Kymru
DGN2000 to RPI Syslog Server
Sat Dec 21, 2013 1:56 pm
I am having some issues with my internet connection, disconnects and reconnects every minute or 2, instead of me relying on the not so good memory of the router, i was hoping to send the logs to a syslog server on one of my Pi's, then if need be i can send those logs to my ISP if i needed to
my router is a Netgear DGN2000 and i can send logs to a single IP address or i broadcast on LAN, which what would be the best way of setting up a syslog server on my Pi to store the router logs?
thanks
Re: DGN2000 to RPI Syslog Server
Sat Dec 21, 2013 5:41 pm
Raspbian comes with rsyslogd installed.
So it's a case of configuring it for remote syslogging from your router/switch
http://www.rsyslog.com/guides/ is the home page for the docs.
http://www.rsyslog.com/receiving-messag ... te-system/ looks like what you want to do and the arcane incantations you'll need to add to /etc/rsyslog.conf to get it listening to port 514.
I updated these lines in /etc/rsyslog.conf
# provides UDP syslog reception
$ModLoad imudp
$UDPServerRun 514
# provides TCP syslog reception
$ModLoad imtcp
$InputTCPServerRun 514
Once it's listening you can test it with telnet.
telnet localhost 514
hello logger log this
warn:log this as warn
>>>> then press CTRL+] followed by quit to exit from telnet
And this turned up in the bottom of /var/log/messages
Dec 21 17:43:30 pi rsyslogd: [origin software="rsyslogd" swVersion="7.4.4" x-pid="4771" x-info="http://www.rsyslog.com"] start
Dec 21 17:44:03 hello logger log this#015
Dec 21 17:44:20 localhost warn: log this as warn#015
You may need to look more deeply at what your router sends, you may be able to create a log just for the router.
Kymru
Sun Dec 22, 2013 11:27 am
Thank you DougieLawson, i had a quick read and got a headache, i tried the Telnet to the Pi and what i wrote did appear in /var/log/messages but i am still waiting for anything from the router, ill investigate some more
Sun Dec 22, 2013 11:38 am
If you reboot your router it should at least log it's "Good Morning" message
Sun, 2013-12-22 hh:mm:ss - NETGEAR activated
And some more if you login to the admin panels.
Although I wouldn't trust the plonkers @ NETGEAR as far as I could spit them to get this stuff right.
http://pages.cs.wisc.edu/~plonka/netgear-sntp/
Kymru
Mon Dec 23, 2013 1:25 pm
DougieLawson wrote:If you reboot your router it should at least log it's "Good Morning" message
yay it works, as of just now, this is what is being logged
Dec 23 12:46:14 192.168.0.1 <DDNS>HTTP cannot connected
Dec 23 12:46:19 LCP down.
Dec 23 12:46:28 Initialize LCP.
Dec 23 12:46:28 LCP is allowed to come up.
Dec 23 12:46:34 CHAP authentication success
Dec 23 12:46:47 192.168.0.1 <DDNS>Update OK: good
Dec 23 12:48:04 LCP down.
Dec 23 12:48:12 Initialize LCP.
Dec 23 12:48:12 LCP is allowed to come up.
Dec 23 12:48:18 CHAP authentication success
Dec 23 12:49:27 192.168.0.1 <DDNS>HTTP cannot connected
Dec 23 12:49:38 LCP down.
Dec 23 12:49:45 Initialize LCP.
Dec 23 12:49:46 LCP is allowed to come up.
Dec 23 12:49:48 CHAP authentication success
Dec 23 12:50:18 192.168.0.1 <DDNS>Update OK: good
Dec 23 12:52:29 LCP down.
Dec 23 12:52:36 Initialize LCP.
Dec 23 12:52:36 LCP is allowed to come up.
Dec 23 12:53:36 Initialize LCP.
Dec 23 12:53:36 LCP is allowed to come up.
Dec 23 12:54:36 Initialize LCP.
Dec 23 12:54:36 LCP is allowed to come up.
Dec 23 12:55:36 Initialize LCP.
Dec 23 12:55:36 LCP is allowed to come up.
Dec 23 12:56:36 Initialize LCP.
Dec 23 12:56:36 LCP is allowed to come up.
Dec 23 12:57:36 Initialize LCP.
Dec 23 12:57:36 LCP is allowed to come up.
Dec 23 12:58:37 Initialize LCP.
Dec 23 12:58:37 LCP is allowed to come up.
Dec 23 12:59:37 Initialize LCP.
Dec 23 12:59:37 LCP is allowed to come up.
Dec 23 13:00:37 Initialize LCP.
Dec 23 13:00:37 LCP is allowed to come up.
Dec 23 13:01:04 CHAP authentication success
Dec 23 13:01:14 192.168.0.1 <DDNS>Update OK: good
Dec 23 13:02:31 Send out NTP request to 194.35.252.7
Dec 23 13:03:44 LCP down.
Dec 23 13:03:57 Initialize LCP.
Dec 23 13:03:57 LCP is allowed to come up.
Dec 23 13:04:58 Initialize LCP.
Dec 23 13:04:58 LCP is allowed to come up.
Dec 23 13:05:26 Initialize LCP.
Dec 23 13:05:26 LCP is allowed to come up.
Dec 23 13:06:26 Initialize LCP.
Dec 23 13:06:26 LCP is allowed to come up.
Dec 23 13:06:35 CHAP authentication success
Dec 23 13:07:49 192.168.0.1 <DDNS>HTTP cannot connected
Dec 23 13:08:09 LCP down.
Dec 23 13:08:18 Initialize LCP.
Dec 23 13:08:18 LCP is allowed to come up.
Dec 23 13:08:18 CHAP authentication success
Dec 23 13:09:30 192.168.0.1 <DDNS>HTTP cannot connected
Dec 23 13:09:38 LCP down.
Dec 23 13:09:46 Initialize LCP.
Dec 23 13:09:46 LCP is allowed to come up.
Dec 23 13:09:46 CHAP authentication success
Dec 23 13:09:55 192.168.0.1 <DDNS>Update OK: good
Dec 23 13:11:56 LCP down.
Dec 23 13:12:40 Initialize LCP.
Dec 23 13:12:40 LCP is allowed to come up.
Dec 23 13:13:40 Initialize LCP.
Dec 23 13:13:40 LCP is allowed to come up.
Dec 23 13:13:50 CHAP authentication success
Dec 23 13:14:19 192.168.0.1 <DDNS>Update OK: good
Dec 23 13:14:45 Send out NTP request to time-g.netgear.com
Dec 23 13:17:23 Send out NTP request to 194.35.252.7
Dec 23 13:17:40 LCP down.
Dec 23 13:18:02 Initialize LCP.
Dec 23 13:18:02 LCP is allowed to come up.
Dec 23 13:18:08 CHAP authentication success
Dec 23 13:18:17 192.168.0.1 <DDNS>Update OK: good
Kymru
Mon Dec 23, 2013 9:49 pm
trying to follow this to get the logs into their own file http://www.rsyslog.com/storing-messages ... ific-file/ but not having much luck
this doesnt seem to work
$ModLoad imtcp
# do this in FRONT of the local/regular rules
if $fromhost-ip startswith '192.168.0.' then /var/log/router.log
# local/regular rules, like
*.* /var/log/syslog.log
my router's IP is 192.168.0.1
Mon Dec 23, 2013 11:21 pm
Trace the TCP or UDP traffic coming in to you RPi and you may be able to see what log stream it is written on.
Else you'd need to ask on a Netgear forum.
Tracing with tcpdump is easy. The trace files can be formatted with Wireshark on Windows. Or for masochists with tcpdump on your RPi.
