lilzz
Try to understand the following table values WiringPi
Tue Dec 17, 2013 10:56 pm
1)what's sysFds, why is it all -1?
2) pinToGpioR1 [64] , are those values pin numbers, 17, 18...etc.
3)physToGpioR1 [64], what' s the difference between pinToGpioR1 versus physToGpioR1, why are the values, how they calculated?
// sysFds:
//	Map a file descriptor from the /sys/class/gpio/gpioX/value
static int sysFds [64] =
  -1, -1, -1, -1, -1, -1, -1, -1, -1, -1, -1, -1, -1, -1, -1, -1,
// pinToGpio:
//	Take a Wiring pin (0 through X) and re-map it to the BCM_GPIO pin
//	Cope for 2 different board revisions here.
static int *pinToGpio ;
static int pinToGpioR1 [64] =
  17, 18, 21, 22, 23, 24, 25, 4,	// From the Original Wiki - GPIO 0 through 7:	wpi  0 -  7
   0,  1,				// I2C  - SDA0, SCL0				wpi  8 -  9
   8,  7,				// SPI  - CE1, CE0				wpi 10 - 11
  10,  9, 11, 				// SPI  - MOSI, MISO, SCLK			wpi 12 - 14
  14, 15,				// UART - Tx, Rx				wpi 15 - 16
// Padding:
      -1, -1, -1, -1, -1, -1, -1, -1, -1, -1, -1, -1, -1, -1, -1,	// ... 31
  -1, -1, -1, -1, -1, -1, -1, -1, -1, -1, -1, -1, -1, -1, -1, -1,	// ... 47
  -1, -1, -1, -1, -1, -1, -1, -1, -1, -1, -1, -1, -1, -1, -1, -1,	// ... 63
static int pinToGpioR2 [64] =
  17, 18, 27, 22, 23, 24, 25, 4,	// From the Original Wiki - GPIO 0 through 7:	wpi  0 -  7
   2,  3,				// I2C  - SDA0, SCL0				wpi  8 -  9
  28, 29, 30, 31,			// New GPIOs 8 though 11			wpi 17 - 20
// Padding:
// physToGpio:
//	Take a physical pin (1 through 26) and re-map it to the BCM_GPIO pin
static int *physToGpio ;
static int physToGpioR1 [64] =
  -1,		// 0
  -1, -1,	// 1, 2
   0, -1,
   1, -1,
   4, 14,
  -1, 15,
  17, 18,
  21, -1,
  22, 23,
  -1, 24,
  10, -1,
   9, 25,
  11,  8,
  -1,  7,	// 25, 26
// Padding:
static int physToGpioR2 [64] =
  -1,		// 0
  -1, -1,	// 1, 2
   2, -1,
   3, -1,
   4, 14,
  -1, 15,
  17, 18,
  27, -1,
  22, 23,
  -1, 24,
  10, -1,
   9, 25,
  11,  8,
  -1,  7,	// 25, 26
// Padding:
// gpioToGPFSEL:
//	Map a BCM_GPIO pin to it's Function Selection
//	control port. (GPFSEL 0-5)
//	Groups of 10 - 3 bits per Function - 30 bits per port
static uint8_t gpioToGPFSEL [] =
  0,0,0,0,0,0,0,0,0,0,
  1,1,1,1,1,1,1,1,1,1,
  2,2,2,2,2,2,2,2,2,2,
  3,3,3,3,3,3,3,3,3,3,
  4,4,4,4,4,4,4,4,4,4,
  5,5,5,5,5,5,5,5,5,5,
FTrevorGowen
Re: Try to understand the following table values WiringPi
Wed Dec 18, 2013 3:45 pm
lilzz wrote:1)what's sysFds, why is it all -1?
O.K., the best person to answer your questions is, of course, the wiringPi author, Gordon (see https://projects.drogon.net/raspberry-pi/wiringpi/ ) but, as a 'C' programmer and wiringPi user I can make an "educated guess" at 1) and point you to info. related to 2) and 3). So, here goes ...
1) The array's name is probably a mnemonic for SYStem File DescriptorS (since most "Linux things" may be regarded as a "type of file"). Generally, file descriptors use positive integers when they have been "defined" or "assigned" so it's quite common to mark them as "undefined" or "unassigned" by giving them a value of -1.
To begin to understand 2) and 3) take a look at http://elinux.org/Rpi_Low-level_periphe ... .28GPIO.29 which describes the various GPIO Pin labelling and numbering schemes and how they changed between "B1" and "B2" Pi's etc.
Trev.
Return to “Advanced users”
