neptune
Raspbmc - How to auto retry the music\audio stream?
Tue Dec 17, 2013 10:09 pm
We are currently running our overhead music, powered by a Raspberry PI running RaspBMC. It outputs a streaming music add-on to the audio 3.5mm output.
It is currently using a wireless adapter via a USB port (it is a Raspberry PI approved wifi adapter) that connects to a WPA2 encrypted WAP.
Unfortunately, it seems the wireless may be spotty at times at the wifi signal becomes weak and it will disconnect. The audio stream then stops and it has to be restarted.
The wireless interface seems to auto re-connect when it drops out for a moment, but the stream does not start back up.
This is the message that is displayed when the wifi signal drops, or is interrupted and the stream stops.
Does anyone have any suggestions for auto retrying the stream when it stops or a script that runs to verify the stream is running in raspbmc?
Thanks!
Phill Rymer
Re: Raspbmc - How to auto retry the music\audio stream?
Thu Dec 19, 2013 10:50 pm
google xbmc user manual large pdf file download as book
