godsfshrmn
./build broken
Mon Dec 30, 2013 9:45 pm
I believe at some point I modified bash in some way that has broken the ./build command. When I try to build something, I get the following:
-bash: ./build: No such file or directory
Any tips please?
joan
Re: ./build broken
Mon Dec 30, 2013 9:50 pm
No such command is found on my system.
The ./ before build indicates that the command code should be in the current working directory.
Where did this command come from?
Have you changed directories?
godsfshrmn
Re: ./build broken
Mon Dec 30, 2013 9:53 pm
You're right. The git repository I cloned has a folder inside itself with the same name. I was one level too deep. Thanks!
