I didn't know that the kernel will kill progress who is using too much memory. I thought kernel would just return NULL when she don't have more memory for a new malloc call.
I think this would be a common problem for Raspberry Pi servers. Do we have to rewrite the server program to meet Raspberry Pi's memory capability? I'll post a same post on aria2 forum to ask for help.
Dec 28 16:07:48 raspberrypi kernel: [12343.878390] aria2c invoked oom-killer: gfp_mask=0x2084d0, order=0, oom_score_adj=0
Dec 28 16:07:48 raspberrypi kernel: [12343.878430] CPU: 0 PID: 1828 Comm: aria2c Not tainted 3.10.24+ #614
Dec 28 16:07:48 raspberrypi kernel: [12343.878505] [<c00139f8>] (unwind_backtrace+0x0/0xf0) from [<c0010d5c>] (show_stack+0x10/0x14)
Dec 28 16:07:48 raspberrypi kernel: [12343.878549] [<c0010d5c>] (show_stack+0x10/0x14) from [<c03fcdd8>] (dump_header.isra.13+0x74/0x1b0)
Dec 28 16:07:48 raspberrypi kernel: [12343.878587] [<c03fcdd8>] (dump_header.isra.13+0x74/0x1b0) from [<c0099c24>] (oom_kill_process+0x298/0x41c)
Dec 28 16:07:48 raspberrypi kernel: [12343.878620] [<c0099c24>] (oom_kill_process+0x298/0x41c) from [<c009a22c>] (out_of_memory+0x26c/0x2b8)
Dec 28 16:07:48 raspberrypi kernel: [12343.878655] [<c009a22c>] (out_of_memory+0x26c/0x2b8) from [<c009df50>] (__alloc_pages_nodemask+0x808/0x83c)
Dec 28 16:07:48 raspberrypi kernel: [12343.878699] [<c009df50>] (__alloc_pages_nodemask+0x808/0x83c) from [<c00b2c44>] (__pte_alloc+0x20/0x188)
Dec 28 16:07:48 raspberrypi kernel: [12343.878734] [<c00b2c44>] (__pte_alloc+0x20/0x188) from [<c00b5e98>] (handle_mm_fault+0xd0/0xe8)
Dec 28 16:07:48 raspberrypi kernel: [12343.878769] [<c00b5e98>] (handle_mm_fault+0xd0/0xe8) from [<c0403b5c>] (do_page_fault+0x224/0x3c4)
Dec 28 16:07:48 raspberrypi kernel: [12343.878799] [<c0403b5c>] (do_page_fault+0x224/0x3c4) from [<c000834c>] (do_DataAbort+0x34/0x98)
Dec 28 16:07:48 raspberrypi kernel: [12343.878838] [<c000834c>] (do_DataAbort+0x34/0x98) from [<c04025bc>] (__dabt_usr+0x3c/0x40)
Dec 28 16:07:48 raspberrypi kernel: [12343.878857] Exception stack(0xddb37fb0 to 0xddb37ff8)
Dec 28 16:07:48 raspberrypi kernel: [12343.878877] 7fa0: 00004019 00020381 23bfec68 23c02c80
Dec 28 16:07:48 raspberrypi kernel: [12343.878899] 7fc0: 23bfec70 00004019 b6b81258 23bfec68 00000398 23bff000 00004028 00024000
Dec 28 16:07:48 raspberrypi kernel: [12343.878919] 7fe0: 00000001 bee34998 b6b17d7c b6ac6474 60000010 ffffffff
Dec 28 16:07:48 raspberrypi kernel: [12343.878931] Mem-info:
Dec 28 16:07:48 raspberrypi kernel: [12343.878942] Normal per-cpu:
Dec 28 16:07:48 raspberrypi kernel: [12343.878956] CPU 0: hi: 186, btch: 31 usd: 81
Dec 28 16:07:48 raspberrypi kernel: [12343.878986] active_anon:58433 inactive_anon:57606 isolated_anon:0
Dec 28 16:07:48 raspberrypi kernel: [12343.878986] active_file:37 inactive_file:539 isolated_file:0
Dec 28 16:07:48 raspberrypi kernel: [12343.878986] unevictable:2 dirty:0 writeback:0 unstable:0
Dec 28 16:07:48 raspberrypi kernel: [12343.878986] free:3440 slab_reclaimable:410 slab_unreclaimable:1057
Dec 28 16:07:48 raspberrypi kernel: [12343.878986] mapped:71 shmem:3 pagetables:444 bounce:0
Dec 28 16:07:48 raspberrypi kernel: [12343.878986] free_cma:1398
Dec 28 16:07:48 raspberrypi kernel: [12343.879054] Normal free:13760kB min:8192kB low:10240kB high:12288kB active_anon:233732kB inactive_anon:230424kB active_file:148kB inactive_file:2156kB unevictable:8kB isolated(anon):0kB isolated(file):0kB present:507904kB managed:480420kB mlocked:8kB dirty:0kB writeback:0kB mapped:284kB shmem:12kB slab_reclaimable:1640kB slab_unreclaimable:4228kB kernel_stack:1056kB pagetables:1776kB unstable:0kB bounce:0kB free_cma:5592kB writeback_tmp:0kB pages_scanned:15475 all_unreclaimable? yes
Dec 28 16:07:48 raspberrypi kernel: [12343.879071] lowmem_reserve[]: 0 0
Dec 28 16:07:48 raspberrypi kernel: [12343.879087] Normal: 1432*4kB (UEC) 0*8kB 0*16kB 1*32kB (R) 1*64kB (R) 0*128kB 1*256kB (R) 1*512kB (R) 1*1024kB (R) 1*2048kB (R) 1*4096kB (R) = 13760kB
Dec 28 16:07:48 raspberrypi kernel: [12343.879154] 673 total pagecache pages
Dec 28 16:07:48 raspberrypi kernel: [12343.879170] 94 pages in swap cache
Dec 28 16:07:48 raspberrypi kernel: [12343.879183] Swap cache stats: add 26383, delete 26289, find 275/343
Dec 28 16:07:48 raspberrypi kernel: [12343.879193] Free swap = 48kB
Dec 28 16:07:48 raspberrypi kernel: [12343.879202] Total swap = 102396kB
Dec 28 16:07:48 raspberrypi kernel: [12343.911996] 126976 pages of RAM
Dec 28 16:07:48 raspberrypi kernel: [12343.912023] 3639 free pages
Dec 28 16:07:48 raspberrypi kernel: [12343.912034] 2739 reserved pages
Dec 28 16:07:48 raspberrypi kernel: [12343.912042] 1011 slab pages
Dec 28 16:07:48 raspberrypi kernel: [12343.912051] 144 pages shared
Dec 28 16:07:48 raspberrypi kernel: [12343.912060] 106 pages swap cached
Dec 28 16:07:48 raspberrypi kernel: [12343.912071] [ pid ] uid tgid total_vm rss nr_ptes swapents oom_score_adj name
Dec 28 16:07:48 raspberrypi kernel: [12343.912116] [ 156] 0 156 721 0 5 133 -1000 udevd
Dec 28 16:07:48 raspberrypi kernel: [12343.912197] [ 287] 0 287 720 0 5 135 -1000 udevd
Dec 28 16:07:48 raspberrypi kernel: [12343.912219] [ 288] 0 288 720 0 5 134 -1000 udevd
Dec 28 16:07:48 raspberrypi kernel: [12343.912275] [ 1526] 0 1526 1224 0 5 428 0 dhclient
Dec 28 16:07:48 raspberrypi kernel: [12343.912298] [ 1828] 0 1828 141151 115676 278 23390 0 aria2c
Dec 28 16:07:48 raspberrypi kernel: [12343.912318] [ 1879] 0 1879 6993 58 7 58 0 rsyslogd
Dec 28 16:07:48 raspberrypi kernel: [12343.912338] [ 1932] 104 1932 794 17 5 50 0 dbus-daemon
Dec 28 16:07:48 raspberrypi kernel: [12343.912372] [ 1947] 0 1947 2473 18 8 99 0 nmbd
Dec 28 16:07:48 raspberrypi kernel: [12343.912393] [ 1968] 107 1968 1321 17 6 36 0 dnsmasq
Dec 28 16:07:48 raspberrypi kernel: [12343.912412] [ 1970] 0 1970 4705 67 12 102 0 smbd
Dec 28 16:07:48 raspberrypi kernel: [12343.912431] [ 1989] 0 1989 4834 30 11 137 0 smbd
Dec 28 16:07:48 raspberrypi kernel: [12343.912451] [ 2050] 0 2050 1086 18 6 23 0 cron
Dec 28 16:07:48 raspberrypi kernel: [12343.912470] [ 2087] 102 2087 1378 50 6 57 0 ntpd
Dec 28 16:07:48 raspberrypi kernel: [12343.912491] [ 2113] 0 2113 6600 19 7 11 0 rngd
Dec 28 16:07:48 raspberrypi kernel: [12343.912510] [ 2135] 0 2135 1553 6 5 100 -1000 sshd
Dec 28 16:07:48 raspberrypi kernel: [12343.912530] [ 2178] 65534 2178 504 4 5 26 0 thd
Dec 28 16:07:48 raspberrypi kernel: [12343.912549] [ 2184] 33 2184 1667 71 7 139 0 lighttpd
Dec 28 16:07:48 raspberrypi kernel: [12343.912578] [ 2210] 0 2210 1073 0 6 32 0 getty
Dec 28 16:07:48 raspberrypi kernel: [12343.912598] [ 2211] 0 2211 1073 0 6 32 0 getty
Dec 28 16:07:48 raspberrypi kernel: [12343.912620] [ 2212] 0 2212 1073 0 6 32 0 getty
Dec 28 16:07:48 raspberrypi kernel: [12343.912639] [ 2213] 0 2213 1073 0 6 32 0 getty
Dec 28 16:07:48 raspberrypi kernel: [12343.912658] [ 2214] 0 2214 1073 0 4 32 0 getty
Dec 28 16:07:48 raspberrypi kernel: [12343.912677] [ 2215] 0 2215 1073 0 6 32 0 getty
Dec 28 16:07:48 raspberrypi kernel: [12343.912696] [ 2216] 0 2216 516 0 5 31 0 getty
Dec 28 16:07:48 raspberrypi kernel: [12343.912717] [ 2230] 0 2230 6885 0 10 268 0 console-kit-dae
Dec 28 16:07:48 raspberrypi kernel: [12343.912738] [ 2297] 0 2297 5571 0 8 119 0 polkitd
Dec 28 16:07:48 raspberrypi kernel: [12343.912860] Out of memory: Kill process 1828 (aria2c) score 900 or sacrifice child
Dec 28 16:07:48 raspberrypi kernel: [12343.912882] Killed process 1828 (aria2c) total-vm:564604kB, anon-rss:462516kB, file-rss:188kB
