mob-i-l
Contact: Website Facebook Google+ Twitter YouTube
Installing BYOB in Raspbian
Sat Dec 07, 2013 6:26 pm
BYOB is an enhanced version of Scratch 1.4 for more advanced Computer Science. I've unsuccessfully tried to install it in the latest and most upgraded Raspbian. What happens when I start it is that it only shows a white window and that CPU and memory usage increases. The only way to stop it is by killing it using Task Manager. I think the problem is that Raspbian squeakvm is incompatible with BYOB. Maybe BYOB.image could be changed so that it works in Raspbian.
[Edit: Now I've updated the instructions to use the BYOB-Pi.image published in the installBYOB.sh script and now it works in Raspbian!]
Here is how I install and run BYOB.
cd ~/Downloads
wget https://www.dropbox.com/s/cevf5my91pjy0t1/BYOB-Pi.image
wget http://byob.berkeley.edu/byoblib.tgz
cd /usr/share/scratch/
sudo mv ~/Downloads/BYOB-Pi.image .
sudo tar xvf ~/Downloads/byoblib.tgz
cd ~/Downloads
cp $(which scratch.old) BYOB
sed -i -e 's/Scratch.*\.image/BYOB-Pi.image/' -e 's| scratch| BYOB|' BYOB
sudo mv BYOB /usr/bin/
BYOB
Raspberry Pi0&1A&1B2&1B+&2B&3B w/ Raspbian. Started w/ BASIC on ABC80&ZX81 then Forth, Z80… http://scratch.mit.edu/users/mobluse/ https://github.com/mobluse/ https://twitter.com/mobluse/ https://YouTube.com/MOBiL4u/
timrowledge
Re: Installing BYOB in Raspbian
Sat Dec 07, 2013 7:19 pm
I suspect the vm is ok, because the squeakvm on the Pi is built from the same code as the one on my iMac and the downloads you listed run happily on that. Typically a plain white screen, expanding memory use and nothing else is a sign that something very early in the system startup code in the image is looping because of an error. It can be a *real* pain to find the culprit, not least because it sometimes seems to depend upon something apparently completely unrelated.
I'll see if I can spot anything. It will be a bit harder than it needs to be because the byob team appear to have removed the backdoor that allows us to get into a production Scratch image and find the tools. Maybe they just put one in a harder to find place...
You could try some simple things as well
- move the scratch.ini file out of the way, in case one of the options is causing trouble
- try moving the tools.ypr & ToolSprite.ysp files - I have no idea what they might be for!
Making Smalltalk on ARM since 1986; making your Scratch better since 2012
mob-i-l
Sun Dec 08, 2013 4:35 pm
I think I might have found the backdoor: Try Shift+Click Edit, then there appears a few extra menu items.
timrowledge wrote: You could try some simple things as well
I tried these things but it still only shows a white window and has increasing memory usage. I have installed and run it on Ubuntu Linux 10.04 and 12.04 but then I used the Debian-package which seems to include its own special BYOB_squeak_vm. It's strange that it runs on Mac OS X using your squeakvm but not in Raspbian. Maybe it works in RISC OS. Is Scratch and Squeak built-in in RISCOS or do you have to download and install them?
I think it would be great for the Foundation's educational goals if BYOB 3.1.1 could run on Raspberry Pi.
timrowledge
Tue Dec 10, 2013 6:30 pm
OK, I got the info on how to get into developer mode from the, err, developer, Jens. You have to start the system with the 'BYOB Development.sg' or 'BYOB Development.BAT' as appropriate and *then* the shift-click on 'Edit' extends the menu to include the 'turn off screen fill' which finally gets you to normal Squeak -land.
So now I can try it out and see what might be the problem.
timrowledge
Fri Dec 13, 2013 3:16 am
Well, that was easy once I remembered back a few months to similar issues I had in Feb; BYOB development started early enough in Scratch-time that the image was based on such an old release that it hadn't had some rather important primitive access changes made. Open it up as a developer, file-in the relevant update file, save and try on Pi, bingo!
https://www.dropbox.com/s/f9nuy733p553r ... .image.zip
Unzip as usual, change your startup script (or the filename!) to suit, and give it a try. Remember, it has none of the speedups I've developed for the image, but the squeakvm does have the faster bitblt.
simplesi
Fri Dec 13, 2013 7:53 am
Fan-Dabby-Dozy :-) :-) :-)
For people not used to playing around with Scratch modificactions here is a little guide to getting it installed alongside Scratch
Download file as above and copy it to /home/pi and then cd to /home/pi
sudo copy BYOB-Pi.image to /usr/share/scratch
cp ./Desktop/scratch.desktop to ./Desktop/BYOB.desktop
nano ./Desktop/BYOB.desktop
Change contents to
[Desktop Entry]
Encoding=UTF-8
Version=1.0
Type=Application
Exec=BYOB %f
Icon=scratch
Terminal=false
Name=BYOB
Comment= Programming system and content development tool
Categories=Application;Education;Development;
MimeType=application/x-scratch-project
save and then
sudo cp /usr/bin/scratch /usr/bin/BYOB
sudo nano /usr/bin/BYOB
and change to
#!/bin/sh
# File:            BYOB
# Description:     Script to start the Squeak VM binary with the BYOB image
# Original Author: Bert Freudenberg
# Adapted by:      Miriam Ruiz
VM_VERSION=`find /usr/lib/squeak/ -name "squeakvm" -type f|cut -f5 -d"/"`
SQ_DIR=/usr/lib/squeak/$VM_VERSION
VM="$SQ_DIR/squeakvm"
VMOPTIONS="-encoding UTF-8 -vm-display-x11 -xshm -plugins
/usr/lib/scratch/plugins/:$SQ_DIR/"
IMAGE="/usr/share/scratch/BYOB-Pi.image"
IMOPTIONS=""
DOCUMENT=""
WRAPPER=""
#set to 1 to work around OLPC bug #8008
export SQUEAK_FAKEBIGCURSOR=0
# default directories (used if not running as Sugar activity)
[ -z "$SQUEAK_SECUREDIR" ] && export
SQUEAK_SECUREDIR="$HOME/.scratch/private"
[ -z "$SQUEAK_USERDIR" ] && export SQUEAK_USERDIR="$HOME/Scratch"
[ ! -d "$SQUEAK_SECUREDIR" ] && mkdir -p "$SQUEAK_SECUREDIR" && chmod
700 "$SQUEAK_SECUREDIR"
[ ! -d "$SQUEAK_USERDIR" ] && mkdir -p "$SQUEAK_USERDIR"
[ ! -d "$HOME/Documents" ] && mkdir -p "$HOME/Documents"
usage()
    echo "Usage: BYOB [--param value] [-vmopt value] [arg value]"
    echo "       where --param is --vm, --image, or --document;"
    echo "       -vmopt is an option passed to the Squeak VM;"
    echo "       and args are passed to the Squeak image."
if [ $# -eq 1 ] ; then
	case "$1" in
	    /*) DOCUMENT="$1"
	    *) DOCUMENT="$PWD/$1"
	esac
	shift
else
    while [ -n "$1" ] ; do
	if [ -z "$2" ] ; then
	        usage
		exit -1
	fi
	case "$1" in
	        --help)
			usage
 			exit
	        --document)
			case "$2" in
			    /*) DOCUMENT="$2"
			    *) DOCUMENT="$PWD/$2"
			esac
 			shift
	        --image)
			case "$2" in
			    /*) IMAGE="$2"
			    *) IMAGE="$PWD/$2"
			esac
 			shift
	        --vm)
			case "$2" in
			    /*) VM="$2"
			    *) VM="$PWD/$2"
			esac
 			shift
		-*) VMOPTIONS="$VMOPTIONS $1 $2"
			shift
		*)  IMOPTIONS="$IMOPTIONS $1 $2"
			shift
	esac
	shift
    done
fi
# do not crash on dbus errors
export DBUS_FATAL_WARNINGS=0
# make Compose input methods work
# 30/01/2013: apprently this causes issues, so comment out. asb@asbradbury.org
#[ -z "$LC_ALL" ] && export LC_ALL="$LANG"
VMOPTIONS="$VMOPTIONS -vm-sound-alsa"
# VM, Image, and Document are non-optional
# Document has to be present even if empty for IMOPTIONS to work
echo Executing: $WRAPPER "$VM" $VMOPTIONS "$IMAGE" "$DOCUMENT"
$IMOPTIONS
exec $WRAPPER "$VM" $VMOPTIONS "$IMAGE" "$DOCUMENT" $IMOPTIONS
and robert is a close relation of your mother :)
All hail Tim and Jens :-)
Simon
Seeking help with Scratch and I/O stuff for Primary age children
http://cymplecy.wordpress.com/ @cymplecy on twitter
simplesi
Fri Dec 13, 2013 9:30 pm
[edit] 14Dec - Now includes required extra BYOB library files[/edit]
Hopefully I've manged to automate the install
Try
wget https://dl.dropbox.com/s/zgkq2jw9o9wbava/installBYOB.sh -O installBYOB.sh
followed by
sudo bash installBYOB.sh
This will download BYOB, create a desktop icon to a script to run it :)
This is for Raspbian users only running as normal user pi :) (Not for ubergeeks)
Simon
simplesi
Fri Dec 13, 2013 9:47 pm
Aah - it seems like the BYOB image has the original high CPU usuage when displaying variables issue that kicked off the whole "lets speed up Scratch" process :(
@tim
Any chance of applying the magic fix - even just the original simple one would do :)
Simon
mob-i-l
Fri Dec 13, 2013 11:48 pm
timrowledge wrote:Well, that was easy once I remembered back a few months to similar issues I had in Feb; BYOB development started early enough in Scratch-time that the image was based on such an old release that it hadn't had some rather important primitive access changes made.[...]
This worked for me and I updated the install-instructions in the original post. Thanks!
mob-i-l
Fri Dec 13, 2013 11:58 pm
simplesi wrote:Hopefully I've manged to automate the install[...]
You miss byoblib and probably BYOB.changes and the right menu icon if you only run that Bash-script.
timrowledge
Sat Dec 14, 2013 12:40 am
simplesi wrote:Aah - it seems like the BYOB image has the original high CPU usuage when displaying variables issue that kicked off the whole "lets speed up Scratch" process :(
@tim
Ouch. Didn't spot that one. I'll see what I can do but it may take a few days. In the meantime, bask in the nostalgia of how awful it was...
simplesi
Sat Dec 14, 2013 10:32 am
@mob-i-l
Ta - :)
I've included the byoblib files now but haven't worked out where I can find an icon file so still using the Scratch one
I didn't include the changes file as I'm assuming Tim has rolled them into his image
Simon
mob-i-l
Wed Dec 25, 2013 5:12 pm
simplesi wrote:@mob-i-l
Ta - :)
There are icons in the deb-file for i386 in data.tar.gz in /./usr/share/icons/hicolor/.
@timrowledge Can BYOB-Pi do without the changes-file?
timrowledge
Thu Dec 26, 2013 8:28 pm
The short story is that you can always manage without the .changes file and the .sources file since all they are is the saved source text; the .sources is a large read-only file with mostly the main system code and the .changes file is an audit trail of edits made and saved and code filed in. There's a much longer story that you could learn about by reading up on how Smalltalk works, should you be interested (wiki.squeak.org/wikiwould be a decent starting point)
Even if you are doing development work you can survive without the two source files since Smalltalk systems can decompile the code and let you edit and re-save it. You lose helpful comments etc but you can still work.
I'll try to take a look at adding the scratch speedups to byob over the next few days. Some of them will be very simple to import but I suspect some of the major speedups in the execution machinery might need a fair bit of work since byob has altered things down in the dungeons.
simplesi
Thu Dec 26, 2013 9:15 pm
I think the variable display issue has always been the real killer slowdown so if that one alone could be sorted that would be great :)
Simon
timrowledge
Fri Dec 27, 2013 10:16 pm
OK, for the pathologically brave, there is another BYOB derived image at https://www.dropbox.com/s/hd1j1n7ig0ak9 ... .image.zip
It's so scary you might want to hide behind the sofa with your anti-Dalek paper bag over your head.
What it has so far-
better handling of the updating of variables displayed on-stage
popup menus that work in the development tools (quite important when you are using them!)
faster background displaying
better graphic effect filter handling
some media item improvements
It *does not* have any of the execution engine improvements, nor the tile editing speedups - yet.
simplesi
Fri Dec 27, 2013 10:52 pm
Its just hanging with white screen with me :(
If I put the original back, then that works fine
Simon
timrowledge
Fri Dec 27, 2013 11:37 pm
Hmm. I did mention the paper bag, right?
Try adding the changes file (https://www.dropbox.com/s/e382wuh7mmwe5 ... hanges.zip) to the same directory as the image file. Make sure you have the SqueakV2.sources file in the same directory as the squeak vm - that ought to be /usr/lib/squeak - see https://www.dropbox.com/s/4x4b35kab8yn6 ... ources.zip for a copy if it isn't already there.
On my machine (which is admittedly in a decidedly not-standard state) it starts up ok. You *might* find a debug log file if we're lucky.
simplesi
Sat Dec 28, 2013 9:16 am
Copied changes into /usr/share/scratch- no diff
installed sources into /usr/lib/squeak - no diff
Simon
timrowledge
Thu Jan 02, 2014 3:38 am
Hmph. That is very odd. I'm running out of ideas to test.
simplesi
Thu Jan 02, 2014 8:14 am
I'll download them all and start again and see what happens the 2nd time
Simon
timrowledge
Thu Jan 02, 2014 6:21 pm
Just in case there is some compression artefact causing issues, try this tgz instead -
https://www.dropbox.com/s/7kftb6du1ufh2wb/BYOB-Pi2.tgz
(`tar xvzf BYOB-Pi2` should decompress it)
It runs perfectly ok on my Mac and Pi.
simplesi
Thu Jan 02, 2014 9:59 pm
No - still just white screen :(
We need someone else to try it and see what happens to them
Simon
timrowledge
Thu Jan 02, 2014 11:04 pm
Yes, I think we need a third party test; I even went so far as to copy your desktop & script stuff to see if that might explain it - no problem.
If you do the old `ps aux` do you see the vm running is
/usr/lib/squeak/4.10.2-2793 ?
simplesi
Thu Jan 02, 2014 11:15 pm
Yep
/usr/lib/squeak/4.10.2-2793/squeakvm -encoding UTF-8 -vm-dis
Simon
Return to “Scratch”
Who is online
Users browsing this forum: No registered users and 0 guests
