xatru
omxplayer on TFT Display
Wed Dec 11, 2013 10:24 pm
Hey everyone,
I'm playing around with an 2.8" TFT Touch Display from http://www.watterott.com/de/28-TFT-Touc ... eld-Bridge for the rpi. Everything works fine - now, nerly everything. I've two problems:
1. On the touch tft left and right is switched. So if I move from left to right it moves from right to left and vice versa.
2. Does anybody know how I can start omxplayer in such a way that it uses the TFT for video output and not the HDMI port of the PI? This is more important for me!
Regards,
Xatru
raspifari
Re: omxplayer on TFT Display
Thu Dec 12, 2013 5:33 pm
Try omxplayer fbdev:/dev/"the framebuffer of your screen" "your video"
the screen framebuffer is maybe fb1
That command work for mplayer but i have not tested with omxplayer
xatru
Thu Dec 12, 2013 11:12 pm
This doesn't work with omxplayer. The only thing I can give it without an "-" or "--" is the filename (see code) :(
Usage: omxplayer [OPTIONS] [FILE]
Options :
         -h / --help                    print this help
         -k / --keys                    print key bindings
         -n / --aidx  index             audio stream index    : e.g. 1
         -o / --adev  device            audio out device      : e.g. hdmi/local
         -i / --info                    dump stream format and exit
         -s / --stats                   pts and buffer stats
         -p / --passthrough             audio passthrough
         -d / --deinterlace             deinterlacing
         -w / --hw                      hw audio decoding
         -3 / --3d mode                 switch tv into 3d mode (e.g. SBS/TB)
         -y / --hdmiclocksync           adjust display refresh rate to match video (default)
         -z / --nohdmiclocksync         do not adjust display refresh rate to match video
         -t / --sid index               show subtitle with index
         -r / --refresh                 adjust framerate/resolution to video
         -g / --genlog                  generate log file
         -l / --pos n                   start position (in seconds)
              --boost-on-downmix        boost volume when downmixing
              --vol n                   Set initial volume in millibels (default 0)
              --subtitles path          external subtitles in UTF-8 srt format
              --font path               subtitle font
                                        (default: /usr/share/fonts/truetype/freefont/FreeSans.ttf)
              --font-size size          font size as thousandths of screen height
                                        (default: 55)
              --align left/center       subtitle alignment (default: left)
              --lines n                 number of lines to accommodate in the subtitle buffer
                                        (default: 3)
              --win "x1 y1 x2 y2"     Set position of video window
              --audio_fifo  n           Size of audio output fifo in seconds
              --video_fifo  n           Size of video output fifo in MB
              --audio_queue n           Size of audio input queue in MB
              --video_queue n           Size of video input queue in MB
Is there any chance to compile it self with an option like "use this device as default output and not hdmi"? Maybe someone a familiar with compiling omxplayer or know how I can find futher assistance?
Thanks!
texy
Mon Dec 16, 2013 7:45 am
for sending omxplayer output to fb1 search for application fbcp - it copies fb0 to fb1, and can be run as a background task using
fbcp &
It works very well with the displays I produce.
For the touch panel inversion - how are you calibrating the screen?
Texy
cleverca22
Tue Dec 17, 2013 7:42 pm
from the way i understand things, omxplayer bypasses fb0 entirely, and renders at the dispmanx level, so fbcp likely wont do any good
i think the player would have to be modified to either use dispmanx_snapshot, or raw rgb565 output, and then feed that over to the 2nd framebuffer
or you could make an fbcp clone, that uses dispmans_snapshot as the source, but the performance of such a thing wont be good
texy
Thu Dec 19, 2013 5:27 pm
Like I said, fbcp works fine for me using omxplayer to send video to fb1. No reason why it shouldn't work for other displays as long as they use fb1.
Texy
Return to “Advanced users”
