notbobRSA
Using GPIO to update a MySQL table
Mon Dec 09, 2013 2:11 pm
Hi there,
Any help would be much appreciated!
I'm working on a project where I'm listening to 8 pins (7,11,12,13,15,16,18,22) for pulses (falling edges on the pins which have been pulled up).
Currently I'm using threaded callbacks (see code) to run the following SQL statement which just inserts a row into a table each time there is a pulse.
"""INSERT INTO t_pulses
		(pulse_id, pin_number, pulse_timestamp)
		VALUES
		({}, {}, NOW());""".format(count, channel)
To test the code, I'm currently running it remotely (ssh) and shorting each pin to simulate a falling edge.
My Problem:
My code seems to escape with the following error 70% of the time, whereas it works the other 30% of the time.
It runs the callback several times (more times the longer I hold the pin shorted) and then escapes with an error.
The error message that is printed is as follows:
<class '_mysql_exceptions.OperationalError'>
My table:
pulse_id int(11) Not null default null
pin_number varchar(250) Not null default null
pulse_timestamp datetime Not null default null
My Code:
#testing threaded callbacks
import RPi.GPIO as GPIO
import MySQLdb
import sys
from time import sleep
global count
global db
global cursor
def test(channel):
	global count
	global db
	global cursor
	count = count + 1
	SQL = """ INSERT INTO t_pulses
		VALUES
	print "executing {}\n".format(SQL)
	try:
		cursor.execute(SQL)
		db.commit()
	except:
		err = sys.exc_info()[0]
		print err
		db.rollback()
def setupPin(pin):
	GPIO.setup(pin, GPIO.IN, pull_up_down=GPIO.PUD_UP)
	GPIO.add_event_detect(pin, GPIO.FALLING, callback=test, bouncetime=300)
#--------------------=============== MAIN ==============---------------
count = 0
#db stuff
try:
	db = MySQLdb.connect("localhost", "guest", "guest", "TestDB")
	cursor = db.cursor()
except:
	print err
GPIO.setmode(GPIO.BOARD)
setupPin(7)
setupPin(11)
setupPin(12)
setupPin(13)
setupPin(15)
setupPin(16)
setupPin(18)
setupPin(22)
raw_input("press any button when u want to terminate")
GPIO.cleanup()
db.close()
joan
Re: Using GPIO to update a MySQL table
Mon Dec 09, 2013 5:15 pm
Surely it should only insert one record each time you short the pin? It shouldn't detect another pulse until you remove the short.
FLYFISH TECHNOLOGIES
Mon Dec 09, 2013 5:42 pm
(Not directly related to the question)
You should optimize the db table and code. Set:
- pulse_id to autoincrement & unsigned & primary key and
- pulse_timestamp to default timestamp.
Consequently, you need each time to insert just pin_number (which is not varchar(250) type, but should be short(2)).
Best wishes, Ivan Zilic.
Running out of GPIO pins and/or need to read analog values?
Solution: http://www.flyfish-tech.com/FF32
Mon Dec 09, 2013 6:30 pm
Your strange output
Comes from
 except:
    print err
You're not catching the exception correctly.
from _mysql_exceptions import (OperationalError, NotSupportedError,
        ProgrammingError)
 except OperationalError m:
   print m[0]
Gives me the numeric failure code. There's probably more to handling OperationalError (but I've not found any coherent documentation for it).
notbobRSA
Tue Dec 10, 2013 2:30 pm
@DougieLawson
Thanks for the tips on exception catching, your code has a syntax error (missing a comma on the except line: )
 except OperationalError, m:
   print m[0]
I instead used the MySQLdb.Error import as follows to give comprehensive error messages.
try:
except MySQLdb.Error, e:
		try:
			print "MySQL Error [%d]: %s" %(e.args[0], e.args[1])
		except IndexError:
			print "MySQL Error: %s" % str(e)
And found that I was forgetting to format my INSERT SQL statement with inverted commas around the text values.
So silly.
@joan
I was also expecting only one callback to be run per short.
This is now my primary concern.
Here is my updated code, can anyone tell me why my callbackFunction is being called multiple times when I am shorting my pins?
#--------------=== Imports ===-------------------------
import MySQLdb
import sys
from threading import Thread
import time
from collections import deque
#----------------===Functions===------------------------
def callbackFunction(channel):
	global number_of_statements_in_SQLqueue
	number_of_statements_in_SQLqueue = number_of_statements_in_SQLqueue + 1
	try:
		meter_id = pinMeterDictionary[channel]
	except:
		print """We have failed """
	pulseID = generatePulseID()
	SQL = """INSERT INTO t_pulses VALUES ({}, "{}", NOW());""".format(pulseID, meter_id)
	try:
		SQLqueue.append(SQL)
	except:
		print "Failed to add the following SQL statement to the queue:\n{}".format(SQL)
	print "\nappended {} for pulse {} on {}".format(SQL, pulseID, meter_id)
def executeSQL(SQL):
	try:
		cursor.execute(SQL)
		db.commit()
		try:
			print "MySQL Error [%d]: %s  {from your executeSQL method}" %(e.args[0], e.args[1])
		except IndexError:
		db.rollback()
def setupPin(pin):
	GPIO.add_event_detect(pin, GPIO.FALLING, callback=callbackFunction, bouncetime=300)
def generatePulseID():
	t = time.struct_time(time.localtime())
	pulseID = (t.tm_min/30) + (t.tm_hour*2) + ((t.tm_yday-1)*48) + (t.tm_year-2010)*17520
	return pulseID
def getPinMeterDictionary():
	global pin_meter_dictionary
	f = open('RPi_Water_Meter_Setup.txt', 'r')
	pin_meter_dictionary = {}
	currentPin = 0
	for line in f:
		if line[:4] == "Pin_":
			currentPin = int(line[4:6])
		elif line[:6] == "Meter_":
			meter_no = line[11:].lstrip().replace('\n', '')
			pin_meter_dictionary[currentPin] = meter_no
	return pin_meter_dictionary
class BackgroundSQLThread(Thread):
	def run(self):
		global SQLqueue
		while 1:
			sleep(60)
			for statement in range(number_of_statements_in_SQLqueue):
				if number_of_statements_in_SQLqueue > 0:
					executeSQL(SQLqueue.popleft())
					sleep(0.5)
					number_of_statements_in_SQLqueue = number_of_statements_in_SQLqueue - 1
#---------------===Global Variables===------------------
global db
global cursor
global SQLqueue
#-------------===Variables ===-------------------
count = 0
number_of_statements_in_SQLqueue = 0
#-------------===Database stuff===----------------
try:
		try:
			print "MySQL Error [%d]: %s  {from your connect method}" %(e.args[0], e.args[1])
		except IndexError:
#-------------===GPIO Setup===-----------------
setupPin(7)
setupPin(11)
setupPin(12)
setupPin(13)
setupPin(15)
setupPin(16)
setupPin(18)
setupPin(22)
#-------------===Data Structures===-------------
SQLqueue = deque()
pinMeterDictionary = getPinMeterDictionary()
#-----------===SQL Thread===-------------------
sqlthread = BackgroundSQLThread()
sqlthread.start()
#-----------===Program Interupt===---------------
inp = raw_input("press q you want to quit")
while 1:
	inp = raw_input()
	if inp=='q':
		GPIO.cleanup()
		db.close()
		sys.exit()
#------------===Clean up===---------------------
GPIO.cleanup()
db.close()
I've updated the code for readability etc.
joan
Tue Dec 10, 2013 2:51 pm
No idea why you'd be getting multiple callbacks. Perhaps the contact is not firm enough and it's bouncing.
Out of interest I tried your code (but amended to use my own library). I inserted a 100,000 records or so. I didn't get any MySQL errors.
#!/usr/bin/python
import sys
import MySQLdb
import pigpio
global count
global db
global cursor
def test(gpio, level, tick):
   global count
   global db
   global cursor
   count += 1
   SQL = """ INSERT INTO t_pulses (pulse_id, pin_number, pulse_timestamp)
      VALUES ({}, {}, {});""".format(count, gpio, tick)
   print SQL
   try:
      cursor.execute(SQL)
      db.commit()
   except:
      print "Unexpected error:", sys.exc_info()[0]
      db.rollback()
def setup_gpio(gpio):
   pigpio.set_mode(gpio, pigpio.INPUT)
   pigpio.set_pull_up_down(gpio, pigpio.PUD_UP)
   pigpio.callback(gpio, pigpio.FALLING_EDGE, test)
count = 0
try:
   db = MySQLdb.connect("localhost", "guest", "guest", "pi")
except:
   raise
pigpio.start()
setup_gpio(4)
setup_gpio(7)
setup_gpio(8)
setup_gpio(9)
setup_gpio(10)
setup_gpio(11)
setup_gpio(22)
setup_gpio(23)
raw_input("press RETURN to finish")
pigpio.stop()
db.close()
notbobRSA
Thu Dec 12, 2013 9:27 am
Awesome, thanks for testing my code :)
It is probably the bounce from a loose connection, I'll be setting up a test bed in the next week with firm connections and I'll report back.
Thank you to everyone for their help and comments, happy holidays!
AndrejB
Wed Feb 20, 2019 9:52 am
Pretty old theme. But maybe someone can help. How to modify code above to only write GPIO pin state (logic 0 or 1) to MySQL database.
Many Thanks
Andrej
B.Goode
Wed Feb 20, 2019 12:34 pm
Welcome to the Raspberry Pi forums.
Many Thanks
Andrej
Maybe a fresh topic outlining your own difficulty would be more productive than resurrecting a 5-years dead topic?
However, the heart of the matter appears to be:
Your requirement could be met by defining a database table with a single column (field) and modifying the INSERT statement correspondingly.
Return to “Python”
