muchotreeo258
how do I set up the wifi
Fri Dec 27, 2013 7:11 pm
I tried going to the network manager and adding my connection, and it worked on my last install but because of over overscan issues I had to reinstall, and now it won't work.
Re: how do I set up the wifi
Fri Dec 27, 2013 10:14 pm
What's in your /etc/network/interfaces and /etc/wpa_supplicant/wpa_supplicant.conf?
Here's mine (set-up with a fixed IP address)
/e*/n*/interfaces
auto lo
auto wlan0
iface lo inet loopback
iface eth0 inet dhcp
allow-hotplug wlan0
#wireless-power off
iface wlan0 inet manual
address 192.168.1.7
gateway 192.168.1.1
netmask 255.255.255.0
wpa-roam /etc/wpa_supplicant/wpa_supplicant.conf
iface default inet static
address 192.168.1.7
gateway 192.168.1.1
and /e*/wpa_*/wpa_supplicant.conf
update_config=1
network={
 ssid="REDACTEDSSID"
 scan_ssid=1
 psk="redactedpassword"
Lob0426
Fri Dec 27, 2013 10:50 pm
Here is a simpler version that works for most people.
this is for WPA2
cd /etc/network
sudo nano interfaces
auto lo
allow-hotplug wlan0
iface wlan0 inet dhcp
wpa-ssid "your SSID"
wpa-psk "Your wifi password"
512MB version 2.0 as WordPress Server
Motorola Lapdock with Pi2B
Modded Rev 1.0 with pin headers at USB
http://rich1.dyndns.tv/
(RS)Allied ships old stock to reward its Customers for long wait!
Fri Dec 27, 2013 10:52 pm
Yours may be simpler but it's missing auto eth0 and auto wlan0 to get the interfaces started at boot up.
MrEngman
Fri Dec 27, 2013 11:53 pm
DougieLawson wrote:Yours may be simpler but it's missing auto eth0 and auto wlan0 to get the interfaces started at boot up.
And neither has mine but both eth0 and wlan0 connect when I boot/reboot. And both connect when booting if they are both connected.
login as: pi
pi@192.168.16.27's password:
Linux raspberrypi 3.10.25+ #616 PREEMPT Mon Dec 23 18:13:02 GMT 2013 armv6l
The programs included with the Debian GNU/Linux system are free software;
the exact distribution terms for each program are described in the
individual files in /usr/share/doc/*/copyright.
Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
permitted by applicable law.
Last login: Fri Dec 27 06:35:37 2013
pi@raspberrypi ~ $ ifconfig
eth0      Link encap:Ethernet  HWaddr b8:27:eb:19:f0:e0
          inet addr:192.168.16.27  Bcast:192.168.16.255  Mask:255.255.255.0
          UP BROADCAST RUNNING MULTICAST  MTU:1500  Metric:1
          RX packets:114 errors:0 dropped:0 overruns:0 frame:0
          TX packets:75 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 txqueuelen:1000
          RX bytes:12250 (11.9 KiB)  TX bytes:11407 (11.1 KiB)
lo        Link encap:Local Loopback
          inet addr:127.0.0.1  Mask:255.0.0.0
          UP LOOPBACK RUNNING  MTU:65536  Metric:1
          RX packets:0 errors:0 dropped:0 overruns:0 frame:0
          TX packets:0 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 txqueuelen:0
          RX bytes:0 (0.0 B)  TX bytes:0 (0.0 B)
wlan0     Link encap:Ethernet  HWaddr a0:f3:c1:25:7d:28
          inet addr:192.168.16.24  Bcast:192.168.16.255  Mask:255.255.255.0
          RX packets:57 errors:0 dropped:2 overruns:0 frame:0
          TX packets:4 errors:0 dropped:0 overruns:0 carrier:0
          RX bytes:7423 (7.2 KiB)  TX bytes:1028 (1.0 KiB)
And /etc/network/interfaces is currently
pi@raspberrypi ~ $ cat /etc/network/interfaces
auto lo
allow-hotplug wlan0
wpa-ssid "network-name"
wpa-psk "network-password"
allow-hotplug wlan1
iface wlan1 inet dhcp
#iface wlan0 inet manual
#wpa-roam /etc/wpa_supplicant/wpa_supplicant.conf
#iface default inet dhcp
pi@raspberrypi ~ $
And no auto eth0 or auto wlan0/wlan1 and it's been pretty much similar to that since I started using the Pi in Apr 2012. auto eth0 was required before debian wheezy appeared but was remove in the default /etc/network/interfaces included since.
You really don't need auto wlan0 if you have allow-hotpug wlan0 included as they both behave similarly.
MrEngman
muchotreeo258
Sat Dec 28, 2013 1:28 am
I dont have a network folder
MrEngman
Sat Dec 28, 2013 1:47 am
muchotreeo258 wrote:I dont have a network folder
OK, what software image are you using? The above is typical for Raspbian. What are you using?
MrEngman
muchotreeo258
Sat Dec 28, 2013 2:07 am
pidora
MrEngman
Sat Dec 28, 2013 2:34 am
muchotreeo258 wrote:pidora
Ah. I've never tried Pidora so I have no idea how the wifi is set up on it. Will take a look and see how it is configured but it is way past my bed time now so I will have to do that in the morning.
MrEngman
MrEngman
Sat Dec 28, 2013 5:50 pm
Hi muchotreeo258,
Well I tried Pidora and I certainly won't be using it again. How complicated, almost as bad as Windows 8 to get working
Anyway I got the wifi working without any problem other than trying to figure out how to configure Pidora.
Ended up setting it to boot into a graphical window, logged in as root and then the window appeared with the menu bar across the top. Selected the network icon on the top right hand side and selected my wifi, input the password and it connected.
Logging in as a different user and the menu bar was not there and I couldn't get the network manager running or at least I could not see it running.
MrEngman
klricks
Tue Dec 31, 2013 2:10 am
muchotreeo258 wrote:I tried going to the network manager and adding my connection, and it worked on my last install but because of over overscan issues I had to reinstall, and now it won't work.
Make sure you are using the network connect button on the top bar between the time and user name.
At first I was trying to use the network config under settings in the applications menu and could not get anything to work. Once I found that network button I had WIFI working in seconds.
I also bagged Pidora for now. It's just not ready for prime time. Simple things just don't work without a lot of fussing. I even run Fedora 19 on a desktop so I am somewhat familiar with it.
Return to “Pidora / Fedora”
