lilzz
WiringPi lib for accessing GPIO.
Tue Dec 17, 2013 5:22 pm
The WiringPi lib for accessing GPIO
https://projects.drogon.net/raspberry-p ... functions/
I need access the periperhal pin on pi board therefore I am using this wiringPi lib. However, I check it's using Broadcom chipset.
// BCM Magic
#define	BCM_PASSWORD		0x5A000000
// The BCM2835 has 54 GPIO pins.
//	BCM2835 data sheet, Page 90 onwards.
//	There are 6 control registers, each control the functions of a block
//	of 10 pins.
//	Each control register has 10 sets of 3 bits per GPIO pin - the ALT values
Now my Pi has a Samsung chipset, so does the wiringPi still gonna work? In the code there's a board com magic key, I suppose Samsung would have one different.
Now, Why my pi use a Samsung chipset, I prefer to get Broadcom.. Do I need to return the pi and ask one with Broadcom chipset?
joan
Re: WiringPi lib for accessing GPIO.
Tue Dec 17, 2013 5:32 pm
All Pi's have a Broadcom SOC. Yours happens to have Samsung memory.
lilzz
Tue Dec 17, 2013 6:15 pm
joan wrote:All Pi's have a Broadcom SOC. Yours happens to have Samsung memory.
Nope that's not true. Mine is clearly a Samsung ARM chipset.
Also, there's no memory chip onboard, everything runs off from the SD Card.
lilzz
Tue Dec 17, 2013 6:29 pm
Oh my bad, the Samsung chip is stacked on top of the broadcom SOC.
