jobrien44
Help: unmet dependencies: Blueman
Sat Dec 28, 2013 8:39 pm
Evening all,
Any help is appreciated, I'm completely new to the world of pi and dealing with install type issues.
My pi has a copy of "2013-12-20-wheezy-raspbian.img" installed as per this sites downloads section.
I have a wifi\bluetooth combo dongle, (BT-Micro3H2X) the wifi works fine but i'm having issues installing bluetooth GUI.
So far i have installed bluez and bluez-tools, If i run the '/etc/init.d/bluetooth Status' I get a 'Bluetooth is running' message.
My problem is when trying to install the bluetooth gui using the following ;
apt-get install bluetooth bluez-utils blueman
I get the following message:
blueman : Depends: obex-data-server (>= 0.4.3) but it is not going to be installed
E: Unable to correct problems, you have held broken packages.
Can anybody tell me (in simple terms) how to address this issue and install the Bluetooth GUI?
Thanks in advance
J.
rconry
Re: Help: unmet dependencies: Blueman
Mon Jan 06, 2014 7:31 pm
I am also having this issue...
Any help would be much appreciated :D
Jednorozec
Tue Jan 07, 2014 9:22 am
You have to fix the broken packages. Try
sudo dpkg --configure -a
If that doesn't work you can try
sudo apt-get install -f
Good luck.
The most important leg of a three legged stool is the one that's missing.
It's called thinking. Why don't you try it sometime?
BoskoStones
Tue Jan 07, 2014 10:44 am
I am having the same problem.
CODE: SELECT ALL
CODE: SELECT ALL
Good luck.
Did not seem to help.
BoskoStones
Tue Jan 07, 2014 10:45 am
CODE: SELECT ALL
CODE: SELECT ALL
Good luck.
rconry
Tue Jan 07, 2014 2:29 pm
When entering:
I am not returned any response, the terminal just waits for another command.
When entering:
It returns:
Reading package list...Done
Building dependency trees
Reading state information...Done
0 upgraded, 0 newly installed, 0 to remove and 1 not upgraded
Is there a command to remove the broken package (whatever is containing the obex-data-server) and then checking for updates again?
rconry
Tue Jan 07, 2014 3:35 pm
It seems I have found a solution!
using:
sudo aptitude install bluez-utils blueman
worked for me.
It will ask you if you wish to remove obexd-server and leave dependencies unresolved. I said yes and Bluetooth manager was successfully installed. Hope this helps
BoskoStones
Tue Jan 07, 2014 4:34 pm
sudo apt-get install obex-data-server
worked for me.
jobrien44
Tue Jan 07, 2014 11:23 pm
Evening all,
Thanks for your responses, i tried the 'sudo aptitude install bluez-utils blueman' command and this has now installed the bluetooth gui, i have been able to pair my BT mouse and will sort out the keyboard tomorrow.
Many many thanks for your help on this, it's much appreciated.
Jason
jobrien44
Thu Jan 09, 2014 9:13 pm
Just to get back to you and confirm the BT keyboard is now working.
Bit of a pig to pair up but working in the end.
Thanks you to everyone who helped me out here.
Jason.
Slapshot135
Sat Jun 20, 2015 3:40 pm
I have the Icon now and if I do hcitool scan, my device comes up, but i can't make the pi discoverable on the device
Return to “Off topic discussion”
