daddadhad
Re: (UPDATE) Drivers for TL-WN725N V2 - 3.6.11+ -> 3.10.32+
Mon Mar 03, 2014 8:24 pm
what dir do you download it to?
11 years of age
built my own computer at age 10
problem solver since the day I was born
NUKE IN 3 2 1 BOOOOOM!!!
MrEngman
Mon Mar 03, 2014 8:49 pm
daddadhad wrote:what dir do you download it to?
Download to your default home directory - probably /home/pi.
The easy way to get there is to just use the command
cd
then run all the install commands from there.
MrEngman
woodside
Tue Mar 04, 2014 4:28 pm
Hi MrEngman
I wonder if you can help me?
I am trying to get the WN725N working with WiFi Direct for the Piracast (Miracast on Pi) Beta Release and although I had it working once, I have since reinstalled Rasbian to 3.10.32+ #648 and it no longer works. It does connect, but seems to fall over when loading the p2p_hostapd.conf file.
The syslog reports:-
Mar 4 00:16:13 raspberrypi ifplugd(wlan0)[2291]: Using interface wlan0/C0:4A:00:18:2E:96 with driver <rtl8188eu> (version: )
Mar 4 00:16:13 raspberrypi ifplugd(wlan0)[2291]: Using detection mode: wireless extension
Mar 4 00:16:13 raspberrypi ifplugd(wlan0)[2291]: Initialization complete, link beat not detected.
Just so that I can rule out the driver, could you please confirm that ALL I need to do with a fresh Raspbian build is:-
wget https://dl.dropboxusercontent.com/u/802 ... 226.tar.gz
tar -zxvf 8188eu-20140226.tar.gz
sudo install -p -m 644 8188eu.ko /lib/modules/3.10.32+/kernel/drivers/net/wireless
sudo depmod 3.10.32+
sudo reboot
As you probably gathered, I have no idea how this works and at one stage on a previous install, I mistakenly used the rtl8188eufw.bin file. I don't know if this updates the firmware on the dongle or just updates Rasbian - I did read somewhere that if the wrong firmware is used on the dongle, then it could be fatal, so I wondered if this might be the reason.
If you think the driver is OK, then I will have to look elsewhere.
Thanks in advance for any help you can give.
MrEngman
Tue Mar 04, 2014 5:00 pm
Hi woodside,
The instructions you've used to install the driver are all OK. Whether it works or not then depends on the configuration data required. For basic wifi use this would be done using file /etc/network/interfaces and may be file /etc/wpa_supplicant/wpa_supplicant.conf if you are using wpa_supplicant.
Regarding the firmware the version of driver I use does not need any external firmware file as it is included in the driver module so no need to worry about updating firmware. If you have loaded firmware rtl8188eufw.bin it will be ignored.
I have no experience using Piracast so I've no idea what you may need to do to get the driver working with it. The driver source file includes a load of documentation and includes one about Miracast so it may be useful to download it and have a look at that. The driver souce can be downloaded and unzipped using
wget http://lazyzhu.com/file/RTL8188EUS_RTL8189ES_linux_v4.1.8_9499.20131104.zip
unzip RTL8188EUS_RTL8189ES_linux_v4.1.8_9499.20131104.zip
Hope that may be some help.
MrEngman
woodside
Tue Mar 04, 2014 5:57 pm
So the driver looks as though it is working correctly. I shall certainly look at the documentation, but whether I will understand it is another matter! Thank you so much for your prompt reply.
MrEngman
Re: (UPDATE) Drivers for TL-WN725N V2 - 3.6.11+ -> 3.10.33+
Fri Mar 07, 2014 6:23 pm
Updated 8188eu.ko driver now available for 3.10.33+
See here
MrEngman
fluxcapacitor
Sun Mar 09, 2014 9:45 pm
Is anybody getting a fail
ERROR: The certificate of ‘dl.dropboxusercontent.com’ is not trusted.
ERROR: The certificate of ‘dl.dropboxusercontent.com’ hasn't got a known issuer.
with SSL on the download site? I'm issuing
wget https://dl.dropboxusercontent.com/u/80256631/8188eu-20140307.tar.gz
as the command. It works with http though :-S My Mac on 10.6.8 Snow Leopard doesn't trust this certificate, yet my RPi does. Is there a trusted source online that I can update my certificates on my Mac? I've actually never done that, and perhaps they're really outdated. Still wondering though.
Sun Mar 09, 2014 9:52 pm
sudo apt-get update
sudo apt-get install ca-certificates
will fix it on your RPi.
Don't know how to do that on OS X.
This is a doctor free zone.
twlare
Wed Mar 12, 2014 6:13 pm
Dear MrEngman,
All of us TL-WN725N V2 users appreciate the work you've done to get and keep our goofy WiFi adapter running. I don't know what we would do without you. Is there some way to get TL-WN725N V2 support added to the main Raspbian distribution so that you don't have to do all this work?
MrEngman
Wed Mar 12, 2014 9:56 pm
Hi twlare, thanks.
There is a version of the driver being included in development versions 3.12.y and 3.13.y but not the one I prefer. It is the driver being mangled by lwfinger and requires a separate firmware file which I find is totally unnecessary.
I did use the lwfinger driver for a while but then came across an unmodified driver from Realtek and I now use that as I find the other one has caused me various problems and using the separate firmware file is, I think. really unnecessary and over-complicated. The driver version I now use seems much more reliable.
This stuff I do now is similar to work I did with the driver for the EW-7811Un and other devices using the 8188cus before that was included in the available images. Keeps me occupied occasionally ;)
MrEngman
albert.avipe
Sat Mar 15, 2014 11:45 am
Hey MrEngman,
Thank god I stumbled upon your post after hours (or maybe minutes, is not that hard to find :D ) trying to make my wifi work. But after configuring it all and moving my pi to the living room to connect it to my TV it stopped working properly. While I have perfect signal strenght and low latency at 4m from the router, weird things happend when I move it behind a rather slim wall, at 4.1m. Those are the ping results to the router:
PING 172.17.0.151 (172.17.0.151) 56(84) bytes of data.
64 bytes from 172.17.0.151: icmp_req=1 ttl=64 time=96.8 ms
64 bytes from 172.17.0.151: icmp_req=2 ttl=64 time=156 ms
64 bytes from 172.17.0.151: icmp_req=3 ttl=64 time=7.76 ms
64 bytes from 172.17.0.151: icmp_req=4 ttl=64 time=23.1 ms
64 bytes from 172.17.0.151: icmp_req=5 ttl=64 time=242 ms
64 bytes from 172.17.0.151: icmp_req=6 ttl=64 time=30.5 ms
64 bytes from 172.17.0.151: icmp_req=7 ttl=64 time=1188 ms
64 bytes from 172.17.0.151: icmp_req=8 ttl=64 time=853 ms
64 bytes from 172.17.0.151: icmp_req=9 ttl=64 time=62.5 ms
Do you think it has something to do with the driver? My kernel version is 3.10.25+.
All other wireless devices work fine placed in the exact same place (smartphones, laptops...).
Thank you in advance
otiumh
wifi trouble
Tue Mar 18, 2014 1:16 pm
MrEngman:
I followed your instructions detailed in "http://fars-robotics.net/".
But uptoday i take two month without to set in function the WIFI of my RPI. Indeed, I couldn´t never to turn it on. i´m very frustrated.
Maybe you can help me once more. This is that the terminal give me:
[email protected]:/home/pi# wget https://dl.dropboxusercontent.com/u/802 ... 307.tar.gz
--2014-03-18 10:04:09-- https://dl.dropboxusercontent.com/u/802 ... 307.tar.gz
Resolviendo dl.dropboxusercontent.com (dl.dropboxusercontent.com)... 107.21.234.69, 23.21.47.41, 23.21.82.216, ...
Conectando con dl.dropboxusercontent.com (dl.dropboxusercontent.com)[107.21.234.69]:443... conectado.
Petición HTTP enviada, esperando respuesta... 200 OK
Longitud: 301229 (294K) [application/octet-stream]
Grabando a: “8188eu-20140307.tar.gz.2”
100%[======================================>] 301.229 185K/s en 1,6s
2014-03-18 10:04:18 (185 KB/s) - “8188eu-20140307.tar.gz.2” guardado [301229/301229]
[email protected]:/home/pi# tar -zxvf 8188eu-20140307.tar.gz
8188eu.ko
[email protected]:/home/pi# sudo cp rtl8188eufw.bin /lib/firmware/rtlwifi
cp: no se puede efectuar `stat' sobre «rtl8188eufw.bin»: No existe el fichero o el directorio
[email protected]:/home/pi# sudo install -p -m 644 8188eu.ko /lib/modules/3.10.33+/kernel/drivers/net/wireless
[email protected]:/home/pi# sudo insmod /lib/modules/3.10.33+/kernel/drivers/net/wireless/8188eu.ko
Error: could not insert module /lib/modules/3.10.33+/kernel/drivers/net/wireless/8188eu.ko: File exists
[email protected]:/home/pi# sudo depmod -a
[email protected]:/home/pi# sudo reboot
Thank you very much.
MrEngman
Re: wifi trouble
Tue Mar 18, 2014 1:38 pm
otiumh wrote:MrEngman:
8188eu.ko
You do not to install file rtl8188eufw.bin, the firmware file, as this version of the driver does not need it. Check the install instructions. Please supply the output of commands
uname -a
lsusb
lsmod
cat /etc/network/interfaces
sudo cat /etc/wpa_supplicant/wpa_supplicant.conf
What do you see if you use command
sudo iwlist wlan0 scan
MrEngman
otiumh
Tue Mar 18, 2014 2:24 pm
Ok. , here you have Mr. Egman:
[email protected] ~ $ uname -a
Linux OTIUMH 3.10.33+ #656 PREEMPT Fri Mar 14 18:19:28 GMT 2014 armv6l GNU/Linux
[email protected] ~ $ clear
[email protected] ~ $ lsusb
Bus 001 Device 004: ID 0bda:8179 Realtek Semiconductor Corp.
[email protected] ~ $ lsmod
Module Size Used by
snd_bcm2835 16165 0
snd_soc_bcm2708_i2s 5474 0
regmap_mmio 2806 1 snd_soc_bcm2708_i2s
snd_soc_core 131268 1 snd_soc_bcm2708_i2s
snd_compress 8076 1 snd_soc_core
regmap_i2c 1645 1 snd_soc_core
regmap_spi 1897 1 snd_soc_core
8188eu 665223 0
snd_pcm 81593 2 snd_bcm2835,snd_soc_core
snd_page_alloc 5156 1 snd_pcm
snd_seq 53769 0
snd_seq_device 6473 1 snd_seq
snd_timer 20133 2 snd_pcm,snd_seq
leds_gpio 2059 0
led_class 3688 1 leds_gpio
snd 61291 7 snd_bcm2835,snd_soc_core,snd_timer,snd_pcm,snd_seq,snd_seq_device,snd_compress
[email protected] ~ $ cat /etc/network/interfaces
auto lo
iface lo inet loopback
iface eth0 inet dhcp
#WIFI
allow-hotplug wlan0
iface wlan0 inet dhcp
wpa-ssid= "MERLUZONET"
wpa-psk= "ernesto2716"
[email protected] ~ $ sudo cat /etc/wpa_supplicant/wpa_supplicant.conf
update_config=1
network={
ssid= "MERLUZONET"
psk= "ernesto2716"
proto=RSN
key_mgmt=WPA-PSK
pairwise=CCMP
auth_alg=OPEN
[email protected] ~ $ sudo iwlist wlan0 scan
wlan0 Scan completed :
Cell 01 - Address: 00:22:75:22:17:54
ESSID:"MERLUZONET"
Protocol:IEEE 802.11bgn
Mode:Master
Frequency:2.412 GHz (Channel 1)
Encryption key:on
Bit Rates:144 Mb/s
Extra:wpa_ie=dd1c0050f20101000050f20202000050f2020050f20401000050f2020000
IE: WPA Version 1
Group Cipher : TKIP
Pairwise Ciphers (2) : TKIP CCMP
Authentication Suites (1) : PSK
Extra:rsn_ie=30180100000fac020200000fac02000fac040100000fac020000
IE: IEEE 802.11i/WPA2 Version 1
Group Cipher : TKIP
IE: Unknown: DD9F0050F204104A0001101044000102103B000103104700102880288028801880A8800022752217541021001242656C6B696E20436F72706F726174696F6E1023001642656C6B696E20576972656C65737320526F75746572102400034635441042000C3131313131313131313131311054000800060050F20400011011001642656C6B696E20576972656C65737320526F75746572100800020084103C000101
Quality=0/100 Signal level=96/100
Extra:fm=0003
Cell 02 - Address: D4:D1:84:AC:39:69
ESSID:"morocha"
Mode:Master
Frequency:2.427 GHz (Channel 4)
Encryption key:on
Bit Rates:300 Mb/s
Extra:wpa_ie=dd180050f20101000050f20401000050f20401000050f2020c00
IE: WPA Version 1
Group Cipher : CCMP
Pairwise Ciphers (1) : CCMP
Quality=0/100 Signal level=39/100
Extra:fm=0003
Cell 03 - Address: 00:21:00:87:DF:27
ESSID:"Omar Wi-fi"
Mode:Master
Frequency:2.437 GHz (Channel 6)
Encryption key:on
Bit Rates:54 Mb/s
Extra:fm=0003
Cell 04 - Address: 90:B1:34:8F:07:BE
ESSID:"Luana"
Mode:Master
Frequency:2.457 GHz (Channel 10)
Encryption key:on
Bit Rates:54 Mb/s
Extra:wpa_ie=dd1c0050f20101000050f20202000050f2040050f20201000050f2020c00
IE: WPA Version 1
Group Cipher : TKIP
Pairwise Ciphers (2) : CCMP TKIP
Quality=0/100 Signal level=27/100
Extra:fm=0003
MrEngman
Tue Mar 18, 2014 2:43 pm
Hi otiumh,
The format you have used for /etc/network/interfaces means you do not need /etc/wpa_supplicant/wpa_supplicant.conf so that file will be ignored. The driver looks to be installed OK and is working as you see a list of networks.
I think there is a minor problem with file /etc/network/interfaces. I think it should be
auto lo
#WIFI
allow-hotplug wlan0
 wpa-ssid "MERLUZONET"
 wpa-psk "ernesto2716"
There should be NO = sign in lines wpa-ssid and wpa-psk.
Also it is not a good idea to show the network password. Now anyone can login to your wifi network. You should change the password.
Hopefully this will now get your wifi working.
MrEngman
MrEngman
Tue Mar 18, 2014 2:55 pm
albert.avipe wrote:Hey MrEngman,
I have seen similar behaviour. My access point is downstairs on one side of the house and the Pi is upstairs on the other side of the house. Ping results vary greatly depending on what I ping. e.g.
64 bytes from 192.168.16.2: icmp_req=1 ttl=128 time=2.35 ms
64 bytes from 192.168.16.2: icmp_req=2 ttl=128 time=0.844 ms
64 bytes from 192.168.16.2: icmp_req=3 ttl=128 time=78.2 ms
64 bytes from 192.168.16.2: icmp_req=4 ttl=128 time=202 ms
64 bytes from 192.168.16.2: icmp_req=5 ttl=128 time=21.3 ms
64 bytes from 192.168.16.200: icmp_req=2 ttl=64 time=0.761 ms
64 bytes from 192.168.16.200: icmp_req=3 ttl=64 time=0.810 ms
64 bytes from 192.168.16.200: icmp_req=4 ttl=64 time=0.823 ms
64 bytes from 192.168.16.200: icmp_req=5 ttl=64 time=0.756 ms
64 bytes from 192.168.16.200: icmp_req=6 ttl=64 time=0.729 ms
64 bytes from 192.168.16.202: icmp_req=2 ttl=64 time=5.42 ms
64 bytes from 192.168.16.202: icmp_req=3 ttl=64 time=4.73 ms
64 bytes from 192.168.16.202: icmp_req=4 ttl=64 time=3.97 ms
64 bytes from 192.168.16.202: icmp_req=5 ttl=64 time=4.10 ms
64 bytes from 192.168.16.202: icmp_req=6 ttl=64 time=4.04 ms
64 bytes from 192.168.16.202: icmp_req=7 ttl=64 time=4.05 ms
If I change to a different access point, also downstairs but with one less wall between the Pi and access point the results are much more consistent.
64 bytes from 192.168.16.2: icmp_req=1 ttl=128 time=1.19 ms
64 bytes from 192.168.16.2: icmp_req=2 ttl=128 time=2.53 ms
64 bytes from 192.168.16.2: icmp_req=3 ttl=128 time=4.02 ms
64 bytes from 192.168.16.2: icmp_req=4 ttl=128 time=2.56 ms
64 bytes from 192.168.16.2: icmp_req=5 ttl=128 time=2.68 ms
64 bytes from 192.168.16.200: icmp_req=1 ttl=64 time=1.97 ms
64 bytes from 192.168.16.200: icmp_req=2 ttl=64 time=0.782 ms
64 bytes from 192.168.16.200: icmp_req=3 ttl=64 time=0.687 ms
64 bytes from 192.168.16.200: icmp_req=4 ttl=64 time=0.931 ms
64 bytes from 192.168.16.200: icmp_req=5 ttl=64 time=0.789 ms
64 bytes from 192.168.16.202: icmp_req=2 ttl=64 time=4.11 ms
64 bytes from 192.168.16.202: icmp_req=3 ttl=64 time=5.45 ms
64 bytes from 192.168.16.202: icmp_req=4 ttl=64 time=4.01 ms
64 bytes from 192.168.16.202: icmp_req=5 ttl=64 time=3.95 ms
64 bytes from 192.168.16.202: icmp_req=6 ttl=64 time=4.52 ms
MrEngman
otiumh
Tue Mar 18, 2014 3:16 pm
Thank you So much Mr. Engman. I made the change in the "=" signo, but...it is still out of work.
maybe this comands help you to help me:
[email protected] ~ $ iwconfig
wlan0 unassociated Nickname:"<[email protected]>"
Mode:Managed Frequency=2.412 GHz Access Point: Not-Associated
Sensitivity:0/0
Retry:off RTS thr:off Fragment thr:off
Power Management:off
Link Quality:0 Signal level:0 Noise level:0
Rx invalid nwid:0 Rx invalid crypt:0 Rx invalid frag:0
Tx excessive retries:0 Invalid misc:0 Missed beacon:0
lo no wireless extensions.
eth0 no wireless extensions
MrEngman
Tue Mar 18, 2014 5:48 pm
Hi otiumh,
There doesn't seem to be any problem with the wifi data and information except the wifi does not connect.
This sort of problem is often because the wifi name or password is not correct. Are you sure you have the password set correctly?
What happens if you try the two commands
sudo ifdown --force wlan0
sudo ifup --force wlan0
Try two or three times if it does not connect the first time.
MrEngman
otiumh
Tue Mar 18, 2014 8:38 pm
Hi Mr. Engman
I´ve tried at least 6 or 7 times, as you told me, and this is the resultant:
[email protected] ~ $ sudo ifdown --force wlan0
Internet Systems Consortium DHCP Client 4.2.2
Copyright 2004-2011 Internet Systems Consortium.
All rights reserved.
For info, please visit https://www.isc.org/software/dhcp/
Listening on LPF/wlan0/64:66:b3:1d:0c:fb
Sending on LPF/wlan0/64:66:b3:1d:0c:fb
Sending on Socket/fallback
[email protected] ~ $ sudo ifup --force wlan0
ioctl[SIOCSIWAP]: Operation not permitted
ioctl[SIOCSIWENCODEEXT]: Invalid argument
DHCPDISCOVER on wlan0 to 255.255.255.255 port 67 interval 6
DHCPDISCOVER on wlan0 to 255.255.255.255 port 67 interval 20
DHCPDISCOVER on wlan0 to 255.255.255.255 port 67 interval 8
DHCPDISCOVER on wlan0 to 255.255.255.255 port 67 interval 7
No DHCPOFFERS received.
No working leases in persistent database - sleeping.
MrEngman
Tue Mar 18, 2014 9:31 pm
Hi otiumh,
Your set up for /etc/network/interfaces appears OK and the driver is loaded OK and the wifi is working as the scan shows your network. Just trying to think what could stop your wifi not connecting as the network signal level is also very good.
The main items are making sure the network name and password are correct and does your router have DHCP enabled?
Does your router use MAC address filtering? If it does you need to add your wifi MAC address to the list of allowable devices in the router.
MrEngman
Edit: you could try resetting your router to see if that makes a difference.
otiumh
Tue Mar 18, 2014 10:33 pm
"The main items are making sure the network name and password are correct and does your router have DHCP enabled? " Yes.
"Edit: you could try resetting your router to see if that makes a difference" Done.
"Does your router use MAC address filtering? If it does you need to add your wifi MAC address to the list of allowable devices in the router."----- This was the missing thing!!!!!!
Now the Raspi is updating thanks YOU!!! :D
I had the Raspi MAC in the list, but not the WiFi dongle MAC.
Thanks a lot for your help, your time and your patience.
Otiumh
otiumh
Tue Mar 18, 2014 10:37 pm
Mr. Engman:
Otiumh
MrEngman
Tue Mar 18, 2014 10:46 pm
otiumh wrote:"The main items are making sure the network name and password are correct and does your router have DHCP enabled? " Yes.
Otiumh
That's good to hear your wifi is now operating OK.
I once had the same problem with the wifi MAC address :oops:
Glad to be able to help. Have fun with your Pi.
MrEngman
undecided
Wed Mar 19, 2014 5:42 pm
MrEngman wrote:Driver files available for the TP-LINK TL-WN725N V2 and similar wifi dongles using the 8188eu driver module for systems using the Raspbian image.
Download and install the driver, and firmware if required, with the following commands
wget https://dl.dropboxusercontent.com/u/80256631/8188eu-201xyyzz.tar.gz <--set data code for driver version above
tar -zxvf 8188eu-201xyyzz.tar.gz                                         <--set data code for driver version above
# run following two commands only if using version 3.10.xx+, not required for 3.6.11+
cat README                                                               <--check README file for adding
sudo cp rtl8188eufw.bin /lib/firmware/rtlwifi                            <--firmware if not already installed
sudo install -p -m 644 8188eu.ko /lib/modules/$(uname -r)/kernel/drivers/net/wireless
sudo insmod /lib/modules/$(uname -r)/kernel/drivers/net/wireless/8188eu.ko
sudo depmod -a
Once the driver is loaded you will need to configure the network set up so the Pi will connect to your wifi network if it is not already done. There are some basic details on how to do that available here.
To help in installing or updating the driver @LaFambe has produced a very simple script available here which will automatically select and install the correct version of the driver for the version of Raspbian being used, and the firmware if necessary. I was quite impressed by it and it really does make life much simpler. To install the script look here.
Thank you very much, LaFambe.
MrEngman
I am trying to do this but do not have internet access on my Pi. So I am trying to put the driver firmware onto the SD card and access it from there to install. Hoping i can get some help, i have spent about 8 hours over the course of several days, but i am just learning all of this. @LaFambe @MrEngman @anyone who can help ;)
fluxcapacitor
Wed Mar 19, 2014 6:20 pm
undecided wrote: I am trying to do this but do not have internet access on my Pi. So I am trying to put the driver firmware onto the SD card and access it from there to install. Hoping i can get some help, i have spent about 8 hours over the course of several days, but i am just learning all of this. @LaFambe @MrEngman @anyone who can help ;)
Hi undecided. I imagine you are able to download the driver elsewhere on a computer? Are you running Raspbian? Do you need the actual firmware or not? The firmware hasn't been necessary for many releases. Perhaps you are only referring to the driver and not the firmware?
Option 1: If you have GNU/Linux, you can mount the partitions on the RPi SD card with no problem and copy the files to the SD card directly to the correct location.
Option 2: If you have a different OS, perhaps the easiest is to boot the RPi with a USB flash attached the the USB port, loaded with the driver files. From there, you can mount the USB flash on the RPi and copy the files from the USB flash to the necessary locations of the RPi.
