harlock74
MJPG and crontab
Sat Dec 07, 2013 11:48 am
Hi there,
I hope someone can help me out with this.
I have followed this guide here:
http://blog.miguelgrinberg.com/post/how ... spberry-pi
and everything is working like a charm as I can watch the stream in my browser.
I am now trying to automate the all process by using:
crontab -e
which I have edited as follows:
@reboot mkdir /tmp/stream && raspistill --nopreview -w 640 -h 480 -q 5 -o /tmp/stream/pic.jpg -tl 100 -t 9999999 -th 0:0:0 && LD_LIBRARY_PATH=/usr/local/lib mjpg_streamer -i "input_file.so -f /tmp/stream -n pic.jpg" -o "output_http.so -w /usr/local/www"
Basically after rebooting my RPI I can see the new folder /tmp/stream, by running top I can see the raspistill is running but not mjpg. I am sure I am doing something wrong but I wouldn't know what though. I have also tried to edit crontab as follows:
@reboot mkdir /tmp/stream && raspistill --nopreview -w 640 -h 480 -q 5 -o /tmp/stream/pic.jpg -tl 100 -t 9999999 -th 0:0:0 && home/pi/stream.sh"
where stream.sh is a script which I have edited as follows:
#!/bin/bash
then I have given the right permission with:
sudo chmod 755 /home/pi/stream
The script itself is working, indeed if I run it I can watch the video in my browser. But I won't work with crontab.
I would appreciate if someone could help me out as I am really struggling now :oops:
Many thanks in advance.
Re: MJPG and crontab
Sat Dec 07, 2013 11:59 am
I think you'd be better off adding a script to /etc/init.d
cp skeleton scriptname && vi scriptname
and using
update-rc.d scriptname enable
to get it running at boot time.
harlock74
Sat Dec 07, 2013 12:06 pm
Many thanks for getting back to me.
I will try what you suggested and I will let you know how it goes!
Thanks! :mrgreen:
scruss
Sat Dec 07, 2013 1:51 pm
harlock74 wrote:I have followed this guide here:
Hmm, there's a lot of specialized and assumed knowledge in that. Why it only half-installs the package, I don't know.
Well, with cron, you need to be explicit about paths. It doesn't know anything outside /bin and and /usr/bin. So you need to call mjpg_streamer as /usr/local/bin/mjpg_streamer. Also, you might be relying on /tmp being cleared out on reboots; mkdir will fail if the folder already exists, and so will the rest of your command.
home/pi/stream.sh → /home/pi/stream.sh
#!/bin/bash
mjpg_streamer → /usr/local/bin/mjpg_streamer
Any scripts you run from cron inherit its limited environment. Also, is /usr/local/www writeable by this user?
Pronouns: he/him
harlock74
Sat Dec 07, 2013 8:19 pm
Hi DougieLawson/Scruss,
Many thanks for your kind help. I have now managed to get everything up and running :mrgreen:
Scruss,
Just out of curiosity, what did you mean by
How can I install the full package then?
Thanks again!
scruss
Thu Dec 12, 2013 3:51 pm
One usually does a 'make' followed by a 'sudo make install', but given this package has no documentation (ಠ_ಠ) and relies on a whole bunch of other stuff to build, you're probably okay as is. I've been bitten before by installing just enough of a package to get it working. Other packages - when finding the mjpg_streamer binary in your path - might assume that everything else is also there, and fail in hilarious ways on installation.
Glad to hear you got it working.
Pronouns: he/him
harlock74
Mon Dec 23, 2013 8:58 pm
scruss wrote:One usually does a 'make' followed by a 'sudo make install', but given this package has no documentation (ಠ_ಠ) and relies on a whole bunch of other stuff to build, you're probably okay as is. I've been bitten before by installing just enough of a package to get it working. Other packages - when finding the mjpg_streamer binary in your path - might assume that everything else is also there, and fail in hilarious ways on installation.
I see. Thank you!
Return to “Camera board”
