Faegano
Can't run pygame script before starting x.
Tue Dec 31, 2013 12:57 am
I recently got a raspberry pi for Christmas and have created some very simple script in order to draw a circle on the screen with python, using pygame. This runs fine after starting up the GUI and activating it from the LXTerminal, however if I enter "python Circle.py" into the terminal after start up but before I start the GUI with "startx" the screen goes black and nothing happens.
Could anybody explain to me what is happening here.
DBryant
Re: Can't run pygame script before starting x.
Fri Jan 03, 2014 8:37 am
The startx command runs X11 and established a graphical environment for your system. Without this, or any other graphical system running, then you won't be able to draw circles and the like.
Faegano
Wed Jan 08, 2014 8:05 am
Ok, thank you. I understand now :D . Does this mean that the only way to run my script is through the terminal after starting the GUI?
scotty101
Wed Jan 08, 2014 10:12 am
Correct. Pygame needs an active "GUI" to display anything.
You can either run your script from a bash terminal in the GUI or using IDLE.
Electronic and Computer Engineer
Pi Interests: Home Automation, IOT, Python and Tkinter
Faegano
Wed Jan 08, 2014 10:06 pm
Thanks for the help :) .
Douglas6
Wed Jan 08, 2014 10:18 pm
That's just not true. I have some code somewhere that uses pygame writing to the Linux framebuffer. It was based on pyscope, from our friends at Adafruit.
Yup, I hauled out the code. You don't need X-windows for pygame, necessarily.
DBryant
Thu Jan 09, 2014 9:30 am
The key point is that a graphical environment is required. This could be X11, Qt or whatever but a library of graphical primitives will be required to write into the framestore for that graphical interface. Any program, be it Python, C/C++ as examples, may have one or more bindings of these graphical libraries with which it will inter-operate in order to carry out its function.
More details, specific to Pygame, can be found at http://www.pygame.org/wiki/gui. There is at least one discussion on this forum http://www.raspberrypi.org/phpBB3/viewt ... =32&t=7709
Or try Googling "python with X"
https://www.google.co.uk/search?q=pytho ... e&ie=UTF-8
Return to “Beginners”
