pi@pi0:~/bin $ ./pirevcode.sh
Code Model Proc Rev RAM Manufacturer
900092 Zero BCM2835 1.2 512MB Sony UK
Use the driver that matches the kernel version from command uname -a. It does not show -v6l, just 5.4.51+ #1333 so you don't need a driver file that includes -v6l.tinker2much wrote: ↑Sat Aug 15, 2020 7:27 pmuname -a says:
I looked at your download site http://downloads.fars-robotics.net/wifi ... u-drivers/ for "8188eu-5.4.51-v6l-1333.tar.gz", but no such file exists. The following are there, though:Linux pi0 5.4.51+ #1333 Mon Aug 10 16:38:02 BST 2020 armv6l GNU/Linux
Can I use the one with no "v" qualifier?8188eu-5.4.51-1333.tar.gz
8188eu-5.4.51-v7-1333.tar.gz
8188eu-5.4.51-v7l-1333.tar.gz
8188eu-5.4.51-v8-1333.tar.gz
I hadn't looked at the output of "uname -a" on any of my pi's recently. I saw the "armv6l" near the end of the output, and mistakenly assumed that was the v6 you were looking for. If I do a "uname -l" on my pi4, I clearly see you're looking for a modifier in the front, next to the kernel, in that case "v7l":MrEngman wrote: ↑Sat Aug 15, 2020 7:52 pmUse the driver that matches the kernel version from command uname -a. It does not show -v6l, just 5.4.51+ #1333 so you don't need a driver file that includes -v6l.tinker2much wrote: ↑Sat Aug 15, 2020 7:27 pmuname -a says:
In your case use 8188eu-5.4.51-1333.tar.gz.
EDIT: If you use my install-wifi script it will automatically select the right driver file.
MrEngman
pi@pi4:~ $ uname -a
Linux pi4 5.4.51-v7l+ #1333 SMP Mon Aug 10 16:51:40 BST 2020 armv7l GNU/Linux
