Thu Dec 12, 2013 11:19 am
alex_R wrote:FTrevorGowen: I agree with your statement that this may not be considered a "fault" in/with NOOBS, but in relation to the original question, I identified that the "problem" exists (in my case) when NOOBS is present on the SD card.
If NOOBS does not respect the config file of the OS to be loaded, then this should be explicitly stated somewhere (which I have not been able to find so far) to prevent random "head-scratching" assumptions, such as, faulty cable or incorrect TV settings.
A possible solution would be for NOOBS to have its own config file in the root partition (or part of the install payload), but this might cause confusion as to which config values are in use at any give state of RPI booting up. But this discussion is beyond the scope of this topic.
For now, it is only important to determine where the "fault" lies for this post, and which solution solve the issue.
@alex_R,
I understand that NOOBS default "HDMI setup/mechanism" is giving rise to a "problem" (not, perhaps, the same "problem" ) with some TV's but, so far, in my "following" of a number of NOOBS threads I have only come across ~3 similar issues (IIRC, none were reported in the "beta-testing" thread, for example). NOOBS does have its equivalent of a "config.txt", AFAIK, but that is somewhat different to those for the O.S.'s and the editing of such an "advanced topic". NOOBS main documentation can be found at:
https://github.com/raspberrypi/noobs and, if you so wish, please raise an issue there.
Trev.
