tdunn599
Wi-Pi not working
Mon Dec 09, 2013 5:00 pm
I recently purchase a Raspberry PI with a Wi-Pi USB adapter.
When I plug in the Wi-Pi, it sees my network, but it will not connect. After about a minute, it looses the network and cannot find it when it select Scan.
Can anyone help me to resolve this problem?
Ted Dunn
Phill Rymer
Re: Wi-Pi not working
Mon Dec 09, 2013 9:45 pm
which op system and have you entered ssid and passkey you may need to install it with cable connected I sometimes need to do that don't know why but seems to help
tdunn599
Tue Dec 10, 2013 8:38 pm
Phill Rymer wrote:which op system and have you entered ssid and passkey you may need to install it with cable connected I sometimes need to do that don't know why but seems to help
I am using Raspian.
When I run Wi-Fi config it initially sees the network. The name of the network appears. But then I get the error under status "Could not get status from wpa_supplicant"
I did try it with a short cable. Same results.
In the adapter field it displays wian0
Regards, Ted
