NicholasH
Cannot exit browser
Tue Dec 10, 2013 1:07 pm
I got my new toy today, loaded Raspbmc and I went to the browser to see how to set it up as a DLNA client. Anyway now I cannot exit the browser, or, at least, when I do it just restarts. Pulling the plug does not help either.
As a secondary issue I resized the screen (-4%) which works when navigating normally round Raspbmc, but the browser is still too big and I can't even see the File menu (I can access it by mousing off to the left as I know where it should be so I can exit correctly)
TIA,
Nick
NicholasH
Re: Cannot exit browser
Tue Dec 10, 2013 2:01 pm
I found an answer elsewhere - to pull the SD card and remove lines pointing to the browser from config.txt. It does not sort out the browser size issue, but I am avoiding it for the moment.
paulie
Tue Dec 10, 2013 4:37 pm
Is it just the browser, or is it the Desktop itself?
There is info in the setup guides about overscan/under scan setting.
If you kill the X server & work at the command prompt, you may also see top,bottom, or sides with text missing.
It has been my custom to use Xeyes
NicholasH
Tue Dec 10, 2013 4:55 pm
I can get the desktop to fit by adjusting Settings > Appearance > Skins > Zoom to -4%, but it does not affect the browser which is so big I cannot see any of the word File in the menu.
I'll try to read up about the overscan settings.
Dilligaf
Tue Dec 10, 2013 5:42 pm
You need to turn off overscan on your tv/monitor different manufacturers call it different things such as just scan, just fit,
NicholasH
Tue Dec 10, 2013 10:15 pm
I/ve been back in and this time the browser is displayed correctly with the zoom set to -4%. The TV is set to 16:9 and I have not found any overscan options. That's the good bit.
The bad bit is that the browser went into a restart loop again. Although I am new to it, I have a feeling I should be posting the troubleshooting of the restart to this thread at stmlabs.
Karder
Wed Dec 11, 2013 8:31 pm
Hi
As a noob i unwittingly did the same thing - Raspbmc browser is now on a loop, i looked at my SD card and config.txt only has one line: Boot_delay=1
am i missing something? can someone direct me to getting Xbmc back as im cracking up...
sdjf
Wed Dec 11, 2013 10:53 pm
I do not know anything about Xbmc but I do believe there is a standard for all X applications for declaring their size in pixels in whatever file starts them. It is the --geometry.
For example, I have my lxterminal in Arch started by the following, where first number is width and second is height. you can also specify the distance in pixels from the top left corner, google for more details or read some man pages, I might lead you wrong if I try to explain more right now.
lxterminal 300x200 &
The ampersand lets the startup script exit while the application is still running/starting up.
I hope some of this is applicable in Xbmc, it ought to be since I understand that geometry is the same in all X (but I could be wrong, I just read that in some man page).
FORUM TIP: To view someone's posting history, sign in, click on their user name, then on "Search User's Posts." || Running ArchLinuxArm on Model 2B and 512MB Model B
Dilligaf
Thu Dec 12, 2013 12:49 am
Karder wrote:Hi
If you want Raspbmc it's probably best to dump the Noobs install and do a straight Raspbmc install from here http://www.raspbmc.com/download/ the difference in the NOOBS filesystem is causing issues.
Karder
Thu Dec 12, 2013 8:26 am
Im reading on here that all that is required is to remove lines re the browser from the Config.txt... But i cant see the Config.txt that ppl describe.
Are you saying that the NOOBs install hides the main? if so how do i get at it. TBH i dont know if i have the time to do a fresh install... a quick easy fix is all im after - SD card into PC edit config - fire up pi .....kop out i know but i will learn the nuts and bolts sometime.
Thu Dec 12, 2013 1:05 pm
Boot NOOBS while holding the [SHIFT] key.
The NOOBS menu has a config.txt editor.
Karder
Thu Dec 12, 2013 1:53 pm
DougieLawson wrote:Boot NOOBS while holding the [SHIFT] key.
Right i need a keyboard then!! cheers ill try that and report back
