ironworker wrote:hello everone
i starded using my raspberry pi one week ago. i had a 4gb sd card and everything worked fine,
now i bought a 32gb sd card , i had it format like the discription said i needed to, then i putted noob on it and that also worked,
now i want to instal a os or image and it says availble space 0 mb i hope u guys can help me with it.
So you used the formatter from the quick start guide, and you remembered to set the Format size adjustment ?
I would imagine the default is 4GB so you first need to go through each step and try again.
You put noob on it which will fit, but when you come to put anything else on it, the program reports there is not enough space. ?
I strongly suggest you go back to the start and try another format
To help where possible, and always to learn.
