Hello I am trying to run my Raspberry PI on the Composite Video input as I do not have access to HDMI or HDMI/DVI at present.
When I first received my PI I managed with a small amount of trial & error to press 3 and managed to install then run Raspbian.
However I updated my SD Card with the new version of NOOBS and have had no success getting the PI running.
I even tried another SD Card and tried to put an edited config.txt on the root of the card with sdtv_mode=2 but this still didn't work.
The LED seems to flash 8 times and I've read that this means that the SD card cannot be read, perhaps the firmware file is not up to date. This can't be right if I'm running the latest NOOBS.
Can anyone offer any helpful suggestions?
I have a card reader on my Linux laptop that I've tried re-formatting and starting again.
Is there a definitive guide that lists all the necessary files?
In case it helps the PI is from RS in the UK part 756-8308 with a pre-installed card (that I stupidly overwrote).
