agentscreech
Re: RPi Cam Web Interface
Sun Aug 26, 2018 8:49 pm
Looks like they need to upgrade their PHP version.
Wayback Machine can get you going in the mean time. It's got a copy from Dec 2017
https://web.archive.org/web/20171119195 ... -Interface
HaMaSch
Mon Aug 27, 2018 4:37 pm
oldjake wrote:
Sun Aug 26, 2018 6:06 pm
Disaster!
Just been to the wiki page as I have another Pi built and ready to go but the page is down. Do the install instructions exist anywhere else?
Cheers
Andy
Hi Andy,
I saved a local copy of the Instructions. Just put it up to my dropbox. You may download it from here: https://www.dropbox.com/s/kvd3r2mfxiqbm ... e.pdf?dl=1
Maybe it's not the newest, but helps you anyway.
Cheers
Hartmut
oldjake
Mon Aug 27, 2018 9:05 pm
Thanks, Hartmut. I've just checked and it's back online now. I think I might just save a copy just in case
bluesky55
Thu Aug 30, 2018 7:08 pm
Hi all, need a bit of help please - What I'm trying to do is start recording video on motion detect, then continue recording while there continues to be motion in the picture, this motion could continue for many minutes, and when the motion ceases, continue recording for a further 60 seconds, So this would produce just one clip. Have tried ca 1 60 in a schedule for the Motion start field, (Motion stop field left blank) but this doesn't appear to allow a fresh motion trigger to extend the recording. Hope that makes sense to someone, any thoughts ?
oldjake
Thu Aug 30, 2018 9:29 pm
Is it possible to use this as a trigger for IFTTT?
I have 2 Sonoff controlled lights in my garage and I would like to set them so that the Pi/camera in the garage acts as a motion detector that turns the lights on via IFTTT.
Long shot but the alternative seems to be flashing the firmware and doing all sorts of nasty sounding stuff.
oldjake
Fri Aug 31, 2018 8:21 am
@bluesky55:
What results are you getting at the moment? Have you got anything set for max_capture in the schedule? The reason I ask is that I have mine set up pretty much with the defaults and it does exactly what you're talking about. Motion gets triggered and I get anything from about 6s to several minutes. It's never many minutes but that's just the nature of it here. I think I got about 12 minutes when my other half was watering the plants in the front garden.
Be worth having a look in your logs as well to get an idea when capture is started and stopped.
bluesky55
Sat Sep 01, 2018 8:02 am
oldjake
Thanks for the reply, having looked at your suggestions, heres what I did
Re installed raspbian afresh. Installed RPi-Cam-Web-Interface.
Having done this the system worked alot better than before, the camera had randomly reset before the re-build.
Then changed the event_gap to 60 (under the Edit Motion Settings),
Now it works just how I wanted, :D That is, any movement inside a 60 second window allows recording to carry on, recording only stops after 60 seconds of no movement.
What a nice piece of software, thanks to the developers for all the hard work, I hope you are enjoying developing it, and its much appreciated out here.
oldjake
Fri Sep 07, 2018 8:33 pm
I've upcycled an old Kodak Brownie and installed a Pi Zero, camera and LiPo battery pack. The Pi runs RPi Cam Web Interface and I connect to it on my phone for previews and control. That all works brilliantly.
I've also got a physical button connected to a couple of GPIO pins. At the moment, I have to stop the camera in RPiCWI, ssh into the Pi and do:
python cam.py
Then the physical button takes snaps and puts them into the media directory.
What I'd really like to do is be able to use the physical button to do the same as clicking the 'Record image' button on the interface. That way, I could just fire the camera up, take some pics (No preview screen, just the viewfinder on the camera) and then get the results when I get WiFi again. The Pi has rclone installed so it uploads to Google Drive if there's a connection.
Anyway, the question is whether I can take a pic using the physical button connected to the GPIO.
Cheers
Andy
oldjake
Sat Sep 08, 2018 12:48 am
With a bit of jiggery pokery, I now have a physical button that does the same as the 'Record Image' button in the web interface.
There's quite a lot to it (for a newbie like me) and it's 01.45am so I won't document it now but I will if anyone wants to do the same.
The most important thing I've learned is not to go to bed with an idea bubbling around your head!
stefan.knight
Camera Choice
Sun Sep 09, 2018 5:35 pm
What is consensus for the camera choices listed on the wiki?
Camera Choice
Raspberry Pi Camera Board - Night Vision & Fisheye 160° Lens - https://www.modmypi.com/raspberry-pi/camera/camera-boards/raspberry-pi-camera-board-night-vision-and-fisheye-160°-lens-5mp/?limit=50
Raspberry Pi Camera Board - Fisheye 160° Lens - https://www.modmypi.com/raspberry-pi/camera/camera-boards/raspberry-pi-camera-board-fisheye-160°-lens-5mp/?limit=50
Raspberry Pi Camera Board - Fisheye 222° Lens - https://www.modmypi.com/raspberry-pi/camera/camera-boards/raspberry-pi-camera-board-fisheye-222°-lens-5mp/?limit=50
Raspberry Pi Camera Board - Night Vision "IR-CUT" - https://www.modmypi.com/raspberry-pi/camera/camera-boards/raspberry-pi-night-vision-camera-ir-cut/?limit=50
I need something for day/night (as I just have the regular raspberry pi v1.3 cameras) and was thinking of getting the Raspberry Pi Camera Board - Night Vision "IR-CUT" instead of Raspberry Pi Camera Board - Night Vision & Fisheye 160° Lens.
Does either support hevc (h.265) onboard encoding?
Gary Littlemore
Mon Sep 10, 2018 9:36 am
I've been a long time user of this software and I'm still running Jessie Lite, is there any benefits for me starting a fresh install with Stretch?
3b+, 2b, b+, b, Zero & Zero-W
pumpkinpi
Sat Sep 15, 2018 10:43 pm
Hi folks,
I am trying to record videos for a dashcam with boxing off and do the mp4 boxing later on via this command:
sudo echo 'sy startstop.sh start' >> /var/www/html/FIFO
I have used the bash script that comes with the software:
#!/bin/bash
# example start up script which converts any existing .h264 files into MP4
#Check if script already running
mypidfile=/var/www/html/macros/startstop.sh.pid
NOW=`date +"-%Y/%m/%d %H:%M:%S-"`
if [ -f $mypidfile ]; then
        echo "${NOW} Script already running..." >> /var/www/html/scheduleLog.txt
        exit
fi
#Remove PID file when exiting
trap "rm -f -- '$mypidfile'" EXIT
echo $$ > "$mypidfile"
#Do conversion
if [ "$1" == "start" ]; then
  cd $(dirname $(readlink -f $0))
  cd ../media
  shopt -s nullglob
  for f in *.h264
    do
      f1=${f%.*}
        echo "${NOW} Converting $f" >> /var/www/html/scheduleLog.txt
        #set -e;MP4Box -fps 25 -add $f $f1 > /dev/null 2>&1;rm $f;
        if MP4Box -fps 25 -add $f $f1; then
                echo "${NOW} Conversion complete, removing $f" >> /var/www/html/scheduleLog.txt
                rm $f
        else
                echo "${NOW} Error with $f" >> /var/www/html/scheduleLog.txt
        fi
    done
fi
The macro is executing just fine as I can see in the log file:
more /var/www/html/scheduleLog.txt
{2018/09/15 17:59:22} Executing macro /var/www/html/macros/startstop.sh start &
-2018/09/15 17:59:22- Converting vi_0001_20180915_175821.h264
-2018/09/15 17:59:23- Conversion complete, removing vi_0001_20180915_175821.h264
-2018/09/15 17:59:23- Converting vi_0002_20180915_175838.h264
-2018/09/15 17:59:24- Conversion complete, removing vi_0002_20180915_175838.h264
The issue is that I am a total bash newbie and I can't figure out why the file names are not getting updated. This is what I see in the media folder:
/var/www/html/media $ ls -la
total 13508
drwxr-xr-x 2 www-data www-data    4096 Sep 15 18:00 .
drwxr-xr-x 7 www-data www-data    4096 Sep 15 13:47 ..
-rw-r--r-- 1 www-data www-data 5507380 Sep 15 17:59 vi_0001_20180915_175821
-rw-r--r-- 1 www-data www-data   14737 Sep 15 17:58 vi_0001_20180915_175821.h264.v0001.th.jpg
-rw-r--r-- 1 www-data www-data 8279728 Sep 15 17:59 vi_0002_20180915_175838
-rw-r--r-- 1 www-data www-data   13923 Sep 15 17:58 vi_0002_20180915_175838.h264.v0002.th.jpg
The videos will only show up in the interface correctly if they look like this when the script is done:
-rw-r--r-- 1 www-data www-data 5507380 Sep 15 17:59 vi_0001_20180915_175821.mp4
-rw-r--r-- 1 www-data www-data   14737 Sep 15 17:58 vi_0001_20180915_175821.mp4.v0001.th.jpg
-rw-r--r-- 1 www-data www-data 8279728 Sep 15 17:59 vi_0002_20180915_175838.mp4
-rw-r--r-- 1 www-data www-data   13923 Sep 15 17:58 vi_0002_20180915_175838.mp4.v0002.th.jpg
Can anybody help me with the bash updates needed to add the correct suffix onto the file names?
Thanks,
PPi
Gary Littlemore
Wed Sep 19, 2018 10:19 pm
I've just done a fresh install using Raspbian Stretch Lite, installed the web interface. All is fine, I'm just wondering which 'Motion detect mode' is best to use these days? External or Internal?
oldjake
Thu Sep 20, 2018 5:58 am
If definitely say internal based on my experience running one in my garage for a month or so and another at the front door for about 3 months.
Return to “Camera board”
Who is online
Users browsing this forum: No registered users and 10 guests
