texy wrote:Still sounds like power issues, although not necessarily the actual PSU, which if the 2.8A rating is accuarate, is plenty good enough for the job.
Have you tried another usb cable - the one that feeds the power to the pi?
Also can you try to isolate the +5v line in the cable that connects the hub to one of the pi's usb ports?
Texy
hi Texty
You are right, the PSU for hub is fine, I measured it when I plug everything in and out it stays above 5.1V so it does not seem to be the problem.
I have consistently confirmed it is somehow conflicting with my Mouse/Keyboard combo (i tried various ones) No matter which one of Mouse/Key with my wifi, one of the items fail or locks up until I unplug my mouse or keyboard and then the wifi works again. I confirm this also by booting up with just wifi and no mouse/key. And the boot just flies thru, but if I boot with all three plugged in, i get hung up on USB read errors.
Sometimes I am able to get all three to work in terminal after booting, confirmed by pinging
www.google.com but with I got to GUI with startx, again one of the three accessories will fail.
I even switched Rpi as I have an extra one thinking it is board problem, It does not solve it.
can anyboy thinnk of why USB accessories are conflicting with each other? OH i also tried to do without using hub, same result.
TEXTY;; I tried various cables, did not seem to help. What do you mean by isolating the cable between Rpi and hub?
