 am
Hey, it was my stupidity. I didn't capitalise the P in wiringPi.h. Everything is working fine now. Thanks for the help.
