This is how I fixed the problem of copying 8GB card to another, somewhat smaller, 8GB card
(Cards could be of any size, it's important only that the target card is smaller and that actual data from the source card could fit on it)
Prerequisite: separate Linux and Windows boxes (Pi not needed).
Resize the source card
(on Linux)
Run gparted to reduce the size of the "data" partition on the source card.
I reduced it by ~500MB, but I guess 100-200MB would have sufficed. As can be seen in the code later (*), the actual difference was 120MB.
This needs to be done only one time.
Make an image of the source card
(on Windows, sorry)
Make an image of the source card with Win32DiskImager. Don't be alarmed by result -- the image will be the same size as before the resizing (because physical sectors did not change), but what's important, the end of it will now contain uninitialized partition (500MB), so it's safe if we cut that off when copying to a smaller card later.
Prepare for copying
(on Linux)
First we need to check the size of the target card with this command:
sudo fdisk /dev/mmcblk0Code: Select all
sudo fdisk target.img(after hitting enter on the fdisk command, press 'p' to display the partition info)
ubuntu@ubuntu:/media/Other$ sudo fdisk OpenElec_2013-11-28.img
Command (m for help): p
Disk OpenElec_2013-11-28.img: 7822 MB, 7822376960 bytes
255 heads, 63 sectors/track, 951 cylinders, total 15278080 sectors
Units = sectors of 1 * 512 = 512 bytes
Sector size (logical/physical): 512 bytes / 512 bytes
I/O size (minimum/optimal): 512 bytes / 512 bytes
Disk identifier: 0x0001080e
Device Boot Start End Blocks Id System
OpenElec_2013-11-28.img1 * 2048 258047 128000 c W95 FAT32 (LBA)
OpenElec_2013-11-28.img2 258048 1830911 786432 83 Linux
Next, as we will use 'dd' command for copying data, we have to calculate some parameters for it.
('bs' as in block size)
bs=1M (kilo times kilo equals mega: 1024 * 1024 = 1M)
('count' as in number of blocks to copy)
count=7460 (divide target size with block size to get number of blocks: 7822376960 / (1024 * 1024) = 7460)
Do the copy
As the shell operation last for some minutes (depending on the speed of the card, 10-20 min), we'll use 'pv' to track the progress. This is the complete command:
pv source.img | sudo dd of=/dev/mmcblk0 bs=1M iflag=fullblock count=7460Code: Select all
pv source.img | sudo dd of=target.img bs=1M iflag=fullblock count=7460Additional info
(*) To calculate the actual difference for which the target card should be resized down, we also need the size of the source card. Use the same 'fdisk' command explained above, just with the source card inserted in the reader:
sudo fdisk source.img7948206080 - 7822376960 = 125829120 / 1024 / 1024 = 120M ==> the source partition should be reduced by at least 120M to prevent data loss!
NB: you don't actually need 'fdisk' if you have both images -- just check their sizes with
ls -l(as in Test Driven Copying
Unsure will it work? Test writing on (virtual) device first!
# create an empty image the size of target card
dd if=/dev/zero of=test.img bs=1M count=7460
#connect the loopback device
losetup /dev/loop1 test.img
#to simulate an error, don't limit the number of written blocks
pv source.img | sudo dd of=/dev/loop1 bs=1M iflag=fullblock
#result: "dd: writing `/dev/loop1': No space left on device"
#copy all content from the source to the target (while watching progress)
pv source.img | sudo dd of=/dev/loop1 bs=1M iflag=fullblock count=7460
#et voila! dd should finish w/o error
