davidtjackson
Coloured splash screen woes
Thu Dec 26, 2013 4:24 pm
Hi all,
Wondering if someone can come to my rescue.
I can't get my Pi to boot. I'm stuck on the coloured splash screen.
I've read around the common non booting guides:
http://elinux.org/R-Pi_Troubleshooting# ... F_Start-up
http://www.raspberrypi.org/phpBB3/viewt ... 28&t=58151
However, I can't seem to make any progress.
I've got the model B Pi. I know my power supply is sufficient and I've tried the latest version of NOOBS on several different SD cards, ensuring they're formatted correctly and also that the NOOBS files are coped over correctly.
When I plug the power in to my Pi, I get a constant red PWR light and one flash of the green ACT light.
Even without the SD card in, I can still get the coloured splash screen.
I know one solution is adding the "boot_delay=1" to the to the config.txt file. However, I can't find that file anywhere on my SD card.
Does anyone have any idea what's going on?
Dave
mahjongg
Re: Coloured splash screen woes
Thu Dec 26, 2013 4:48 pm
That's impossible, without the SD-card the PI cannot load the "BIOS" code that creates this GPU test pattern you call a "splash screen".
If it boots until the test pattern, that means it doesn't see the first ARM boot code.
NOOBS itself doesn't use the config.txt file, it is only until it creates raspbian that the config.txt file is created, but before that happens you can edit the version that will be created using the editor built into noobs itself.
davidtjackson
Thu Dec 26, 2013 5:10 pm
Sorry - my mistake.
Yeah, of course nothing without the SD card.
Still none the wiser why things aren't booting at all.
chalky3000
Thu Dec 26, 2013 8:55 pm
I too am having the exact same problem. New to these as bought for my son. any help much appreciated.
Chalky
gsh
Thu Dec 26, 2013 9:10 pm
You can create a config.txt file on the SD card in the recovery section... It will get loaded...
Just create that one file with that one line and see if it makes a difference... I'd be very interested if it does because we've seen this problem recently (although not very high rate)...
Is the SDRAM Micron (Big M on the top of the processor chip)
Gordon
Gordon Hollingworth PhD
chalky3000
Thu Dec 26, 2013 9:44 pm
Thanks, There is a big M on the processor.
to fill in some blanks along the way...
This is a new version 2 Pi that was supplied with an 8mb Sd card and pre installed NOOBS
I am using a VGA monitor with a HDMI - VGA adaptor (this is a powered version)
I was having the coloured screen issue and not getting past that point. I tried a different power supply (both were 1A) and the pi booted to the Install OS page. I selected Raspbian and it appeared to go ok - to 100%, Clicked ok and the screen went blank, stayed blank for 5 mins till I pulled the power. (all the time I only had the solid red power lamp illuminated). When the power was restored the coloured screen came back and nothing else. Retried several times but no joy.
Second attempt was to reformat the SD card and download the latest NOOBS. repeated the above and now back to where I was before - rainbow screen.
Chalky
chalky3000
Thu Dec 26, 2013 9:49 pm
Should I still try the confic.txt file thing?
Chalky
gsh
Thu Dec 26, 2013 9:59 pm
OK, it seems this is the same issue as the hardware I've got on my desk at PiTowers, so it's nothing you're doing wrong. It would be very useful if you could try the config.txt thing for NOOBS (and the Raspbian OS as well, if you get into NOOBS, select the Raspbian OS you have installed and then click "Edit config.txt" button)
Gordon
chalky3000
Thu Dec 26, 2013 10:14 pm
Ok you'll have to go a bit slower with me, sorry.
So
1, config.txt file. I create one and save it in the recovery section but what line of txt goes in it?
2, Will I need to reformat my SD card and copy the NOOBS across again before doing this? Or will it just work if I put it in the recovery section?
chalky
Thu Dec 26, 2013 10:27 pm
I'd start by ensuring that all of NOOBS was copied to your SDCard (there's some other threads where some hidden files get missed by Windows copy).
TwistedTurns
Thu Dec 26, 2013 10:30 pm
I am having the same problem, bought a kit from amazon.co.uk that came with a 4gb SD card with NOOBS (the seller is NEW IT newit.co.uk - http://www.amazon.co.uk/exec/obidos/ASI ... os_product) before xmas as a present for my nephew, he tried to boot and got stuck at the multi-coloured screen, having a few times it was clear it wasn't the sd card fitting. Tried to download the latest NOOB 1.3.3 and used that and could get it to boot to NOOB, which I then installed Raspbian, this gave the NOOB message about successfully installing and clicking "ok" it just black screened, I left it for 10 minutes and then removed and re-applied the power and again it stuck at the multi-coloured screen.
I did some reading and saw some references to boot_delay=1, so to the BOOT partition, I added that to the config.txt and also uncomment the first hdmi option in config.txt (someone else suggested this might also be contributing), rebooted and this still gave the multi-coloured screen.
Done some more reading and founds someone mentioning that NOOBS 1.3.3 needs an SD Card bigger than 4gb for Raspbian, so popped out to buy a 16gb SD Card today, repeated the initialisation of SD card, copied over NOOBS 1.3.3 and it booted again, installed Raspbian, again it hung after clicking "ok", after 10 or so minutes I removed and re-applied power and the raspberry hung at the multi-coloured screen, I repeated the SD card format again (on my mac) and copied NOOBS again and re-installed again this time setting the boot_delay=1, again it hung after clicking "ok" to confirm that the install of raspbian had finished and removing and re-applying the power returned the raspberry to the multi-coloured screen.
At this point it feels like there is either something wrong with the hardware or something wrong with raspbian. There is an M on the processor (with a circle over it), could this be related to the issue seen at "PiTowers"? I have attached a photo of the chip to confirm that is the "M" you are referring to.
Thanks,
Jason.
phree
Thu Dec 26, 2013 10:36 pm
This sounds just like the issue I'm having and I posted elsewhere so would be interested in the solution.
Just learning the way....
chalky3000
Thu Dec 26, 2013 10:43 pm
OK, I have re read the whole post now and created the config.txt file with 'boot_delay=1' in, saved it in the recovery section without reformatting and reinstalling NOOBS, it and this got me past the rainbow screen, Raspberry icon in top left & a pile of txt rolled up and stayed there ending in 'more>' no flashing curser and no keyboard activity. powered down after a couple of mins and rebooted. This time I went past the rainbow screen but its now just giving me a black screen - no curser.
Chalky
davidtjackson
Thu Dec 26, 2013 11:13 pm
Hi Gordon,
No joy with this I'm afraid, that file still doesn't seem to be getting me past this dreaded colour splash.
gsh wrote:You can create a config.txt file on the SD card in the recovery section... It will get loaded...
Gordon
davidtjackson
Thu Dec 26, 2013 11:19 pm
Just for the avoidance of any doubt here, I wanted to check that all the files are being extracted and copied over correctly. (I've used a few different extraction tools and operating systems and getting the same each time). Hopefully, I'm not missing anything
From NOOBS v1.3.3 I'm extracting the following onto my SD card.
(nine files, two folders). Not listing any files in either folder
defaults (folder)
os (folder)
bootcode.bin
BUILD-DATA
INSTRUCTIONS-README
recovery.cmdline
recovery.elf
recovery
recovery.rfs
RECOVERY_FILES_DO_NOT_EDIT
riscos-boot.bin
Does that all look correct?
DougieLawson wrote:I'd start by ensuring that all of NOOBS was copied to your SDCard (there's some other threads where some hidden files get missed by Windows copy).
Thu Dec 26, 2013 11:22 pm
Download a new copy of NOOBS 1.3.3 (or NOOBS lite) from http://raspberrypi.org/downloads
Unzip it directly onto your SDCard (or if you unzip to a Windows folder, then ensure you copy everything including hidden files)
Try that in the RPi.
Here's a file listing of NOOBS 1.3.2
NOOBS 1.3.3 will be slightly different.
chalky3000
Thu Dec 26, 2013 11:28 pm
I'm listing 87 files and 16 folders, including the config.txt I created and this seems to be consistant with the unzipped folder. Is it likely the unzipped folder won't have all the files?
Chalky
Thu Dec 26, 2013 11:54 pm
Here's the file listings. Done on both Linux & Windows.
LINUX:
NOOBS_v1_3_3:
total 22664
drwxr-xr-x  4 root root     4096 Dec 26 23:51 .
drwxr-xr-x 30 root root     4096 Dec 26 23:51 ..
-rw-r--r--  1 root root    17824 Nov  2 10:21 bootcode.bin
-rw-r--r--  1 root root      346 Dec 23 21:42 BUILD-DATA
drwxr-xr-x  3 root root       19 Sep 27 14:41 defaults
-rw-r--r--  1 root root     2249 Nov  2 10:21 INSTRUCTIONS-README.txt
drwxr-xr-x  9 root root      109 Oct 13 16:47 os
-rw-r--r--  1 root root       71 Nov  2 10:21 recovery.cmdline
-rw-r--r--  1 root root   471736 Nov  2 10:21 recovery.elf
-rw-r--r--  1 root root        0 Nov  2 10:21 RECOVERY_FILES_DO_NOT_EDIT
-rwxr-xr-x  1 root root  2093824 Nov  2 10:21 recovery.img
-rw-r--r--  1 root root 20579519 Nov  2 10:21 recovery.rfs
-rw-r--r--  1 root root     9728 Nov  2 10:21 riscos-boot.bin
NOOBS_v1_3_3/defaults:
total 4
drwxr-xr-x 3 root root   19 Sep 27 14:41 .
drwxr-xr-x 4 root root 4096 Dec 26 23:51 ..
drwxr-xr-x 2 root root   18 Sep 27 14:41 slides
NOOBS_v1_3_3/defaults/slides:
total 40
drwxr-xr-x 2 root root    18 Sep 27 14:41 .
drwxr-xr-x 3 root root    19 Sep 27 14:41 ..
-rw-r--r-- 1 root root 40113 Nov  2 10:21 A.png
NOOBS_v1_3_3/os:
total 24
drwxr-xr-x 9 root root  109 Oct 13 16:47 .
drwxr-xr-x 3 root root 4096 Oct 13 16:49 Arch
drwxr-xr-x 2 root root   85 Oct 14 18:55 data_partition
drwxr-xr-x 3 root root 4096 Oct 13 16:49 OpenELEC
drwxr-xr-x 3 root root 4096 Oct 13 16:50 Pidora
drwxr-xr-x 3 root root 4096 Oct 13 16:51 Raspbian
drwxr-xr-x 3 root root 4096 Oct 13 16:52 RaspBMC
drwxr-xr-x 3 root root  120 Oct 13 16:52 RISC_OS
NOOBS_v1_3_3/os/Arch:
total 115112
drwxr-xr-x 3 root root      4096 Oct 13 16:49 .
drwxr-xr-x 9 root root       109 Oct 13 16:47 ..
-rwxr-xr-x 1 root root      1529 Dec 24 09:49 Arch.png
-rw-r--r-- 1 root root  14958972 Dec 24 09:50 boot.tar.xz
-rw-r--r-- 1 root root       293 Dec 24 09:51 os.json
-rw-r--r-- 1 root root       634 Oct 13 16:46 partition_setup.sh
-rw-r--r-- 1 root root       662 Dec 24 09:53 partitions.json
-rw-r--r-- 1 root root        45 Oct 13 16:46 release_notes.txt
-rw-r--r-- 1 root root 102884388 Dec 24 09:51 root.tar.xz
drwxr-xr-x 2 root root        66 Aug 29 09:42 slides_vga
NOOBS_v1_3_3/os/Arch/slides_vga:
total 372
drwxr-xr-x 2 root root    66 Aug 29 09:42 .
drwxr-xr-x 3 root root  4096 Oct 13 16:49 ..
-rw-r--r-- 1 root root 57815 Sep  2 17:59 A.png
-rw-r--r-- 1 root root 65847 Sep  2 17:59 B.png
-rw-r--r-- 1 root root 77839 Sep  2 17:59 C.png
-rw-r--r-- 1 root root 66326 Sep  2 17:59 D.png
-rw-r--r-- 1 root root 93585 Sep  2 17:59 E.png
NOOBS_v1_3_3/os/data_partition:
total 16
drwxr-xr-x 2 root root   85 Oct 14 18:55 .
-rwxr-xr-x 1 root root 1335 Oct 14 18:55 Data_Partition.png
-rw-r--r-- 1 root root  332 Oct 14 18:55 data.tar.xz
-rw-r--r-- 1 root root  143 Oct 14 18:55 os.json
-rw-r--r-- 1 root root  225 Oct 14 18:55 partitions.json
NOOBS_v1_3_3/os/OpenELEC:
total 81800
-rw-r--r-- 1 root root     2598 Oct 13 16:46 OpenELEC.png
-rw-r--r-- 1 root root      262 Oct 13 16:46 os.json
-rwxr-xr-x 1 root root     2391 Oct 13 16:46 partition_setup.sh
-rw-r--r-- 1 root root      549 Oct 13 16:46 partitions.json
-rw-r--r-- 1 root root       82 Oct 13 16:46 release_notes.txt
drwxr-xr-x 2 root root       66 Sep 14 01:08 slides_vga
-rw-r--r-- 1 root root      164 Oct 13 16:46 Storage.tar.xz
-rw-r--r-- 1 root root 83734092 Oct 13 16:46 System.tar.xz
NOOBS_v1_3_3/os/OpenELEC/slides_vga:
total 140
drwxr-xr-x 2 root root    66 Sep 14 01:08 .
-rw-r--r-- 1 root root 24305 Sep 14 01:08 A.png
-rw-r--r-- 1 root root 29013 Sep 14 01:08 B.png
-rw-r--r-- 1 root root 28657 Sep 14 01:08 C.png
-rw-r--r-- 1 root root 23974 Sep 14 01:08 D.png
-rw-r--r-- 1 root root 25902 Sep 14 01:08 E.png
NOOBS_v1_3_3/os/Pidora:
total 365932
drwxr-xr-x 3 root root      4096 Oct 13 16:50 .
-rw-r--r-- 1 root root  14318404 Nov  4 17:54 boot.tar.xz
-rw-r--r-- 1 root root       204 Nov  4 17:55 os.json
-rw-r--r-- 1 root root       478 Nov  4 17:55 partition_setup.sh
-rw-r--r-- 1 root root       389 Nov  4 17:55 partitions.json
-rw-r--r-- 1 root root      2131 Oct 13 16:46 Pidora.png
-rw-r--r-- 1 root root      7377 Oct 13 16:46 release-notes.txt
-rw-r--r-- 1 root root 360359468 Nov  4 17:54 rootfs.tar.xz
drwxr-xr-x 2 root root        66 Sep  9 11:20 slides_vga
NOOBS_v1_3_3/os/Pidora/slides_vga:
total 332
drwxr-xr-x 2 root root    66 Sep  9 11:20 .
drwxr-xr-x 3 root root  4096 Oct 13 16:50 ..
-rw-r--r-- 1 root root 21107 Sep 13 16:14 A.png
-rw-r--r-- 1 root root 63679 Sep 13 16:19 B.png
-rw-r--r-- 1 root root 84260 Sep 13 16:21 C.png
-rw-r--r-- 1 root root 81473 Sep 13 16:22 D.png
-rw-r--r-- 1 root root 77486 Sep 13 16:23 E.png
NOOBS_v1_3_3/os/Raspbian:
total 544620
drwxr-xr-x 3 root root      4096 Oct 13 16:51 .
-rw-r--r-- 1 root root  14755400 Dec 24 09:56 boot.tar.xz
-rw-r--r-- 1 root root       275 Oct 13 16:46 flavours.json
-rw-r--r-- 1 root root       278 Dec 24 09:55 os.json
-rw-r--r-- 1 root root       419 Oct 13 16:46 partition_setup.sh
-rw-r--r-- 1 root root       445 Dec 24 09:54 partitions.json
-rw-r--r-- 1 root root      2857 Oct 13 16:46 Raspbian_-_Boot_to_Scratch.png
-rwxr-xr-x 1 root root      1662 Oct 13 16:46 Raspbian.png
-rw-r--r-- 1 root root      1099 Dec 24 09:56 release_notes.txt
-rw-r--r-- 1 root root 542895692 Dec 24 09:56 root.tar.xz
drwxr-xr-x 2 root root        90 Jun 13  2013 slides_vga
NOOBS_v1_3_3/os/Raspbian/slides_vga:
total 244
drwxr-xr-x 2 root root    90 Jun 13  2013 .
drwxr-xr-x 3 root root  4096 Oct 13 16:51 ..
NOOBS_v1_3_3/os/RaspBMC:
total 148788
drwxr-xr-x 3 root root      4096 Oct 13 16:52 .
-rw-r--r-- 1 root root   6672500 Dec 24 09:57 boot.tar.xz
-rw-r--r-- 1 root root       204 Dec 24 10:06 os.json
-rw-r--r-- 1 root root       504 Oct 13 16:46 partition_setup.sh
-rw-r--r-- 1 root root       445 Dec 24 10:08 partitions.json
-rwxr-xr-x 1 root root      2325 Oct 13 16:46 RaspBMC.png
-rw-r--r-- 1 root root       701 Dec 24 09:57 release_notes.txt
-rw-r--r-- 1 root root 145654664 Dec 24 09:57 root.tar.xz
NOOBS_v1_3_3/os/RaspBMC/slides_vga:
total 140
drwxr-xr-x 3 root root  4096 Oct 13 16:52 ..
-rw-r--r-- 1 root root 27126 Dec 24 10:02 A.png
-rw-r--r-- 1 root root 29205 Dec 24 10:02 B.png
-rw-r--r-- 1 root root 26883 Dec 24 10:02 C.png
-rw-r--r-- 1 root root 29060 Dec 24 10:02 D.png
-rw-r--r-- 1 root root 15259 Dec 24 10:03 E.png
NOOBS_v1_3_3/os/RISC_OS:
total 68684
drwxr-xr-x 3 root root      120 Oct 13 16:52 .
-rw-r--r-- 1 root root      269 Oct 13 16:46 os.json
-rw-r--r-- 1 root root      487 Oct 13 16:46 partitions.json
-rw-r--r-- 1 root root  2544832 Oct 13 16:46 RISC_OS_Boot.tar.xz
-rw-r--r-- 1 root root     3151 Oct 13 16:46 RISC_OS.png
-rw-r--r-- 1 root root 67770876 Oct 13 16:46 RISC_OS.xz
drwxr-xr-x 2 root root       42 Aug 29 09:42 slides_vga
NOOBS_v1_3_3/os/RISC_OS/slides_vga:
total 264
drwxr-xr-x 2 root root    42 Aug 29 09:42 .
drwxr-xr-x 3 root root   120 Oct 13 16:52 ..
-rw-r--r-- 1 root root 71572 Aug 29 09:42 A.png
-rw-r--r-- 1 root root 96935 Aug 29 09:42 B.png
-rw-r--r-- 1 root root 95710 Aug 29 09:42 C.png
WINDOWS:
 Volume in drive Z is shared
 Volume Serial Number is EBA2-DA4F
 Directory of Z:\RaspPi\NOOBS_v1_3_3
26/12/2013  23:48    <DIR>          .
26/12/2013  23:32    <DIR>          ..
02/11/2013  10:21            17,824 bootcode.bin
23/12/2013  21:42               346 BUILD-DATA
27/09/2013  14:41    <DIR>          defaults
02/11/2013  10:21             2,249 INSTRUCTIONS-README.txt
13/10/2013  16:47    <DIR>          os
02/11/2013  10:21                71 recovery.cmdline
02/11/2013  10:21           471,736 recovery.elf
02/11/2013  10:21                 0 RECOVERY_FILES_DO_NOT_EDIT
02/11/2013  10:21         2,093,824 recovery.img
02/11/2013  10:21        20,579,519 recovery.rfs
02/11/2013  10:21             9,728 riscos-boot.bin
               9 File(s)     23,175,297 bytes
 Directory of Z:\RaspPi\NOOBS_v1_3_3\defaults
27/09/2013  14:41    <DIR>          .
26/12/2013  23:48    <DIR>          ..
27/09/2013  14:41    <DIR>          slides
               0 File(s)              0 bytes
 Directory of Z:\RaspPi\NOOBS_v1_3_3\defaults\slides
27/09/2013  14:41    <DIR>          ..
02/11/2013  10:21            40,113 A.png
               1 File(s)         40,113 bytes
 Directory of Z:\RaspPi\NOOBS_v1_3_3\os
13/10/2013  16:47    <DIR>          .
13/10/2013  16:49    <DIR>          Arch
13/10/2013  16:52    <DIR>          RaspBMC
13/10/2013  16:50    <DIR>          Pidora
13/10/2013  16:49    <DIR>          OpenELEC
13/10/2013  16:52    <DIR>          RISC_OS
14/10/2013  18:55    <DIR>          data_partition
13/10/2013  16:51    <DIR>          Raspbian
               0 File(s)              0 bytes
 Directory of Z:\RaspPi\NOOBS_v1_3_3\os\Arch
13/10/2013  16:49    <DIR>          .
13/10/2013  16:47    <DIR>          ..
24/12/2013  09:51               293 os.json
24/12/2013  09:51       102,884,388 root.tar.xz
24/12/2013  09:53               662 partitions.json
13/10/2013  16:46               634 partition_setup.sh
13/10/2013  16:46                45 release_notes.txt
24/12/2013  09:49             1,529 Arch.png
29/08/2013  09:42    <DIR>          slides_vga
24/12/2013  09:50        14,958,972 boot.tar.xz
               7 File(s)    117,846,523 bytes
 Directory of Z:\RaspPi\NOOBS_v1_3_3\os\Arch\slides_vga
29/08/2013  09:42    <DIR>          .
13/10/2013  16:49    <DIR>          ..
02/09/2013  17:59            77,839 C.png
02/09/2013  17:59            57,815 A.png
02/09/2013  17:59            66,326 D.png
02/09/2013  17:59            65,847 B.png
02/09/2013  17:59            93,585 E.png
               5 File(s)        361,412 bytes
 Directory of Z:\RaspPi\NOOBS_v1_3_3\os\RaspBMC
13/10/2013  16:52    <DIR>          .
24/12/2013  10:06               204 os.json
24/12/2013  09:57       145,654,664 root.tar.xz
24/12/2013  10:08               445 partitions.json
13/10/2013  16:46             2,325 RaspBMC.png
13/10/2013  16:46               504 partition_setup.sh
24/12/2013  09:57               701 release_notes.txt
24/12/2013  09:57         6,672,500 boot.tar.xz
               7 File(s)    152,331,343 bytes
 Directory of Z:\RaspPi\NOOBS_v1_3_3\os\RaspBMC\slides_vga
13/10/2013  16:52    <DIR>          ..
24/12/2013  10:02            26,883 C.png
24/12/2013  10:02            27,126 A.png
24/12/2013  10:02            29,060 D.png
24/12/2013  10:02            29,205 B.png
24/12/2013  10:03            15,259 E.png
               5 File(s)        127,533 bytes
 Directory of Z:\RaspPi\NOOBS_v1_3_3\os\Pidora
13/10/2013  16:50    <DIR>          .
04/11/2013  17:55               204 os.json
13/10/2013  16:46             7,377 release-notes.txt
04/11/2013  17:55               389 partitions.json
04/11/2013  17:55               478 partition_setup.sh
09/09/2013  11:20    <DIR>          slides_vga
13/10/2013  16:46             2,131 Pidora.png
04/11/2013  17:54       360,359,468 rootfs.tar.xz
04/11/2013  17:54        14,318,404 boot.tar.xz
               7 File(s)    374,688,451 bytes
 Directory of Z:\RaspPi\NOOBS_v1_3_3\os\Pidora\slides_vga
09/09/2013  11:20    <DIR>          .
13/10/2013  16:50    <DIR>          ..
13/09/2013  16:21            84,260 C.png
13/09/2013  16:14            21,107 A.png
13/09/2013  16:22            81,473 D.png
13/09/2013  16:19            63,679 B.png
13/09/2013  16:23            77,486 E.png
               5 File(s)        328,005 bytes
 Directory of Z:\RaspPi\NOOBS_v1_3_3\os\OpenELEC
13/10/2013  16:46               262 os.json
13/10/2013  16:46               549 partitions.json
13/10/2013  16:46             2,391 partition_setup.sh
13/10/2013  16:46                82 release_notes.txt
13/10/2013  16:46             2,598 OpenELEC.png
14/09/2013  01:08    <DIR>          slides_vga
13/10/2013  16:46        83,734,092 System.tar.xz
13/10/2013  16:46               164 Storage.tar.xz
               7 File(s)     83,740,138 bytes
 Directory of Z:\RaspPi\NOOBS_v1_3_3\os\OpenELEC\slides_vga
14/09/2013  01:08    <DIR>          .
14/09/2013  01:08            28,657 C.png
14/09/2013  01:08            24,305 A.png
14/09/2013  01:08            23,974 D.png
14/09/2013  01:08            29,013 B.png
14/09/2013  01:08            25,902 E.png
               5 File(s)        131,851 bytes
 Directory of Z:\RaspPi\NOOBS_v1_3_3\os\RISC_OS
13/10/2013  16:46               269 os.json
13/10/2013  16:46             3,151 RISC_OS.png
13/10/2013  16:46               487 partitions.json
13/10/2013  16:46        67,770,876 RISC_OS.xz
13/10/2013  16:46         2,544,832 RISC_OS_Boot.tar.xz
               5 File(s)     70,319,615 bytes
 Directory of Z:\RaspPi\NOOBS_v1_3_3\os\RISC_OS\slides_vga
29/08/2013  09:42            95,710 C.png
29/08/2013  09:42            71,572 A.png
29/08/2013  09:42            96,935 B.png
               3 File(s)        264,217 bytes
 Directory of Z:\RaspPi\NOOBS_v1_3_3\os\data_partition
14/10/2013  18:55    <DIR>          .
14/10/2013  18:55               143 os.json
14/10/2013  18:55               225 partitions.json
14/10/2013  18:55               332 data.tar.xz
14/10/2013  18:55             1,335 Data_Partition.png
               4 File(s)          2,035 bytes
 Directory of Z:\RaspPi\NOOBS_v1_3_3\os\Raspbian
13/10/2013  16:51    <DIR>          .
24/12/2013  09:55               278 os.json
24/12/2013  09:56       542,895,692 root.tar.xz
24/12/2013  09:54               445 partitions.json
13/10/2013  16:46               419 partition_setup.sh
24/12/2013  09:56             1,099 release_notes.txt
13/06/2013  15:27    <DIR>          slides_vga
13/10/2013  16:46             2,857 Raspbian_-_Boot_to_Scratch.png
13/10/2013  16:46               275 flavours.json
24/12/2013  09:56        14,755,400 boot.tar.xz
13/10/2013  16:46             1,662 Raspbian.png
               9 File(s)    557,658,127 bytes
 Directory of Z:\RaspPi\NOOBS_v1_3_3\os\Raspbian\slides_vga
13/06/2013  15:27    <DIR>          .
13/10/2013  16:51    <DIR>          ..
20/06/2013  16:37            27,682 C.png
20/06/2013  16:37            39,806 A.png
20/06/2013  16:37            28,172 D.png
20/06/2013  16:37            33,646 G.png
20/06/2013  16:37            38,637 B.png
20/06/2013  16:37            29,776 E.png
20/06/2013  16:37            35,337 F.png
               7 File(s)        233,056 bytes
     Total Files Listed:
              86 File(s)  1,381,247,716 bytes
              50 Dir(s)  1,459,968,376,832 bytes free
chalky3000
Thu Dec 26, 2013 11:56 pm
OK Last post for now,
I have reformatted the SD card, coppied all the latest NOOBS onto it, created the config.txt file with the one line in it as previous post above. Started ok and gets past the rainbow screen. Get to select the OS and installs raspbian to 100% and leaves me with the 'OS installed correctly' message. Click ok and the Pi reboots and sits back with a black screen and just stays there...... and stays there.....
Just checked the files and sizes from the post above and mine are the same. Thanks
Chalky
davidtjackson
Fri Dec 27, 2013 9:29 am
I'll give this another go.today.
The one thing I haven't tried is extracting directly to the SD card. I've always extracted to a folder elsewhere and moved files across.
I'll report back.
gsh
Fri Dec 27, 2013 11:56 am
OK, adding boot_delay=1 definitely seems to have an effect, but there are two places to add it...
First as you have done to the primary partition (RECOVERY) but after installing Raspbian, you need to hold down shift to re-enter NOOBS, move the OS selection back down to Raspbian and click the edit config button... Then add the boot_delay=1 to that as well...
Be interested in how it works...
Just for people to understand, this is definitely a known bug, currently we do not know whether it is a software or hardware problem and I need to get back to work tomorrow to see if I can find out!
Sorry, we'll be working on this full time until we find the problem
Gordon
phree
Fri Dec 27, 2013 12:26 pm
Hi, I've been following this post with interest as I have the same issues. Eventually having tried all the things on this post I downloaded Raspian on its own and used Win32Diskmanager to install the image. This didnt seem to work, but then I edited the config file and added the line as advised.the Pi has booted upto to a gui entitled "Raspberry Pi Software Configuration Tool (raspi-config).
What do I do next ?
Rgds Paul
phree
Fri Dec 27, 2013 1:42 pm
I have been suffering exactly the same issue as the people on this post, but I have finally got mine working, hopefully this will help you to get going to.
First I downloaded the Raw Raspian image here http://www.raspberrypi.org/downloads and unpacked it
I also downloaded the installer here http://sourceforge.net/projects/win32diskimager/ and unpacked it
I formatted the SD card using the advised SD formatter
Used the Diskimager to install the image on the SD Card using this guide http://elinux.org/RPi_Easy_SD_Card_Setup
Once installed I then edited the config.txt file on the SD Card and added boot_delay=1
Inserted the SD card, the HDMI and the keyboard into the Pi and powered up. It took a couple of seconds, but then scrolling text on the screen that ended with the Raspberry Pi config screen.
I then followed the guide here to configure the Pi and it then rebooted to a Rasperry desktop gui
hope this helps
Paul
davidtjackson
Fri Dec 27, 2013 2:36 pm
Hi all,
Paul's method did work.
I've been able to download the raw image of Raspbian, copy it on to my SD card using Win32DiskImager and then, by adding in boot_delay=1 to the config files, it booted.
I assume, given I've made this much progress - as have others - that there's some kinda problem with NOOBS v1.3.3?
Dave
phree
Fri Dec 27, 2013 4:20 pm
Sorry, just noticed I missed this link of the final step
http://www.raspberrypi.org/forum/viewto ... =91&t=4751
rgds Paul
