solar3000
remote admin project, screen blanking adj
Fri Dec 20, 2013 4:44 am
so we already know that setterm -blank 10 in /etc/kbd/ will blank console after 10 minutes.
I'm off site. So how do I setterm the remote pi running raspbian? Also I can't just reboot the machine just because I feel like it.
Antikythera
jojopi
Re: remote admin project, screen blanking adj
Fri Dec 20, 2013 5:02 am
If I understand the question correctly:
sudo sh -c 'TERM=linux setterm -blank 0 >/dev/tty0'
TERM=linux is to convince setterm that it is on a Linux console, otherwise it will refuse to output Linux-specific codes. >/dev/tty0 directs the output to the currently active virtual console. The convoluted sudo syntax is because otherwise the redirection would be attempted before the privileges were escalated.
solar3000
Mon Dec 23, 2013 3:49 am
You understand perfectly well. You=genius. Thank you. It works.
Antikythera
