Darrenr75
Wifi problem- RALINK (Maplin)
Sun Dec 29, 2013 7:27 pm
Hi all,
I have a RPi model B, running Raspian Wheezy.
I bought the RALINK wifi adaptor from Maplin today.
I've run through many different forums to try and get this setup without success.
I'm using WPA2 on my wifi router. If I run dmesg | grep usb! I can see that my router signal is there.
Any tips please?
Re: Wifi problem- RALINK (Maplin)
Mon Dec 30, 2013 1:05 am
Plug it in.
Run an lsusb command
Search on here for the magic numbers that show up when the adapter is inserted.
https://www.google.com/search?q=XXXXXX+ ... errypi.org change XXXXXX to your magic numbers
Darrenr75
Mon Dec 30, 2013 1:24 pm
Thanks. I've checked some of those posts before. Nothing works on the RPi.
The device works fine on my Windows laptop.
I'm going to buy a powered usb hub and try it through there - when I plug the wifi adaptor in while the RPi is on, the whole device reboots itself so there could be an issue with power.
MrEngman
Mon Dec 30, 2013 1:29 pm
Darrenr75 wrote:Thanks. I've checked some of those posts before. Nothing works on the RPi.
The fact that the Pi reboots when you plug in the wifi adaptor is not unusual and is basically a problem with the Pi even if you have a good supply. It will reboot if you plug in almost any USB device if it takes it's power from the Pi.
MrEngman
Mon Dec 30, 2013 1:40 pm
I was hoping you'd post the magic numbers here so that we can better help you.
